Old 10-17-2013, 01:35 AM   #1
overtimeracing
overtimeracing's Avatar
Tranny Crossmember
Hey guys...I've been looking for a thread on this already, but cant seem to find one. For those that know me, know that I had recently built an 87 Trazer with my son. He took that truck back to Camp Lejeune with him, and the day he left, I lost all interest in the 63 Trazer I was building for myself. It is currently for sale. But I couldn't take it! I went out a bought a 65 c10, 6cly, three on the tree, short box. I will be installing a small block and either a th350 or a 200r4. There are 3 crossmembers. Engine, tranny, and parking brake mounting. Do I cut out the second crossmember? Do I use a crossmember from a 73-87 2wd, and if so, what do I do with the parking brake crossmember? I would like to keep the parking brakes. Thanks for all your help!! Kevin
Why...Why...Why...Can't I leave anything alone???
overtimeracing is offline   Reply With Quote
Old 10-17-2013, 10:16 AM   #2
kieth
kieth's Avatar
Re: Tranny Crossmember
I would try and convert it to 66 e brake cable, this will make it a lot simpler when you are moving things around. ? why a 200r4, the 700r4 would be easier to find and simpler to rebuild and give you a lower 1st gear ratio ?
Kieth
here is a picture of the 66 e brake set up, it eliminates the attachment to the crossmember:
http://kieth.smugmug.com/Trucks/66-G...7236&k=v4Rpz77
Here is another shot:
http://kieth.smugmug.com/Trucks/66-G...4536&k=Kd8Z3KK
kieth is offline   Reply With Quote
Old 10-17-2013, 10:53 AM   #3
padresag
there is also the stock 66 a/t crossmember which has the emerg hook-up
which I have
ron
padresag is offline   Reply With Quote
Old 10-18-2013, 01:43 AM   #4
overtimeracing
Thanks for the replies! The old crossmember bolted to the tranny closer to the bell housing. This one needs to be removed, correct?
Old 10-18-2013, 01:45 AM   #5
overtimeracing
Kieth
I had read that the 200 was an easier replacement for the th350. I will be running a 400 sbc but not a lot of HP as this will be a daily driver.
Old 10-18-2013, 09:28 AM   #6
kieth
kieth's Avatar
The 200r4 is much harder to find, and more expensive to rebuild. I went with the 700r4 had to install a new trans crossmember ($100.00) but my truck is a 66 so my ebrake cable was the style I showed you in the pictures. the driveline had to be shortened about 1.25" to work with the 700......what rear axle ratio do you have and what height are the tires (diameter), what engine ? PM me your email address and I will send you a excell spreadsheet that shows how your truck performs now (speed and torquej) and also after you change the transmission (so your truck does not fall on its face.......Kieth
Old 10-18-2013, 11:19 PM   #7
Captainfab
60-66 Nut
When converting to an auto trans, the bellhousing crossmember does need to be removed. If you can not find a '63-'65 auto trans crossmember, you can use a '66-'87 auto trans crossmember. The easiest way to deal with the e-brake cables is to convert to the '66-'72 style, as was already mentioned.
Old 10-21-2013, 02:36 AM   #8
overtimeracing
Ok...Thanks guys...So what needs replaced/saved from my present e brake set up? And does anybody have the parts available, either new or used for sale?
Old 10-21-2013, 02:39 AM   #9
overtimeracing
Thanks Kieth! Im not sure what gears are in the rear yet. I've only owned the truck for a week, and needed to get busy pulling motor/tranny as PO already had it sold. I get back to you asap! Thanks...Kevin
Old 10-21-2013, 09:55 AM   #10
Branman1971
Branman1971's Avatar
Im glad you posted this. My 61 has a TH350 tranny, and the forward crossmember is a support bracket that is nothing more than a rigged up piece of thin steel that is bolted to the frame. So I can use a cross member out of a 66-87 pickup? There is also a crossmember under the tailshaft of the tranny that I think might be original but they have U-bolted a block of wood between the tailshaft and the crossmember to support it. This rear-most crossmember has a cut-out on the bottom that looks like the original tailshaft went underneath it. I will try to post a picture tonight.
Active duty Navy CPO
1961 C10 SWB
1963 C10 LWB (donor)
1965 C10 LWB BBW
Branman1971 is offline   Reply With Quote
Old 10-22-2013, 12:52 AM   #11
Captainfab
60-66 Nut
You can not just bolt in a trans crossmember from a '63-'87 pickup into a '60-'62 frame. The frames are totally different. Unless you get lucky enough to find an original '60-'62 auto trans crossmember, one will need to be fabricated. What you are describing doesn't even sound safe.
Old 10-22-2013, 08:09 AM   #12
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
branman1971,
take a read at this, might help you get yours together...
http://67-72chevytrucks.com/vboard/s...d.php?t=367487
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-23-2013, 11:59 PM   #13
overtimeracing
Hey guys...looks like Im gonna pick up a 73-87 tranny cross member from the yard. What is different between my current e brake and the 66 set up? What can I keep/need to swap? Thanks again...Kevin
Old 10-24-2013, 12:34 AM   #14
Captainfab
60-66 Nut
The '66-'72 e-brake cable assembly does not use a crossmember with a lever as the '60-'65's did. It consists mainly of just cables, a rod on the passenger side, and a couple hooks. I believe there is a link in the '60-'66 FAQ index to a thread that shows how to make the conversion.
Old 10-24-2013, 12:39 AM   #15
overtimeracing
Sweet! Thanks Capt!
Old 10-24-2013, 09:53 PM   #16
Branman1971
Here's my nightmare!
1961 C10 SWB
1965 C10 LWB BBW
Old 10-24-2013, 10:32 PM   #17
Reyals Bemus
The horror!!
Reyals Bemus is offline   Reply With Quote
Old 10-24-2013, 11:32 PM   #18
jtrichard
couple 2x4s some bailing wire and 2 twelve packs should not be a problem LOL GOOD LUCK you have your hands full
jtrichard is offline   Reply With Quote
Old 10-24-2013, 11:33 PM   #19
overtimeracing
Someones been playing with their erector set?
Old 10-24-2013, 11:35 PM   #20
jtrichard
erector set might be an improvement
Old 10-25-2013, 12:07 AM   #21
Branman1971
Erector set is right. And notice the rounded Ubolt in the rear for tail shaft? That's a block of wood in there to take up space. Genious!
1961 C10 SWB
1965 C10 LWB BBW
Old 10-25-2013, 10:55 PM   #22
overtimeracing
Amazing...
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
