Old 10-21-2013, 01:31 PM   #1
ls1man
ls1man's Avatar
frame mount brake booster???
What are u guys using for your frame mounted brake booster, kit or other used setups
50 chevy pickup
ls1man is offline   Reply With Quote
Old 10-21-2013, 03:01 PM   #2
Highsider
Highsider's Avatar
Re: frame mount brake booster???
Maybe these treads will get you started:
http://67-72chevytrucks.com/vboard/s...d.php?t=523434
http://67-72chevytrucks.com/vboard/s...d.php?t=509875
http://67-72chevytrucks.com/vboard/s...d.php?t=354599
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 10-23-2013, 01:23 AM   #3
JumboAMONGus
JumboAMONGus's Avatar
i got the booster and mastercylinder with the brackets on ebay for 159 , been using it for 3 years works great , i dont even have the power booster hooked up ,
JumboAMONGus is offline   Reply With Quote
Old 10-23-2013, 12:30 PM   #4
_Ogre
_Ogre's Avatar
seeing as you just joined; you should read some of the build threads on this site.
many of us have done what your asking, all documented in the build threads.
shop air compressor timer
Old 12-04-2013, 09:13 PM   #5
1958Warrior
1958Warrior's Avatar
I'm going to bring this thread back up instead of creating a new thread for the same ?
I have came across a new frame mount power brake set up minus the booster for cheap (like me).
Most all the builds I've seen every one orders a complete kit in a box. Is there an off the shelf booster and/or M/C -donor replacement that works for the frame mount kit?
I've got the donor Camaro firewall brake set up and pedal, I'd like to keep the firewall clean after filling in all the holes and shaving the lip on my clipped 58 .
1958Warrior is offline   Reply With Quote
Old 12-05-2013, 02:27 PM   #6
OrrieG
OrrieG's Avatar
I used the 74 MC and prop valve from the donor truck, an after market 8" booster and fabbed the brackets myself. That allowed me to move it further back on the frame so the access door was behind the cab brace and radius the bracket to match the booster for better look (yeah I know no one will see it but it mattered to me). I also tucked it closed to the frame for more clearance at the transfer/trans. I used the stock pedal. In the photos the tubing coils are vertical, I ended up rotating them horizontal because they will not bleed coiled vertically. Details are in my build thread towards the start.
OrrieG is offline   Reply With Quote
Old 12-05-2013, 03:18 PM   #7
1958Warrior
Thanks OrrieG, Do you know what a good donor for the booster would be ?
I was trying to find a booster from a newer vehicle to use from a wreaking yard I've seen someone had used a MustangII booster before but not sure on the year, but not very many of those around. Just not sure if a ford booster will work on a chevy M/C.
The bracket assembly I was looking at is from speedway:
http://www.speedwaymotors.com/1955-1...edal,9343.html
Just trying to find out what booster and M/C would work with it that I could find easily when I need to replace them .
I'm not quite there to the point of running the brake lines yet, just trying to gather the parts, but its not far down on my list.
Old 12-05-2013, 08:53 PM   #8
blue57
blue57's Avatar
booster and master mounted under cab with a remote res. all CPP products
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=522711
blue57 is offline   Reply With Quote
Old 12-05-2013, 09:22 PM   #9
OrrieG
OrrieG's Avatar
I think I got it from POL or CPP. It is a standard hot rod 8" for use with a GM master cylinder. Use an old MC like for mock up. It was one of the first things I did and two died from sitting and not getting the seals exercised (started leaking and would not seal back up) Now at least two times a week I go out and pump the pedal a dozen times.
Old 12-05-2013, 09:25 PM   #10
apache200
apache200's Avatar
58Warrior could you use the stock brake arm with that setup? Has anyone else used the speedway bracket? Also i think some of the newer vettes use a 7 or 8 inch master and booster
1958 Chevy Apache Stepside
1955 BBW Fleetside
apache200 is offline   Reply With Quote
Old 12-05-2013, 11:48 PM   #11
1958Warrior
apache200
I don't know if I can use my stock arm with it, It comes with a new arm so that is what I'd use if I can.
Blue57
I'm aware of the brake" kit in a box" kits available not looking to charge up the card ,and want to be able to get replacement parts local,.. I thought I mentioned I'm cheap
I like the remote reservoir too, I saw Ogre's build where he added it.
OrrieG
I'll search the bone yards to see what can find when the weather permits, may have to adapt and fab something up also.
Old 12-05-2013, 11:54 PM   #12
1958Warrior
LS1man
Hope this also helps you and others with the same question, did you find anything else out I know yours is a 50 chevy ,are you also running disc/drum
Old 12-05-2013, 11:56 PM   #13
_Ogre
_Ogre's Avatar
most of the under floor boosters are 7 inch
Old 12-06-2013, 01:48 AM   #14
yossarian19
I used the 55-59 version, as I have a '57, but check this one out.
I like mine just fine, especially for the money.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
