09-08-2013, 06:08 PM | #1 |
No Limit Wide Ride install by Smittys
Ok as many of you have seen our Red Race Truck. We have reached the limits of the front suspension. I need more front tire, ground clearance and better geometry.
So we are making the change to the Wide Ride a couple things to point out. It has great geometry great camber gain and very little bump steer. It is priced well $2700. I priced a complete rebuild of stock parts for a comparison $1580 just for the parts. I am sure Rob will chime in here but I took some pics to show it being installed. Ugly stock stuff just for reference. New cross member bolted in. We have the engine moved back and down so we had to make new engine mounts. I am still a trucker at heart so yes we are still racing on air. These are Ride Techs awesome triple adjustable shockwaves!! |
09-08-2013, 06:13 PM | #2 |
Re: No Limit Wide Ride install by Smittys
Notice right above the engine mount is a notch for the steering shaft depending on the rack you use you have to check for clearance.
The alignment is made simple with the camber/caster concentric used to mount the upper arm. This make for quick easy alignment changes. Upper arm installed. Lower arm installed notice the amount of room for tires. |
09-08-2013, 06:18 PM | #3 |
I chose to run a Flaming River Billet Rack. This is a upgrade that is available.
Some pics of the front end together. Note the steering shaft location to the column. |
09-08-2013, 06:21 PM | #4 |
Ride height sensor location.
Just a little clearance. |
09-08-2013, 10:24 PM | #5 |
What hood hinges are those man? Your laid out and they still clear the tires.
Truck looks killer man. Posted via Mobile Device
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
09-08-2013, 10:27 PM | #6 |
Awesome truck! Rob is a real cool guy and makes a great product
Posted via Mobile Device |
09-09-2013, 01:32 AM | #7 |
truck looks sweet !! should handle awesome . the hood hinges look like Eddie Motorsports.
09-09-2013, 02:00 AM | #8 |
very NICE
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
09-09-2013, 07:43 AM | #9 |
The hinges are Ring Brothers pm me if anyone needs a set.
09-24-2013, 08:10 PM | #10 |
Performance update... we ended up with 315 front tires on it. Off to indy we went after a few shock setting changes a couple calls to Rob we have a pretty good base line setup. This setup kicks a.... the turn in is great and it rotates incredible. We ran a 57.8 which was good enough for 8th out of 18 pro class cars.
Here is a link to video https://www.facebook.com/photo.php?v...type=2&theater |
09-24-2013, 08:43 PM | #11 |
I saw you at Good Guys on Sat and didn't realize you were on this forum. Your truck ROCKS !!! Nice run
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
09-24-2013, 08:44 PM | #12 |
double post ... Hmmmm ...
09-24-2013, 11:39 PM | #13 |
Watched the video, great run, truck is super...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-25-2013, 12:08 AM | #14 | |
Where did you get those engine mounts? |
09-25-2013, 02:48 AM | #15 |
Sounds nice and nasty too.
09-25-2013, 07:54 AM | #16 |
I made the engine mounts because the engine is set back a lot. The kit comes with a mount with it.
09-28-2013, 12:20 PM | #17 |
I am in the mood to help the truck guys out. For everyone who wants to upgrade the suspension on there trucks I will give 10% off your No-Limit orders Through Nov 1st. They now also include RideTech shocks now.
09-29-2013, 01:25 PM | #18 |
Your truck looks awesome Chris.
Scott |
09-29-2013, 03:24 PM | #19 |
I really wish I didn't paint my frame black now.
09-29-2013, 05:40 PM | #20 |
Any pictures at ride height?
Anthony '67 Shortstep (555/T56) '67 Parts Truck (TBA) |
09-29-2013, 06:00 PM | #21 |
There are a couple pics and video on our facebook. I will try to take some this weekend.
09-30-2013, 10:47 AM | #22 |
Another question I haven't seen, but are you running the C10 version that utilizes C10 spindles or the 2nd Gen Camaro version?
09-30-2013, 11:42 AM | #23 |
We only make the Wide Ride with one spindle, and that is our Impalla based ZG spindle. We do make our own rotors for those. They are all 12" drilled and slotted with 1/2" screw in studs, and we have any bolt pattern, 4 1/2", 4 3/4", 5" and 5 x 5 1/2". We also make our own billit aluminum hubs for bigger brakes. In these we can offer the 6 x 5 1/2" pattern. They can be built with 13" or 14" rotors, and 4 or 6 piston calipers. Also, any Baer or Wilwood kit that fits a '79-'81 Camaro or '92-'96 Impalla will fit.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
09-30-2013, 04:19 PM | #24 |
Does Chris's have the drop spindles or std. spindle?
09-30-2013, 04:41 PM | #25 |
They only use one spindle the Impala Spindle that is made for the kit. So its not a drop spindle.
Thread Tools | |
Display Modes | |
