Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-20-2013, 06:01 PM   #1
beetle1960
beetle1960's Avatar
all cluster ans dash lights out 70 c10
All my dash lights went out. Fuse checks out ok..park lamps work. Dome light works. Are there other fuses somewhere or do you think it is the headlight switch..I have wiggled it, turned it, etc. Nothin?
beetle1960 is offline   Reply With Quote
Old 08-22-2013, 06:31 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: all cluster ans dash lights out 70 c10
It sounds like you probably lost the ground connection.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 08-23-2013, 12:34 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Check the gray wire on the heater /AC panel and if you have 12 volts on it, to ground, then your dash cluster connections or the ground is definitely suspect.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-24-2013, 05:57 PM   #4
beetle1960
beetle1960's Avatar
no power to gray wire( I assumed your meaning the heater panel light), no power to the fuse at the fuse box for the lights. if I put a jumper to the lights fuse, they work. all other fuses have power. Thoughts?
Old 08-24-2013, 11:52 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Yes that's the one, If you have no power to the Pnl lights fuse then You are not getting power from the headlight switch. The power from the switch comes in the form of a dark green wire that is fed by the switch power through the variable resistor built into the switch and controlled by the knob ,
Turning the knob controls the amount of resistance in the green wire to current flow which controls the brightness of the dash bulbs. Either you aren't getting power to the resistor or you aren't getting power from it.
Looking closely at the diagram shows the dark green wire coming from the switch in the lower right corner and it runs to the fuse panel to the pnl lights fuse. in the second diagram. The third diagram shows a headlight switch for the post 68 trucks and you can see the green dash lights terminal.
trace the dark green wire to this diagram in the lower right corner where it goes to the Pnl Lights fuse. It's the top one in the bottom section just above the orange one.
Here's the headlight switch terminals.
Name:  Headlight Switch 1.jpg
VetteVet
Old 08-25-2013, 01:51 AM   #6
thelonerife
GMC's and VW's
thelonerife's Avatar
Mr. Vettevet, Thank you for your illustrations and help on this site. I have looked at a few of the threads that you've posted in and even saved a few for future reference. You are appreciated sir. Thanks again!
thelonerife is offline   Reply With Quote
Old 08-25-2013, 04:24 AM   #7
Sklptrljay
Sklptrljay's Avatar
Simple things first, try fiddling with the dash harness. mine did the same thing and was just not pushed in 100%.
Sklptrljay is offline   Reply With Quote
Old 08-25-2013, 09:13 AM   #8
beetle1960
beetle1960's Avatar
Yes thank you..! with this info, I can now trace out the problem.
Old 08-25-2013, 09:56 AM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
You guys are too kind. I do get a lot of satisfaction out of helping my fellow truck members. There are a lot of knowledgeable guys on this site and they have helped me out as well. VV
VetteVet
Old 08-30-2013, 07:18 AM   #10
beetle1960
beetle1960's Avatar
turned out to be a bad headlight switch..
1953 Chevy 3100
1964 Chevy Impala
1966 Chevy El Camino
1970 Chevy C10 Fleet Long
1972 Chevy C10 Step long
1985 Chevy K10 Fleet Short
Old 09-14-2014, 12:28 AM   #11
Triplebuckshot
Old thread I know but I have a related question that I could not find the answer to by searching.
Does the courtesy Ground need to be connected for everything to work (I understand that I would not have dome lights.
Also does it connect to say a battery of frame ground? I installed a full painless harness and as none of the rest of the harness supplied grounding wires and this wire was not supplied I am assuming it goes to a regular batery -- tyoe ground.
Triplebuckshot is offline   Reply With Quote
Old 05-29-2017, 07:15 PM   #12
jondancer
Great info
jondancer is offline   Reply With Quote
Old 04-28-2020, 06:46 PM   #13
Mr3Speed
Crazy that these threads are from 13, my fuse box isn’t even getting power to the cluster feed fuse. The headlights work as well as the brights. Which leads me to believe it’s a problem with the orange wire to the headlight switch or the dark green one for the cluster lights. No parking lights or done either
Mr3Speed is offline   Reply With Quote
Old 04-28-2020, 11:18 PM   #14
dmjlambert
dmjlambert's Avatar
There was a member here not long ago that figured out a kid or grandkid turned the headlight switch dimmer knob all the way down to off. Something to check. Also, the headlight switch could be bad, it has a rheostat in it to provide dimmed light power to the fuse.
dmjlambert is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
