Old 08-30-2013, 09:14 AM   #1
Oxmarqt
Oxmarqt's Avatar
My costs to get the '69 "Right and Reliable"
Boy it adds up quick! Still need to get the washers and left brake light working but at this point I would drive it 1000 miles round trip without batting an eye.
Just thought I would throw this out there although the prices from NAPA are at my cost not retail.
ebay - 1969 Chevrolet C10 = $5,000
ShiftRite - Transmissions - Tailshaft housing = $62
Jegs - Trans Kickdown Cable Bracket/lever - 510-20-121 = $22
Jegs - Trans Kickdown Bracket 700r4 510-20-95 = $22
Jegs - LOCKUP KIT FOR 200/700R4 890-376600 = $90
Transmission Center - Seals/Gear = $27
Creekside2 - ebay - Speedo housing/gears = $118
LMCTruck.com - WINDOW REGULATOR-RH - 38-6571 = $40
LMCTruck.com - WINDOW REGULATOR-LH - 38-6570 = $40
LMCTruck.com - LAP SEAT BELT-BLACK - 38-2249-BL = $50
LMCTruck.com - ESCUTCHEON DOOR/WINDOW-BLACK - 38-6527-BL = $8
LMCTruck.com - LIGHT WIRING KIT W/SWITCH A/R - 38-1275 = $13
LMCTruck.com - DOME LIGHT LENS-CLEAR - 36-4205 = $10
LMCTruck.com - SOCKET-TAIL LIGHT-RH - 36-3543 = $5
LMCTruck.com - LED LICENSE PLATE BOLT SET - 36-4506 = $15
LMCTruck.com - DUAL DRINK HOLDER-BLACK - 38-8200 = $30
LMCTruck.com - LARGE MACHINE SCREW-SS - 30-0411 = $8
LMCTruck.com - DOOR PANEL WASHER - 30-0748 = $8
LMCTruck.com - SHIFT INDICATOR DIAL-W/TILT - 32-7235 = $10
LMCTruck.com - DUAL VOICE COIL SPEAKER - 38-8564 = $70
LMCTruck.com - KICKPANEL SPEAKER SET - 38-8520 = $130
LMCTruck.com - LIGHTER ASSEMBLY - 38-5004 = $15
LMCTruck.com - WINDOW CHANNEL KIT-CUSTOM - 38-5620 = $80
LMCTruck.com - WINDOW HANDLE-CHROME KNOB - 38-6710 = $20
LMCTruck.com - GLOVE BOX - 38-5212 = $13
LMCTruck.com - GLOVE BOX LAMP ASSEMBLY - 36-4500 = $15
LMCTruck.com - DOOR WEATHERSTRIP SET - 38-5953 = $50
LMCTruck.com - INSIDE DOOR LATCH CONTROL-LH - 38-6564 = $15
LMCTruck.com - BUMPER-DOOR/FINGER GUARD A/R - 30-1820 = $2
LMCTruck.com - OIL PRESSURE SENDER TUBE KIT - 36-1923 = $17
Right Stuff Detailing - Frt Disc Brake conversion - TSD 6316 = $795
Craigslist - 700R4 transmission = $200
Wheel Medic - Wheel Repair/Center Caps = $400
GMCPauls.com - 69-72 Chevy Factory Service Manual - MAN2269 = $25
GMCPauls.com - 67-72 Chevy Wiring Diagram - SRW220278 = $5
GMCPauls.com - 67-72 Factory Assembly Manual - MAN5 = $40
Lonestar Car Parts - ebay - Dual Snorker Air Cleaner - CQ-W-460A = $207
Early Classic Enterprises - Shocks and relocator kit - 902-6372-SK = $209
Early Classic Enterprises - Round mirror - 06-18403C = $24
Early Classic Enterprises - Tach kit - 05-7780 = $269
dbleggi79 - ebay - Guages Cluster = $170
NAPA - Brake light switch - SL186 = $11
NAPA - Transmission filter kit - 17936 = $13
NAPA - Front transmission seal - 17458 = $4
NAPA - O-ring - 17154 = $1
NAPA - Radiator cap - 7031697 = $5
NAPA - Upper radiator hose - 7368 = $13
NAPA - Headlight pigtail - LS6479 = $4
NAPA - Wire loom clip - 784287 = $10
NAPA - Wire loom clip - 78428 = $10
NAPA - Alternator belt - 257450 = $17
NAPA - Lower radiator hose - 7352 = $34
Aarow Radiator - Radiator repair = $60
Total = $8,514
1969 Cheverolet C10 Custom
Monza Red
350/700r4/3.73
28" tires
Oxmarqt is offline   Reply With Quote
Old 08-30-2013, 10:48 AM   #2
big mike71
big mike71's Avatar
Re: My costs to get the '69 "Right and Reliable"
Well, Where are pictures so we can see what it all looks like?
