Old 12-30-2013, 11:31 PM   #1
jrick63
granny trany help!
Im 20 learning how to restore my first truck. I need a few question answered.
I have a 1965 c20 4sp. Well i decided after some thinking that I'm going to drop a 350 in. I would like to keep it a manual. What's the best/easier route to go. Being that its a 3/4t there's a little weight to push around.
Can i keep the transmission and change gears/rear end?
Or change transmission and keep rear end.?
I appreciate all answers!
Thanks, jrick
jrick63 is offline   Reply With Quote
Old 12-31-2013, 12:07 AM   #2
jtrichard
Re: granny trany help!
whats in her now? why do you think you need to change rear gears?
jtrichard is offline   Reply With Quote
Old 12-31-2013, 12:10 AM   #3
jrick63
Motor is a 283, not currently in. And needs to be rebuilt. I just heard that the trucks were geared low. I would like to be able to cruise.
Old 12-31-2013, 12:26 AM   #4
jtrichard
they are low geared i have a 63 had since 67 it will do 70+ but it has 750/17s.... not a lot of gears available for these you may want to change the rear axle to later 14 bolt much easier to get parts for.... i am putting a 81 cab and chassis in mine they are the same width....... the standard 3/4 ton 73/81+ are 1-1/2" wider 3/4 each side as for the engine change it will bolt right in
Old 12-31-2013, 12:28 AM   #5
jtrichard
you need to find out just what gear ratio you have and WE need pics .... ps welcome to the world of 60s chevy pickups
Old 12-31-2013, 12:30 AM   #6
jrick63
If i change to a 14bolt will that still be 8 lugs?
Old 12-31-2013, 12:39 AM   #7
jtrichard
yes 8 lug ... looks like the best you can do gear wise with yours is 4.11.... 14 bolt with 3.73s are very common
Old 12-31-2013, 12:41 AM   #8
jtrichard
and later you can get 73/81+ front disc brakes also then you have better braking and easier parts
Old 12-31-2013, 12:42 AM   #9
jrick63
So 14 bolt with 3.73 would be best? Can i keep the Trans then?
Sorry for all the questions! Gotta learn some how
Old 12-31-2013, 12:51 AM   #10
jtrichard
yes you keep your trans there is some work to do any of these mods you can search here for posts on how each one is done
Old 12-31-2013, 12:53 AM   #11
jtrichard
here is one on the 14 bolt there more http://67-72chevytrucks.com/vboard/s...=483346&page=2
Old 12-31-2013, 12:55 AM   #12
jrick63
And what years will match up. Right now there is a guy with 14 bolt 273 from 97 3/4t (not a full floater)
Old 12-31-2013, 01:01 AM   #13
jtrichard
late 80s i think...... personally i would not use the non floater even if it fit
Old 12-31-2013, 01:07 AM   #14
Captainfab
60-66 Nut
I typically discourage using the '88 and up pickup differentials as they are a lot wider than the early differentials, but the Eaton HO52 that is likely under your truck now should be 65.5" wide WMS to WMS. That '97, 9.5" 14 bolt should be 64.75" wide, which would work under your truck. However I would suggest verifying those measurements on the actual differential you are looking at. Also be aware that the 9.5" 14 bolt was also available in a 6 lug version, which is often found under the light duty C2500's and some K1500's.
Old 12-31-2013, 01:15 AM   #15
jrick63
Here is the ad i seen...It is out of 1997 3/4 ton HD 4x4, 8 lug (NOT a full floater) with only 170,000 miles on it. Tested and works good
Old 12-31-2013, 01:31 AM   #16
jrick63
Old 12-31-2013, 01:32 AM   #17
jtrichard
nice ... looks like you need rear cab mounts .. get a set out of a 1/2 ton frame brackets and all
Old 12-31-2013, 01:32 AM   #18
jrick63
Old 12-31-2013, 01:34 AM   #19
jrick63
Old 12-31-2013, 01:40 AM   #20
jtrichard
find a 73/88 3/4 ton that has no engine and a rusted body for parts donner and you will have rear axle, front cross member/disc brakes, power brake and power steering ......looks like you have been busy on it already
Old 12-31-2013, 01:41 AM   #21
jrick63
Will i need to change out the front cross member ?
Old 12-31-2013, 01:45 AM   #22
Captainfab
60-66 Nut
As far as I know, yes you will have to change the entire suspension, including the crossmember, on the '63-'66 C20's Another member claims otherwise, but it has not been verified yet.
If you want to change those sagging rear cab mounts, I have a C10 set here:
http://www.67-72chevytrucks.com/vboa...d.php?t=604784
Old 12-31-2013, 01:46 AM   #23
jrick63
Whats the reasoning for having to change it out?
Old 12-31-2013, 01:48 AM   #24
jtrichard
there different ways to get the disc brakes on the front change the whole thing ( i am doing that as i have a 82 with a good front suspension and grease-able control arms i hate rubber) you can change the arms and spindles or you can change just the spindles and ball joints
Old 12-31-2013, 01:49 AM   #25
jrick63
Ohh you guys are talking about if i switched everything to disc
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
