Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 06-20-2013, 11:48 AM   #1
atvpro
atvpro's Avatar
C50 Pick-up Drill Sergeant
This is one of two C50 pick-ups that I am currently building. One is a 3/4 ton 4wd regular cab step side pick-up truck (Drill Sergeant) will be a light tan color with a light brown interior.
The other will be a 1 ton 4wd crew cab fleet side. Have not decided on a big block or a 12 valve cummins yet but will decided soon.
On Drill Sergeant I have had to make slight modifications to the firewall to change throttle from linkage to cable and to clear the valve cover on driver side. Here are some pics of both donor trucks- the red one is underway and is Drill Sergeant. The Blue will be a crewcab.
atvpro is offline   Reply With Quote
Old 06-20-2013, 12:09 PM   #2
Southern Shaker
Re: C50 Pick-up Drill Sergeant
I LOVE C50's And ive Gotta whatch this SubScribed!
Southern Shaker is offline   Reply With Quote
Old 06-20-2013, 12:22 PM   #3
Dano69c10
Dano69c10's Avatar
D@m^ Awesome trucks!
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 06-20-2013, 12:27 PM   #4
flashed
Post Whore
Im in too , I like the big toys .
flashed is offline   Reply With Quote
Old 06-20-2013, 05:06 PM   #5
farmall
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd PS PB White With Blue Int 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
71 LT1 Convertible, 72 Coupe
69 CJ5 V6, 75 CJ6 V8
67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 06-20-2013, 05:29 PM   #6
JointTech
JointTech's Avatar
those are cool.
you guys have your own section for those monsters. http://67-72chevytrucks.com/vboard/f...play.php?f=239
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 06-20-2013, 08:07 PM   #7
jbclassix
Junk Yartist
jbclassix's Avatar
Subscribing to this one too
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 06-20-2013, 08:25 PM   #8
Don Quixote
Don Quixote's Avatar
Subscribed
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Don Quixote is offline   Reply With Quote
Old 06-20-2013, 11:29 PM   #9
1972RedNeck
1972RedNeck's Avatar
I really like those post '67 small back windows.
Do the right thing and go with a 12 valve.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 06-21-2013, 11:47 AM   #10
atvpro
atvpro's Avatar
Took care of 95% of the rust which was the driver side inner and outer rocker and the front corner. Which obviously had to be hand made because its a C50. After unsuccessfully removing a good floor pan out of another cab decided to go ahead and just make one. Will post pics tonight.
I hate having to remove spot welds off of a truck that was made on Monday.
Old 06-21-2013, 02:23 PM   #11
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work Randall!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-21-2013, 11:08 PM   #12
jbclassix
Junk Yartist
jbclassix's Avatar
I hate spot welds, period! Especially triple thick like the FREAKIN roof! You are now the official "How to do it better" builder.
-Jeremy
Rebuilding an NP205
Old 06-22-2013, 12:33 PM   #13
atvpro
atvpro's Avatar
First, to clarify, the front of the blue C50 will be going on Drill Sergeat which is the red cab. The cab of the blue will be the crew cab. (Hope that makes sense to everyone)
I have come to realize that most C50's have door to fender issues. This is because there is only one center body mount in the front. This picture shows the suspension mounting system that will also support the body on either side directly above the spring mounts. This should take care of fender to door binding.
To the left of the picture below is the stock fender length and to the right is what I am cutting it down to.
Still fit and re-fit body on body off, body on body off, over and over. But I'm getting closer to the look I'm looking for.
These are NOT the tires that will be on it. This will have 16.5 deep dish hubcap wheels and about 38" tall mud terrain similar to the ones on my crewcab.
Old 06-22-2013, 02:10 PM   #14
c20chevy1972
sweet start
c20chevy1972 is offline   Reply With Quote
Old 06-22-2013, 05:13 PM   #15
Seatyger
Awesome Brother! Will be following you on this adventure!
Seatyger is offline   Reply With Quote
Old 06-22-2013, 08:08 PM   #16
Southern Shaker
haha that crew cabs gonna need like 54's to look right haha IMO
Old 06-26-2013, 12:26 PM   #17
atvpro
atvpro's Avatar
This is Drill Sergeant's frame modification all necessary to retro the C50 body to a C20 frame. Significant changes had to be made to the front of the frame, not only to support the cab properly but also to support the 4wd suspension better. After all this is also going to be pushing snow.
Old 06-26-2013, 12:30 PM   #18
atvpro
atvpro's Avatar
Floor Board Restoration
Old 07-04-2013, 02:46 PM   #19
jbclassix
Junk Yartist
jbclassix's Avatar
We need that man back
-Jeremy
Rebuilding an NP205
Old 07-04-2013, 04:34 PM   #20
atvpro
atvpro's Avatar
.....YES WE DO, and more like him......
Old 07-04-2013, 06:59 PM   #21
C10 - C90 Bill
C10 - C90 Bill's Avatar
Totally agree.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 07-05-2013, 12:11 PM   #22
atvpro
atvpro's Avatar
Small window to big window conversion
I was going to leave it a small window because I thought it would look good with the step side. There was so much roof damage, inner and outer, that I decided to go ahead and replace the whole thing with a roof that accepts a headliner, has the cargo light and is in really good shape. These pictures show the process of the conversion as well as installing a clearance light skin. Questions just ask.
Old 07-05-2013, 05:42 PM   #23
NONHOG
NONHOG's Avatar
Awesome! Subscribed.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 07-05-2013, 09:34 PM   #24
flashed
Post Whore
I wish you were working on my truck.
Old 07-06-2013, 12:43 PM   #25
Don Quixote
Good God, where do I find such a fabricator?
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
