Old 12-07-2013, 04:09 PM   #1
cortcomp
cortcomp's Avatar
hood rubber and latch questions
Putting some parts together today and ran into some snags before the power went out, hoping you guys can help...
On my hood latch, the spring that winds around the hooks main hing pin is broke...dont even see the whole latch assembly new...does anyone know a fix for this? Some kind of replacement pin and spring?
Radiator to hood seal is like bent 45 degrees...does it angle down towards the radiatior or up which lays along the hood brace, away from the radiator?
In the hood rubber set there are two long pieces that go under the bolt in braces. Then another long one and three short ones that i dont know ehere they go? Guessing under the front or rear bracing somewhere?
I know where the 4 rubber pads go (2 rivet and 2 screw in)...what about the push in rubber button ones?
Sorry for so many questions, many of these things were missing on my truck and i havent found pics to show me where they go.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 12-07-2013, 07:20 PM   #2
cortcomp
cortcomp's Avatar
Re: hood rubber and latch questions
Found a workable pin for the hinge and made a spring from a coat hanger that looks like it will work decently well and look ok! Still confused on the rubber questions though.
Old 12-07-2013, 07:40 PM   #3
Lugnutz65
Lugnutz65's Avatar
I have an original hood in the shed. I'll go take pics tomorrow.
Did you have everything media blasted?
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 12-07-2013, 08:09 PM   #4
cortcomp
cortcomp's Avatar
I did media blast the rear pad brackets, and the removable braces, and took the hinge apart and made some springs, etc, but the rest of the hood was a lot of DA work. (see my sig thread for more)
Appreciate the pics!
Old 12-08-2013, 10:54 AM   #5
chevyrestoguy
chevyrestoguy's Avatar
The hood looks great! You do very nice work.
It's funny, I'm planning to do the exact same thing you're doing in the next few weeks. I've already pulled the braces off and blasted and the next step is the DA work.
Question: What are you planning to do on the finish of the hood hinges and springs? The factory did zinc phosphate back in the day, and it's hard to find anybody who does that stuff anymore. The ones that do charge pretty steep. I was quoted $150 to do the pair of hinges and springs, and I think I can do it myself for a lot cheaper with one of the home kits.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-08-2013, 11:21 AM   #6
Lugnutz65
Lugnutz65's Avatar
As promised and I can take more pics if you need. The second photo is from a hood I sold. The first is from a 1963 hood I own.
Old 12-08-2013, 11:52 AM   #7
cortcomp
cortcomp's Avatar
Thanks for the pic! So the rubber seems to fold up towards the top of the hood, that helps a ton.
Chevyresto: i did it the cheap and easy way and left the springs and hinges on the inner fenders and painted them with the same semi gloss single stage centari as the underhood...i never really tthought about it. Now that you mentioned it i should do them right. One thing i can tell you, once you get them coated, give them two medium to wet coats of rustoleum clear. I do that to break boosters, fuel pumps, alternators, etc and it adds some shine and keeps the finish from dulling or powdering for a long time.
Old 12-08-2013, 12:03 PM   #8
cortcomp
cortcomp's Avatar
Chevyrestoguy: I had thought you meant zinc plating like below (that typical gold color on boosters etc.) I didn't realize zinc phosphate was black til i googled it. If they just looked black from the factory i'll probably leave the black paint on them.
Old 12-08-2013, 02:39 PM   #9
cortcomp
cortcomp's Avatar
OK i used some hardware store stuff to rebuild the hinge, after blasting it, taking it apart and painting it. I made the main spring that goes over the hinge pin from coat hangar (see my build thread, page 11 i think) in the vice. It works well! The one spring i have pictured, i don't think it goes there, think PO put it there when main spring broke? Also, after pics taken, shortened safety hook return spring to make it tighter just in case. Used marine wheel bearing grease on moving parts and inside latch hole. It's not as slick as the OEM setup (with a stepped mushroomed pin), i had to drill the hole in the safety hook to 5/16, BUT i can take mine a part if i want to make a nicer looking spring or find one. It is NICE and tight now, and kind of looks OEM. Also, who is going to be at a show looking at my hood latch? Who cares what that guy thinks?
On the rubber, i am clear where the two pieces go under the removable braces, but not so sure on the other pieces in red...maybe not for 66? two could go under the back hood brace, there was gunk like rubber in there before? Pic shows them up front?! Can't find holes in the hood for the round bumpers, only 4 drain holes on the front? Also may be not for 66?! So confused!
Old 12-08-2013, 02:41 PM   #10
cortcomp
cortcomp's Avatar
That one that i suspect doesn't go there, it isn't needed, home made spring returns that latch very firmly, i will probably remove it after verifying.
Old 12-08-2013, 02:43 PM   #11
cortcomp
cortcomp's Avatar
Rubber placement rear brace maybe?
Old 12-08-2013, 07:06 PM   #12
chevyrestoguy
Zinc Phosphate leaves a medium silver/gray color, and Manganese Phosphate leaves a dull charcoal/black color. My hinges were silver/gray, and Zinc Phosphate coating is what the factory used back in the day. They used Manganese on almost all of the bolts under the hood and on the suspension.
Palmetto Industries sells the products to do both Zinc and Manganese. You have to use a camp stove or a burner to keep the solution around 185 degrees. Drop the parts in, and the solution etches the parts. In the gun world, they call this process Parkerizing.
My build threads:
Old 12-09-2013, 12:42 AM   #13
Captainfab
60-66 Nut
Yes there should be a piece of the foam rubber there as well as at the front in a similar area. Then you should have the 2 adjustable bumpers at the rear of the hood, each side, and the 2 fixed bumpers at the front corners
Old 12-09-2013, 01:10 AM   #14
cortcomp
cortcomp's Avatar
So the two round bumpers, not for this year? Have the adjustable ones on (riveted to brackets) and know where front screwed ones go, but the third long and smaller peices in lmc cstalot pic confuse me.
Old 05-29-2015, 10:33 AM   #15
1963c-10
1963c-10's Avatar
Bringing up an old thread as I am fixing to do this project this weekend. In post 1 there is a question about the 60-66 hood kit having three long pieces of rubber. From what I can find, the 60-61 hoods take 3 long pieces and the 62-66 hoods take 2. My kit came with 3 also.
I'll get some good pics of the placement on all the parts when I do the install.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-05-2015, 09:53 PM   #16
chevroletrestoguy
Good info here. Thanks for posting this.
chevroletrestoguy is offline   Reply With Quote
Old 10-05-2015, 10:33 PM   #17
TopFuel1966
TopFuel1966's Avatar
Try Alumin-Art in Ontario.That's where I had all of my stuff done........
http://anopros.com/
TopFuel1966 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
