Old 05-24-2013, 04:55 PM   #1
quik8outlaw
gas mileage
My 88 crewcab has a 454 with a 400 trans. Like all other big blocks, it gets bad gas mileage, 6-7 mpg. would I get better mileage with a 700r4, would it be worth the hassel of changing the transmissions ? what kind of mileage could I expect with a overdrive ?
quik8outlaw is offline   Reply With Quote
Old 05-24-2013, 05:13 PM   #2
Skunksmash
Skunksmash's Avatar
Re: gas mileage
You'll get a little better with the extra gear, but I wouldn't expect much. Then again if wth gas prices these days...
Skunksmash is offline   Reply With Quote
Old 05-24-2013, 07:14 PM   #3
donut
donut's Avatar
Re: gas mileage
x2, even at today's price of gas, it's going to take quite a while to pay for the swap.
Is 6-7 normal for you? I get 10-11 with my carburated, single cab much to the dismay of one of my co-workers with a mid to late 90's extra cab bb dually, as that is what he gets with fuel injection and OD.
Oh factor in the extra cost of getting a 700r4 built to live behind a BB, especially if you use it like a truck. I've seen 4l80e and stand alone controllers mentioned before behind 454's
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 05-24-2013, 08:15 PM   #4
74 stepside
74 stepside's Avatar
Re: gas mileage
You can expect 1-2 more miles per gallon. Aerodynamics also plays a big part. Lowered helps a little, a bed cover or cab high shell will also help a little. If you have 4.10 rear gears, a swap to 3.73 will also help. My lowered 92 crewcab dually with OD and fuel injected 454 got 14 mpg. it also had a cab high shell.
74 stepside is offline   Reply With Quote
Old 05-25-2013, 08:52 AM   #5
BONUSCAB
Re: gas mileage
My 1990 454/400 Crew Cab gets 4.5-5.5 miles per gallon. I think. I don't know my odometer is accurate due to my speedo being sketchy. And I know that it's off due to my 33ish inch tall tires. Wheels and tires are ridiculously heavy, and that takes it's toll on mpg. Truck is pretty much a winter vehicle. I don't have a long drive to work (6-7 miles) so it barely gets to operating temp. **** sucks, but it is what it is and mine is waiting to get Cummins swapped...
BONUSCAB is offline   Reply With Quote
Old 05-25-2013, 10:38 AM   #6
RT Big Block
RT Big Block's Avatar
Re: gas mileage
My 75 1 ton with 454 , 4 speed with 3.73 gets around 18 mpg . The worst I have ever gotten with it was 11 mpg but I was loaded 26,000 lbs. Pulling my boats I get around 14 mpg I dont understand why you guys are getting so bad gas mileage. I am getting ready to build a 75 crew cab that I am going to put 427 and 4 speed with U S gear overdrive with 3.73 gear and I am hoping for around 20 mpg with it . I have always done great with gas mileage with big blocks .
RT Big Block is offline   Reply With Quote
Old 05-25-2013, 01:52 PM   #7
lgvl
lgvl's Avatar
Re: gas mileage
I have a similar setup on my 82 454 th400 dually 3+3 but usually get around 11-13 Mpg mixed highway and city. As i've never done the 700r swap i couldn't help you with that question but i can tell you i never speed when the speed limit is over 55mph and i run radial tires versus the chunky truck ones. Also, if you take it easy on the acceleration your gas gauge will thank you.
'82 C30 3+3 Dually 454
lgvl is offline   Reply With Quote
Old 05-25-2013, 02:12 PM   #8
meatwagon83
meatwagon83's Avatar
Re: gas mileage
im callin shenanigans on this one!
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 05-25-2013, 03:36 PM   #9
BONUSCAB
Re: gas mileage
I too call shenanigans. My truck is a 4x4 also.
Old 05-25-2013, 03:48 PM   #10
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Re: gas mileage
I put a Comp Cam's Extreem Energy cam in my '87 crew cab (454) , I went from 9 or 10 on the interstate to 13 or 14, my next step will be a 700R4 and 373 gears.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 05-25-2013, 05:11 PM   #11
RT Big Block
Re: gas mileage
I know you dont believe me but its true ! I worked for GM for 15 years . And I do know how to get mileage out of a big bock and its real easy to do . I guess it does help I have a friend that was a engineer at GM too.
Old 05-25-2013, 06:05 PM   #12
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: gas mileage
I could see it. Especially if your in a low traffic area. Sitting at a stop light for five minutes and driving for only two at a time and hardly reaching 30mph cause nobody can grab their balls and move. Well that's what destroys gas mileage
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-25-2013, 06:41 PM   #13
meatwagon83
Re: gas mileage
Well by all means share with the rest of the class! I know I for one would love to get another 10mpg out of my truck!