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 08-30-2013, 11:00 AM   #3
Keating121
Keating121's Avatar
Did you do the work yourself? How many hours of labor??
8/24/13 First Classic Truck
'67 Short Fleetside, Candy Apple Red! 350ci, Holly 750 double pumper (too much, will change soon), Headers with FlowMaster exhaust, 700R4 tranny.
Keating121 is offline   Reply With Quote
Old 08-30-2013, 11:00 AM   #4
TacBlade
I know what you mean!!! I just put $11,000 into my motor, tranny and rearend on my $5000.00 budget!!!
TacBlade is offline   Reply With Quote
Old 08-30-2013, 12:20 PM   #5
MidLifer
MidLifer's Avatar
Shared misery is always the best - I stopped totaling after a while. Now I just toss receipts into a folder.
Not to take the thread in another direction, but you mentioned you haven't gotten the washers working yet - after fighting with the mechanical pump for months, a few rebuilds, etc, I finally gave in and got a universal electric pump. I made a mounting bracket out of sheet metal that enabled me to mount it on the wiper motor, based on a thread on this board that I now cannot find to repost, but I can post pics if needed.
Works differently than the mechanical one (you have to hold the button in to keep it spraying) but it works, which I never could get the mechanical pump to do.
MidLifer is offline   Reply With Quote
Old 08-30-2013, 12:25 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It's getting ridiculous nowadays what stuff costs.
I've got a saying I use.....
"I can take a running truck, pull the engine out and set it on the ground and then drop it right back into the truck, and it will cost 100 bucks minimum, and that's not doing anything other than r&r".
Antifreeze, a hose clamp or two, electrical terminal, maybe some exhaust donuts. You can just vaporize money and not feel like you've done anything at all.
I quit counting long ago. It's still cheaper than liquor and hookers I guess.
Old 08-30-2013, 12:50 PM   #7
asolde
asolde's Avatar
Glad Im not the only one, I just put the receipts in the drawer now. I quit counting at around $7800.
asolde is offline   Reply With Quote
Old 08-30-2013, 12:52 PM   #8
MidLifer
MidLifer's Avatar
The best part is that when you sell your truck, you'll get it all back - NOT!
Old 08-30-2013, 01:33 PM   #9
Oxmarqt
Oxmarqt's Avatar
Labor was 90% done by yours truly and the rest by some of my employees. Not sure how long I spent since it was all done a little at a time over the last 4ish weeks. I have access to a twin post lift so none of it was that difficult. The worst part was waiting for parts to arrive.
I have always had an unwritten rule that you should plan on spending half of the purchase price to get it right. Of course this doesn't work in all cases but is a nice rule of thumb if you are buying something decent without any major issues.
My "other" ride is a 1977 Jeep CJ7 (304ci, automatic, full-time 4wd). That one got a bit out of hand so I just throw the receipts away and pretend I am not buying stuff for it.
I consider everything on the list to be necessary for safety/travel comfort. When I own something older it has to be able to go 7-10 hr round trip, without any preventable issues, before I am happy. The only thing that is fluff is the air cleaner. Dual snorkels just look cool!!
