Old 10-18-2013, 12:11 PM   #1
mvitale27
mvitale27's Avatar
56 3600 SBC/4WD Trans Question
Hey guys,
I have a 383 stroker I built from a 73 vette's 350. I am going to do a 4WD conversion on my truck and I already have an np205 transfer case. I will most likely be running Dana 44 in the front and corporate 12 in the rear. 383 will be putting out about 400 hp and 450 ft lbs of torque.
I am looking for a 5-speed manual w/ overdrive. I heard good things about the NV4500 and I know it hooks up with the SBC and np205, but I also believe it is a low-geared slow-shifting truck tranny? Mainly this truck is going to be powerful, the 4WD conversion is only for snowy winters. I need the overdrive for 3 hours of daily highway/country road commuting and I would like a sportier transmission. I was looking for more of something like the Tremec TKO, but I don't believe it will work with the np205.
Any ideas?
1956 Chevy 3600
Matt's 3/4T 4X4 Build
mvitale27 is offline   Reply With Quote
Old 10-18-2013, 12:54 PM   #2
rgunlock
rgunlock's Avatar
Re: 56 3600 SBC/4WD Trans Question
I have a NV4500 I plan to pair up with NP205 on my build, but since it is a long way from running I can't speak to how it will drive. You may get more responses posting in the 4x4 subforum.
Rick
78 GMC SWB 4wd Project Fish Tremble
59 Chevy SWB Stepside (next in line)
rgunlock is offline   Reply With Quote
Old 10-18-2013, 02:08 PM   #3
mvitale27
mvitale27's Avatar
Thanks. I will repost over there and see if I have better luck.
1956 Chevy 3600
Old 11-11-2013, 03:36 PM   #4
mvitale27
mvitale27's Avatar
I have decided to go with a TKO 500 trans. I will be using a divorced np205 from a dodge truck. Now my only question is a crossmember for the transmission. The PO must have cut out the old trans crossmember as it is missing from my truck. Anyone know where I can get a bolt-on or weld-on trans crossmember thats compatible with the Tremec transmission?
1956 Chevy 3600
Old 11-11-2013, 10:15 PM   #5
_Ogre
_Ogre's Avatar
make it. x-members are the easiest thing to fabricate.
your going to ba fabricating all sorts of stuff for a build like this.
why buy when you can make?
photosuckit fix for chrome
Old 11-12-2013, 10:54 AM   #6
mvitale27
mvitale27's Avatar
Good advice. I will be doing a bunch of fabrication, I just figure I would see if anything was out there.
1956 Chevy 3600
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
