Old 10-30-2013, 06:15 PM   #1
rs74
rs74's Avatar
Blower motor upgrade
Alot of you may already know about this but I just came across it today. Supposedly if you take a blower motor and fan for a 94 Chevy truck and put it in a square with air that it blows alot more air. Somebody on FB was saying something about it then posted a link. So here it is. Something to look into.
http://forum.73-87chevytrucks.com/sm...&topic=19365.0
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1993 RCSB stepper
1991 Z71 Short Bed
2007.5 Duramax
rs74 is offline   Reply With Quote
Old 10-30-2013, 09:04 PM   #2
Rubble
Rubble's Avatar
Re: Blower motor upgrade
Replacing your old blower motor with a new stock one will make a big difference.I just did this in my crew.Also on my crew,most of the a/c stuff is long gone,so I pulled the evaporator core out of the heater-a/c box when I was replacing the heater cire& this really helped with air flow too.
1985 GMC K35 454/465/205 Dually
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
1983 Chev C20 350/700R
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 10-30-2013, 09:30 PM   #3
Rascal_one2001
Rascal_one2001's Avatar
nice mine has been getting weaker and weaker I guess I know what I am going to replace it with.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 10-30-2013, 10:40 PM   #4
rs74
rs74's Avatar
I guess it is supposed to spin alot faster than what ours call for.
Roy
1993 RCSB stepper
1991 Z71 Short Bed
2007.5 Duramax
Old 10-30-2013, 11:41 PM   #5
Edahall
It's the same size motor. If you old one is still good, you can just lube the bearings and it'll run just like the new ones.
1990 ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 10-31-2013, 10:04 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
check the connections too,try adding a ground wire see if it gets better
take the blower out,clean out the "hampster wheel" mice may even have used it's space for nesting
John http://www.youtube.com/user/TheMotornut
1978 Suburban4X2-hit while parked RIPzez
1978 GMCJimmy4X4-350/203http://67-72chevytrucks.com/vboard/s...=421767&page=4
1979 GMCJimmy4X2-305/350http://67-72chevytrucks.com/vboard/s...=1#post5200107
1987 Suburban4X4-writeoff hit while parked RIPzez
1988 Suburban4X4-writeoff hit while parked RIPzez
1989 Suburban4X2 - square igloo/SOLD
2002 Fleetwood
2005 Malibu hit by City bus,2nd time a write-off(01/15/16)
2010 Dodge Van-writeoff hit while parked(01/14/15)
Now I just buy shorter trucks!
Love em low,but get me higher
motornut is offline   Reply With Quote
Old 10-31-2013, 12:14 PM   #7
85/Silverado
85/Silverado's Avatar
Do you mean a work-out-area.
85/Silverado is offline   Reply With Quote
Old 10-31-2013, 02:45 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
yup, lol
2002 Fleetwood
Old 10-31-2013, 08:39 PM   #9
Sabaka454
Sabaka454's Avatar
Did you happen to catch this post?
This is not an upgrade, they're the same motor
1978 C10 with AC part # 35334 is the same as 1994 C10 with AC part # 35334
Sorry to burst the bubble
Sabaka454 is offline   Reply With Quote
Old 10-31-2013, 08:47 PM   #10
rs74
rs74's Avatar
Why yes I did. I looked on O'reillys site for a motor for an 85 and one for 94. They were two different part numbers. They were not AC parts brand though.
Roy
1993 RCSB stepper
1991 Z71 Short Bed
2007.5 Duramax
Old 10-31-2013, 11:35 PM   #11
SkinnyG
SkinnyG's Avatar
We had a similar thread here a while back on the same thing. http://67-72chevytrucks.com/vboard/s...d.php?t=593977 I had made the bold but cryptic statement that the perceived improvement was merely a result of "new" being better condition than the "old" fan it was replacing.
Nostrildamus - 1961 Apache, soon to go under the knife
The Crusty Chevy - 1977 Silverado, shortboxed & dropped, potato-potato.
SkinnyG is online now   Reply With Quote
Old 11-01-2013, 01:37 AM   #12
Rubble
Rubble's Avatar
Pretty much what I said too......
Old 11-01-2013, 11:14 AM   #13
bnoon
Has anyone thought about a voltage stepper for the high setting? That's what I'm looking into. Since the connectors appear to be simple spade connectors, something could be made plug-and-play without hacking the harness even.
- 1974 GMC Super Custom 1500 - UPDATE: GOING 5.3 TURBO! - "Mr. Green Jeans"
- 2014 Mustang GT Track Pack - Toy
Subscribe to my YouTube channel for project updates!
bnoon is offline   Reply With Quote
Old 11-01-2013, 05:05 PM   #14
SilverMiner
SilverMiner's Avatar
I installed a new blower motor for a '94 into my '80 this summer as well, and I took advantage of an opportunity to take some measurements with a calibrated anemometer before and after the upgrade. I reported my results in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=594506
Basically it was a bit of a disappointment in the sense that the increase in flow was barely perceptible, but it was measurable. Given the very low cost of a new blower motor I decided it was definitely worth the money spent. For $20 dollars or so I realized nearly a nearly 15% improvement in air flow.
Perhaps my blower had been replaced years ago, and if it had been the original stock blower from 35 years ago I'd have seen a much greater improvement. I'd say if a person has any doubts about their blower, just plunk down the money and see if things get better. But unless you have a way to measure the difference, it is very possible you won't be able to tell.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 11-01-2013, 05:14 PM   #15
SilverMiner
I'm VERY interested to hear more about this idea. Given the relatively low cost of the blowers and how easily they can be replaced, even if a voltage increase significantly decreases the useful life of the motor it might be worth the tradeoff.
But isn't the blower already getting maximum system voltage when the fan is set to HIGH? How would you increase the voltage even further?
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