Old 05-25-2013, 06:55 PM   #14
LynnJr
Re: gas mileage
I'm getting 10-12 with a 1/2 ton short fleetside 3.73 rear and hard tonneau cover slammed on the ground with th400.
LynnJr is offline   Reply With Quote
Old 05-25-2013, 07:19 PM   #15
KevinD85
KevinD85's Avatar
Re: gas mileage
I got 12-14 with my crew cab dually 4x4 with the mighty 6.2 on 37's.
I got 7-9mpg with my 90 454 ss turbo 400 and 3.42 gears I had a lead foot with that truck though ha.
I would do a cummins swap and a 5 speed if you were after fuel economy.
1986 chevy k10 silverado rust free from oregon 350 crate big cam,headers and 2.5" duals with an x pipe.
2001 subaru 2.5 rs with a full wrx sti swap track car project
1991 Lexus Ls400 rwd drift toy
2012 lexus is350 awd daily driver
KevinD85 is offline   Reply With Quote
Old 05-26-2013, 12:32 AM   #16
andrewmp6
Re: gas mileage
A overdrive trans will help some but these trucks are heavy and have the aerodynamics of a brick.
andrewmp6 is offline   Reply With Quote
Old 05-29-2013, 12:40 AM   #17
jimbonice
jimbonice's Avatar
Re: gas mileage
I've got a dually with a 454, 4.10's and a 700r4. Don't expect big mileage gains. The big benefit is a much quieter truck on the highway; it loafs along at 70-80 now.
jimbonice is offline   Reply With Quote
Old 05-29-2013, 12:55 AM   #18
83GMCK2500
Re: gas mileage
That is a big beautiful truck. 80 grille and 77 trim? Have you done a little customizing?
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 05-29-2013, 01:00 AM   #19
Rubble
Rubble's Avatar
Re: gas mileage
That is a really nice truck!!!!
1985 GMC K35 454/465/205 Dually
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
1983 Chev C20 350/700R
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 05-29-2013, 01:06 AM   #20
jimbonice
jimbonice's Avatar
Re: gas mileage
I don't want to highjack the thread, but yes, it's got a1980 front end and it's a '77 from the cab back. You've got sharp eyes.
Old 05-29-2013, 01:35 AM   #21
JellyBeanDriver
Re: gas mileage
Ditto, nice truck! Kind of what we have for hauling horses.
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer.
JellyBeanDriver is offline   Reply With Quote
Old 05-29-2013, 07:53 AM   #22
tucsonjwt
Re: gas mileage
I had a 73 C20 454/400 and currently have an 83 C20 454/SM465 (both regular cab long beds) and do only city driving. I got 11 mpg best in city only driving on the 73, and get 9-10 mpg city only driving with the 83 (I attribute that to the smog equipment on the 83. The best highway mpg I got with the 83, even using the gear vendor, was 13 mpg.
If there are secrets to better gas mileage I would sure like to know what they are. I can't remove emissions equipment because I live in a emissions required part of Arizona. In city driving, I spend more time stopped and idling at intersections than driving.
tucsonjwt is offline   Reply With Quote
Old 12-03-2013, 09:38 PM   #23
swissarmychainsaw
Re: gas mileage
I would also like to know the secrets. Too bad that dude did not follow up.
My '75 Gentleman Jim gets 9-11mpg, and that's mostly highway driving the speed limit (65 or less). 350/350
This thing needs a tune and burns a little oil. I imagine I might be able to do a tad better.
My 84' 305/700R4 got 21 @ 65mph highway until the tranny went south.
Then it never got above 17mpg. But it was a dog. I like my 75 350 better, even with the crappy mileage.
Would better heads help?
swissarmychainsaw is offline   Reply With Quote
Old 12-03-2013, 11:42 PM   #24
nekkidhillbilly
Re: gas mileage
hell my 4.8 4wd 01 would only pull a best of 18 city and 22 ish highway no way i can see a big block with no od pull that. the 6.0 trucks the same year pulled a best of 16.
2004 2500 hd dmax cc 4x4
2008 saturn aura xr
1966 buick gran sport
1984 k20
nekkidhillbilly is offline   Reply With Quote
Old 12-04-2013, 01:52 AM   #25
LynnJr
Re: gas mileage
Just put 1538 miles on a brand new Ford F150 and my mileage was 11.3 mpg.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
