Old 09-26-2013, 08:49 PM   #1
DexterDog
DexterDog's Avatar
No bed, no problem 64'
I'm not the type to document everything done, and or the process of procedure on my rides...But It's always fun to keep tabs on progress and share.
After finishing my '46 Chevy truck, moving onto a '32 I never finished, and taking over a 63' 3 door build I missed having something fun. A good friend picked this up a few years back with the best intentions in mind...After a year and a half of it never running right, and issues including the original bed falling off(while driving) I took it upon myself to rescue it.
1964 long bed 283 3speed 2wd base model (I would guess).
I picked it up knowing it ran like ish, but it ran, and drove 100 miles. Not a single issue...Until I pulled into my shop and the fuel pump exploded, front oil seal gave out, valve cover gasket took a poop, and brakes sank to the floor. But it made it.
The Truck was stock, I found nothing molested or really touched minus the addition of HEI and some small upgrades so I found changing some of the original patina and coolness hard to do. I freshened up the engine(cam had six flat lobes....no wonder it ran like ish), new cam(444/466-298) lifters, pushrods, rockers, re sealed, flushed and carbon cleaned, rebuilt 1406 carb, ram horns ,exhaust, suspension, brakes(still 4wheel drum but they work!) de-greased everything and por15 and re sprayed frame and under body, mounts and bushings, stained the bed with vinegar steel wool and coffee, new wiring, shocks, rear drop springs, front springs minus a coil or so, whitewalls and some spray paint....oh and removed a lot of bad rattle can rustolium...
Plans are eventually....power disk brakes, bag it and twin 15.5 keg gas tanks. That's about it, I really don't think it needs much else. I love driving it almost everyday to work, rides like a Cadillac and sounds it means business. I just wish there was easier way to fit my two Great Danes in the cab.
DexterDog is offline   Reply With Quote
Old 09-27-2013, 02:47 PM   #2
1963c-10
Post Whore
1963c-10's Avatar
Re: No bed, no problem 64'
Very cool truck....I'll be watching the build for new updates.....and welcome to the forum.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-27-2013, 03:45 PM   #3
TJ's Chevy
Chevy I6 and GMC V6 Nut
TJ's Chevy's Avatar
Nice rig! And welcome! X2 on the updates!
"6 in a row makes it go!"
"I prefer a buzzin half-dozen"
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-27-2013, 05:34 PM   #4
ChevyFreak60
ChevyFreak60's Avatar
Cool looking truck!
1960 Chevy Stepside 2wd
1966 Chevy Fleetside 2wd
1965 Chevy Suburban 2wd
1965 Chevy Fleetside 4X4
1960 Chevy Fleetside BBW 2wd
ChevyFreak60 is offline   Reply With Quote
Old 01-25-2014, 07:36 PM   #5
DexterDog
DexterDog's Avatar
Freshened up the engine bay, and when doing so did some research on the heads that came on my little 283. Corvette power pack heads! Now just to clean the block and run the numbers to see if it matches the heads.
Old 05-16-2014, 07:06 PM   #6
DexterDog
DexterDog's Avatar
Simple update, new exhaust and re jetted 1406. 2.5 inch dual from the corvette manifolds back to a pair of FLowtech chamber mufflers. Rebuild/Retuned/Rejetted 1406.
Started to clear parts of the truck here and there.
And I've been fighting to get a Flickr video on here for 30 minutes...But I give up. I'll attempt it later.
Old 05-16-2014, 08:17 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Truck is looking good! Nice rusttina!
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