I need to wash it and then I can take some pictures. Maybe I can convince the wife to bust out the bathing suit for a photo shoot.
Monza Red
350/700r4/3.73
28" tires
Old 08-30-2013, 02:00 PM   #10
Mister-B
You're still half the cost of a new Kia, and you've got a vehicle you can be proud to be seen in, isn't disposable, and can only go up in value if you take care of it.
As others have said, please post pics of the truck. I'm partial to '69 trucks myself
As for the bikini pics, yes please. But, be forewarned... one of the puritans on the site may flag your post, and it'll get deleted. So, PM them to me first lol.
Mister-B is offline   Reply With Quote
Old 08-30-2013, 02:16 PM   #11
kcsa75
Forum Staff
kcsa75's Avatar
This reminds of when I was a kid and used to count how many beers I drank so I could brag to my friends. Then one day somebody said something how much money I was spending and that was the end of that
With my truck, unless its something I know I may have to return, receipts get thrown on the dresser until the wife throws them away.
Willie
Swamp Angel Truckers
'72 C10 Highlander
2009 Ford F-150 XLT
2004 Ford Explorer XLT
1998 Cadillac DeVille d'Elegance
If Money can't buy Happiness, Explain Hot Rods and Beer.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
kcsa75 is offline   Reply With Quote
Old 08-30-2013, 02:41 PM   #12
JOJABOY
If you are doing it as an investment, you're doing it for the wrong reason. Very few cars will appreciate in value. But hey.....You've gotta have a hobby.
JOJABOY is offline   Reply With Quote
Old 08-30-2013, 03:27 PM   #13
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[size=1
Posted via Mobile Device[/size]
I think you may be wrong on that. But Im guessing of course
Tom Vogel is offline   Reply With Quote
Old 08-30-2013, 03:41 PM   #14
70blackfish
try rebuilding a mopar....3x the price and harder to find parts
69 GMC SWB
70blackfish is offline   Reply With Quote
Old 08-30-2013, 03:52 PM   #15
CC69Rat
CC69Rat's Avatar
IMO, it's all about building the truck but not building yourself into a hole if that makes sense. Buy it cheap, make it look appealing.. Do it right (not saying cut corners) but watch the budget to the point you dont put more into it than it would be worth to someone else. If you plan to keep it, then .. well. Go for it. But if there's an 'itch to build again you have to be careful where you put the money. The right money in the right places will bring a profit. Having the know how and doing what you can on your own (to me) is more valuable than having a fat checkbook to pay someone else to do it.
Just my .02 Watch what you spend, absolutely but watch where you spend it is equally important.
Chad
1968 C10 SWB - 50th Anniversary Tribute Project http://67-72chevytrucks.com/vboard/s...d.php?t=444414
2017 Jeep Wrangler Rubicon (daily)
2001 Jeep Cherokee XJ
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 08-30-2013, 04:21 PM   #16
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I've never kept receipts.I figure I got in it what I got in it.I don't need to know and Ole'what's'er name sure don't need to know.I enjoy the tinkering and building along with the driveable project.I enjoy the people in the Hobby(the ones here most of all) and I figure I'll spend what I spend and if I sell I'll get what I get but I wont have any regrets.I'm almost to the same attitude with my 401 K.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-30-2013, 05:51 PM   #17
Eddie H.
Eddie H.'s Avatar
If I had all the money I put into old cars and trucks over the years, I would be financially better off for sure, but what good is money if you can't spend some of it doing what you enjoy?
I would rather live my life and enjoy the ride along the way, than scrimp and save every penny just so that my kids will have a lot of money to fight over after I'm gone.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 08-30-2013, 06:01 PM   #18
71sierragrande
Petroleum User
71sierragrande's Avatar
A sweet old chevy for under 9 grand sounds like a great deal to me, good job.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 08-30-2013, 07:23 PM   #19
tlcrz1972
tlcrz1972's Avatar
I''m right there with all of you, I know it is an expensive past time. I do enjoy doing it, and will build more.
