Old 06-16-2013, 04:34 PM   #1
BigRed76
BigRed76's Avatar
1/2 vs. 3/4 ton leaf spring differences
I'm in the process of converting a K10 chassis to K20 for my '70. I've done some searching and haven't found much info specific to 67-72 4wd springs. Basically I'd like to know the difference of leafs between 1/2 ton and 3/4 ton springs on 4wds.
I will be lifting the truck 2" with Tuff Country EZ-Ride springs in the front, and was thinking about going with 2" blocks in the rear, but I don't want to use 1/2 springs in the rear. Tuff country lists the same part #'s for springs for 1/2 ton and 3/4 ton, not sure what's up with that
My current 1/2 ton springs have 2 leafs up front, and 4 leafs plus an overload leaf out back. And I have a set of rear leafs from a 2wd 3/4 ton, which have 5 leafs plus an overload leaf, but they are only 2.25" wide.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 06-16-2013, 06:05 PM   #2
Bigdav160
Bigdav160's Avatar
Re: 1/2 vs. 3/4 ton leaf spring differences
I'm installing the same kit on my K20 right now. I almost asked the same questions as I wasn't sure of my current setup (stock or not) and the possibility of needing the HD Tuff Country springs. Right now I'm glad I went with the 2" EZ ride.
My SPID list HD Front spring as an option. It had four leaves in front. The rear had five leaves plus the short overload on the bottom and a 2 inch blocks.
Note the new rear springs have the correct EZ part number but say 4" on the tag. The truck sits up quite a but higher than before.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-16-2013, 11:39 PM   #3
BigRed76
BigRed76's Avatar
That's interesting, I'd never heard of the HD front spring option for a 4wd. How do the EZ ride springs actually ride?
Zach
Old 06-16-2013, 11:55 PM   #4
BigRed76
BigRed76's Avatar
I'm thinking that the stock 3/4 tons had 3 leafs in the front and 5 leafs in the back. Can anyone confirm this?
Zach
Old 06-17-2013, 08:10 AM   #5
Bigdav160
Bigdav160's Avatar
I haven't driven it yet. I still have to install the shocks and weld in the rear spring perchs.
I went this route because the PO installed a 14 bolt and welded the perches so the pinion was pointed up at a 30 angle. I knew I was going to have to cut that out and correct it. I also had a broken leaf on the RR and a broken centering bolt in the LF.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 06-17-2013, 03:01 PM   #6
BigRed76
BigRed76's Avatar
Ah I understand. You'll have to let me know how the ride is. Mine is still a long ways away from being driven.
Zach
Old 06-20-2013, 08:26 AM   #7
BigRed76
BigRed76's Avatar
Anybody with a stock K20 have some input on this?
Zach
Old 06-20-2013, 09:55 AM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I've been gone for a few days and just now saw this thread.... The OEM front springs on my '72 K20 were two leafs (since replaced with 2.5" Skyjacker Softrides). Rear springs are 5 leafs. It's a light-duty K20, can't recall for sure but seems like 6800# GVWR -- door tag got painted over.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 06-20-2013, 11:28 AM   #9
Bigdav160
Bigdav160's Avatar
Interesting. My GVWR is #7500
I did take my Suburban out for a spin and here's my impression of the Tuff Country 2" EZ ride. I went with their 8000 series gas charged shocks
Firmer than stock. It can be harsh over larger bumps (at speed) but on smooth pavement it was a pleasure to drive.
On the down side my ride height is still 1 1/4" low in the rear. I'm going to make some taller perches today and correct it. I have an inch extra in the rear U-bolts to make it happen.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 06-20-2013, 10:17 PM   #10
BigRed76
BigRed76's Avatar
That's interesting that it rides stiffer than your HD front springs
Zach
Old 06-21-2013, 12:19 AM   #11
med.bronze
med.bronze's Avatar
I used to own a 71 K20 and like Stocker's mine had two in front and five in back
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350
1971 K-10 Custom Deluxe
1971 K-10 Custom
med.bronze is offline   Reply With Quote
Old 06-22-2013, 10:48 PM   #12
cmhamilton68
Would anyone be able to tell me the distance between the axle tube and frame front and rear on a stock k20??
cmhamilton68 is offline   Reply With Quote
Old 06-23-2013, 01:28 AM   #13
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Rear spring is ~52" long eye to eye. IIRC, the axle is located at the center.
- Mike -
RIP El Jay
Old 06-23-2013, 11:37 AM   #14
BigRed76
BigRed76's Avatar
The GVWR on mine is 7500, and it was 2wd. I'm starting to think I wanna track down some stock 3/4 ton springs rather than buying lift springs. My front springs have 2 leafs, but I'm not sure if they're any different since they're from a half ton, and they sag pretty bad.
Zach
Old 06-23-2013, 01:17 PM   #15
Bigdav160
Bigdav160's Avatar
Here's a snapshot of the parts book for front leaf springs. There are many choices in part number but not that many choices of the number of leaves. It appears, 1/2 and 3/4 ton could share the same springs.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 06-23-2013, 02:47 PM   #16
BigRed76
BigRed76's Avatar
Thanks for sharing that. Interesting that the 3 leaf front springs are HD springs and there's no mention of 4 leaves. Would you mind showing the same info for the rear springs?
Zach
Old 06-23-2013, 06:08 PM   #17
Bigdav160
Bigdav160's Avatar
I'm not sure I've got it all.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 06-30-2013, 12:59 PM   #18
BigRed76
BigRed76's Avatar
Thanks for getting me those, that's great info. to have. I think I'll be going with my original plan of a 2" lift, since I'll need the extra clearance up front to move the big block forward 2".
Zach
Old 06-13-2014, 12:29 PM   #19
reuserm@yahoo.com
i have a 72" 1/2 ton shorty with 402 and leafs, is this an odd truck?
reuserm@yahoo.com is offline   Reply With Quote
Old 06-13-2014, 12:32 PM   #20
reuserm@yahoo.com
forgot to mention, i have complete coil suspension to put in truck so ? is, should i or leave original.
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
