Old 12-14-2013, 08:47 PM   #1
Irishbleueyes
In cab gas tank filler hose
How does one change that little filler hose connected to the gas tank? I have a 65 long bed and gas vapor is coming out. Do I pull the gas tank? Easiest way? Thanks in advance
Irishbleueyes is offline   Reply With Quote
Old 12-14-2013, 08:49 PM   #2
Indian113
Indian113's Avatar
Re: In cab gas tank filler hose
when I did mine I replace the rubber around the cap area too. I pulled the top part out and used a 1/4 inch long extension to tighten the clamps after replacing hose then rubber and filler tube.
Indian113 is offline   Reply With Quote
Old 12-14-2013, 08:57 PM   #3
Softpatch
Softpatch's Avatar
ya that job is one of the worst
I repaced the outer fill hose to cab rubber soaking the hose with WD-40 but the clamps are tough to get to...good luck
Softpatch is offline   Reply With Quote
Old 12-14-2013, 09:05 PM   #4
losthope
losthope's Avatar
I pulled the tank clamps are easier to get to, i needed to flush my tank out anyways so did it all at once....another good thing to do with the tank out is pull the bench seat and clean up and paint the floor if thats a issue..
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 12-14-2013, 09:14 PM   #5
Mike Wessinger
Junior Member
Mike Wessinger's Avatar
I just did this repair on my old truck a few weeks ago. It was difficult enough to do it pulling the tank, so I could not imagine trying it leaving the tank in place. Since the seat had probably never been out before, I used the opportunity to do a good cleaning while the seat and tank were out.
Next time I pull the tank though, I will make sure it is not full when I pull it.
1965 Chevy C10 Stepside Shortbed--2012 370Z Base Gun Metallic--2015 Altima 2.5SV Gun Metallic--2012 Altima 2.5SL Dark Slate
Mike Wessinger is offline   Reply With Quote
Old 12-14-2013, 09:26 PM   #6
luvbowties
luvbowties's Avatar
Smile Re: In cab gas tank filler hose
I've replaced several, & never had to remove the tank. Using new clamps will help on going back on. If it just gets too tough for you, remember you don't need to save the old one----cut it off/out! New one will be more flexible & forgiving. As last resort, loosen tank to where you can shuffle it over, up, down a bit; but it does not need to be removed.
Sam
luvbowties is offline   Reply With Quote
Old 04-22-2017, 07:15 PM   #7
Ken Cook
Ken Cook's Avatar
I know this is an old thread but I did not see anyone post what I ended up doing.
I was in a hurry when I ordered my replacement tank and forgot to order the hose. I ordered the grommet but not the hose or the filler that the cap goes on.
Im glad I forgot. I had to go to NAPA to get the hose and only was available in 1 foot pieces.
I cut the matching replacement and tried to put it all together. It is way too tight for my hands.
So I....Put the grommet in the hole, put the LONG piece of hose on the filler tube and got the clamp TIGHT (way tighter than in that small space), put soap on the grommet and passed the filler through the grommet (way up in there to clear the long hose) and put the cap on.
I then had a helper finesse the tank in place, slide the filled down and tighten er up.
You can see the end of the hose but it is not noticeable.
Both hose clamps are tight and the gas smell is GONE!
Ken Cook is offline   Reply With Quote
Old 04-24-2017, 09:14 AM   #8
earl84
Ken Cook, do you have a pic or two of this?
earl84 is offline   Reply With Quote
Old 04-24-2017, 11:16 AM   #9
Ken Cook
Ken Cook's Avatar
I took the photo but I'm am not sure it worked
The hose is long enough to reach just past the corner of the tank so the clamp is accessible.
Old 04-26-2017, 07:04 PM   #10
jdl71
jdl71's Avatar
I was under the impression this hose has 2 different sized ends. You just bought fuel filler hose from NAPA though?
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 05-01-2017, 05:14 AM   #11
Ken Cook
Ken Cook's Avatar
Yes. I took the old one with me to NAPA and matched it up and bought new clamps.
I'm not sure how long it was before I cut the "short" replacement so I m not sure how long a piece I ended up using.
I may be able to pass a tape measure in there if you need.
Old 05-01-2017, 09:14 AM   #12
earl84
Thanks for the pic, it helped me fully understand what you were saying.
Old 05-01-2017, 06:17 PM   #13
jdl71
jdl71's Avatar
No, that's not necessary. I'll go by the one in town sometime and see what they have. Thanks.
Psalm 23
64 C10
66 K20
Old 05-01-2017, 08:39 PM   #14
Ken Cook
Ken Cook's Avatar
I brought the filler pipe to match the hose.
Old 05-01-2017, 08:55 PM   #15
jdl71
jdl71's Avatar
Lightbulb Re: In cab gas tank filler hose
Thanks. The light bulb finally came on...lol
Psalm 23
64 C10
66 K20
Old 05-01-2017, 09:09 PM   #16
Ken Cook
Ken Cook's Avatar
I put about 1 inch over the filler pipe. Just enough to use the clamp. That left as much of the pipe clear to push through the big grommet. You will need the room to finesse the neck into the hose. Then push the filler down to where you like it.
Old 05-02-2017, 12:29 PM   #17
reed62
reed62's Avatar
I used some heavy duty stainless steel clamps from NAPA that are way more stout than the originals or the radiator hose style clamps. I cinched them down to where I thought they would work, added some gas to the tank and then tightened more until the smell went away. it is definitely a horrible design. I used some smaller diameter muffler pipe to use as a "liner" so the gas flows along a metal conduit rather than a mix of rubber and steel. At some point in the future I may resort to moving it under the frame. I did that with my old 50 Ford F-3 and the one drawback was filling the tank through a hole in the new bed wood. I have seen the filler design using a stake pocket which is a lot of fab work, but looks pretty slick when finished.
reed62 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