Now on the part about putting more in it than it's worth, that is so true. But what just bumfuzzels the heck out of me is I have seen to many threads about so called low mileage survivors, and of course some of them had the patina thing going on with them. And some of them are so plain jane (that I fall asleep just looking at them), no power nothing, bottom of the line trucks that people will buy outright for way to much money. What gives with that? They are buying a truck that IMO will need a whole lot of money thrown at them to make them reliable drivers, instead of going out and finding one already on the road to recovery that someone has done all the hard work on and what is left is the easy part.
tlcrz1972 is offline   Reply With Quote
Old 08-30-2013, 07:33 PM   #20
ItsRandy
ItsRandy's Avatar
You're supposed to add the receipts up so you know how much you spent? You guys are way more brave then I am. When I do a little quick math I find I have spent a bit north of 30k on a 20k budget and the truck isn't completely finished yet. I have been driving it for about the last 14-16 months or so and I did do everything except the interior my self so I was able to save some money there.
Do I get to deduct the money I made with the truck for the 27 years I used the truck for work before I lost my mind and decided I wanted a "Hot Rod"? If I do then I think I'm ahead of the game...by about $6.
ItsRandy is offline   Reply With Quote
Old 08-30-2013, 08:26 PM   #21
Hawghauler
Hawghauler's Avatar
I have a great big pile of receipts that I haven't looked at since the piling began. I think they are worth something if some jack wipe decides to rearrange my sheet metal. I can show them all to the insurance guy and hope to get more than $900 bucks for it. Then buy it back for pennies on the dollar and take all the good stuff off for the new build. I should have bought one already restored, but what's the fun in that. Plus I don't trust other people's idea of restored. It's already over 40 years old, and full of po's crap repairs. When I'm done, I'll have something I dig, and will last decades. I don't want to even think about having to buy a new vehicle to replace the p.o.s. I bought new 5 years ago, because it's all worn out already. Plus try finding an 8' bed these days!
If I have to be on 4 wheels, It has to be a classic Chevy
1967 c10 Longbed (Hawghauler/Icy weather transport)
2003 BMW K1200GT (Rain bike)
2007 Softail Deuce (Sun bike)
2009 Ultra Classic Electra Glide (Everything else bike)
Hawghauler is offline   Reply With Quote
Old 08-31-2013, 06:23 AM   #22
Oxmarqt
Oxmarqt's Avatar
Lot's of good comments/opinions!! I keep track because if I didn't thing would get out of control quick. I have a known problem with "While I'm in there/it's apart fever"..
There was a picture request so.....
These are a few pics of where most of the work gets done. I usually have to go on the weekends since we are closed Sat. & Sun. I am very fortunate because if I don't finish something OR get jammed up and need help I can just leave it, take a shop truck home, and finish it when we reopen on Monday.
Main shop:
Other shop:
Monza Red
350/700r4/3.73
28" tires
Old 08-31-2013, 09:02 AM   #23
yuccales
yuccales's Avatar
Oxmarqt, that's a very nice looking truck.
yuccales is offline   Reply With Quote
Old 08-31-2013, 09:12 AM   #24
stexag
Whenever possible on what a 'hobby' costs (my truck is not a DD) I go with the 'head in the sand approach'. I never want to know what it costs - or I probably wouldn't do it!!! One of the biggest shockers to me was a few years ago when my wife started keeping books on the computer and categorizing expenses. Now the totals are just a keystroke away.
She'd asks "You know how much you spend on the boat?? Your old truck??? The kid's 4-H animals???"" NO NO NO! don't want to know! Ha ha. Good on you for being able to keep an accounting and share it!
stexag is offline   Reply With Quote
Old 08-31-2013, 09:13 AM   #25
stexag
Truck is beautiful too. Well done.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
