Old 01-26-2014, 10:46 PM   #1
rjeiii
rjeiii's Avatar
Small block on 6 cylinder mounts?
I have a 68 c10 that I have a 350/700R combo, Is there enough fire wall clearance to run 6 cylinder mounts? I have both forward V8 mounts and the rear 6 cylinder mounts. Would prefer to run the 6 mounts to clear the headers I bought. Is there enough room to run a HEI Distributer with the 6 mounts. We used the same mounts on my sons 66 c10 (6 cylinder) and worked great with a small block, but we had to modify the firewall when he put in a big block. I would appreciate any input you guys have. Thanks john
rjeiii is offline   Reply With Quote
Old 01-26-2014, 11:11 PM   #2
LockDoc
The Original Thread Killer
LockDoc's Avatar
Re: Small block on 6 cylinder mounts?
It will be really close. You could always use the divorced coil HEI for more clearance.
LockDoc
Leon
Old 01-26-2014, 11:36 PM   #3
Lattimer
Lattimer's Avatar
Works fine in my truck. Just about 3/4" clearance between the HEI and the firewall.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 01-27-2014, 12:05 AM   #4
rjeiii
rjeiii's Avatar
Thanks guys, appreciate the input
Old 01-27-2014, 12:22 AM   #5
Z10
Z10's Avatar
If you don't mind your firewall looking like this, it can be done. My truck originally had a 6cylinder and the PO decided to put a small block in with out changing to the correct engine stands. I have a few more pics on my build thread if your interested. But I for one would not do it.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 01-27-2014, 07:55 AM   #6
Lattimer
Lattimer's Avatar
There must be a lot of variation. My firewall needed no modification at all. Only issue I have is to pull the dizzy I have to remove the cap first.
Shawn
Old 01-27-2014, 08:47 AM   #7
Katrina/10
Katrina/10's Avatar
If you move the 6 cyl mounts to the forward holes in the frame, you will have plenty of room.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 01-27-2014, 11:38 AM   #8
LockDoc
LockDoc's Avatar
He mentioned in his first post that he needed to use the rear 6 cyl mounting location for header clearance issues. That's the way I understood it anyway...
LockDoc
Leon
Old 01-27-2014, 12:36 PM   #9
Katrina/10
Katrina/10's Avatar
Well, I guess I could have read a little more closely. I'm not sure if he's talking the position of the mounts or whether they are for 6 or 8 cyl.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 01-27-2014, 12:39 PM   #10
LockDoc
LockDoc's Avatar
I wondered about that too.
LockDoc
Leon
Old 01-27-2014, 03:24 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've done it more than a few times. Never any issue or need to dent the firewall. You can still side your hand between the back of the distributor cap and the firewall. You can still pull your distributor without issue.
Kevin -
My Instagram
Old 01-27-2014, 04:18 PM   #12
Acorn
I just put my engine in last night and I set in in the 6cyl position and had plenty of room. I have a tbi small cap but it looks like the bigger hei cap will fit.
I did it just to try and get my driveshaft as short as possible. I'm just wondering if it will make a difference in how the truck drives and handles?
Acorn is offline   Reply With Quote
Old 01-27-2014, 11:51 PM   #13
rjeiii
rjeiii's Avatar
I am wanting to put a v8 on 6 cylinder mounts (rear mounting holes) with an big cap HEI
Old 01-28-2014, 12:14 AM   #14
Lattimer
Lattimer's Avatar
This is a small block in the 6 cylinder mounting location with standard HEI cap. About 3/4" clearance on the firewall.
Shawn
Old 01-29-2014, 11:21 PM   #15
rjeiii
rjeiii's Avatar
Thanks Lattimer, that's the money shot right there. exactly what I was looking, John
Old 01-29-2014, 11:49 PM   #16
Acorn
Other than clearance for exhaust, why do some people use the 6 cyl location? What are the advantages or disadvantages?
Old 01-30-2014, 12:58 AM   #17
Lattimer
Lattimer's Avatar
A few things if you are swapping in a V-8 for the L-6:
1. Don't have to move the trans crossmember
2. Don't have to modify the driveshaft
3. Don't have to modify the clutch linkage
4. More room in front of engine for accessories, electric fans, etc.
The only performance advantage is that it does shift weight toward the rear, so it can help handling a little bit.
When I swapped in the TREMEC, I debated on moving my engine forward. I was getting a custom driveshaft and the kit came with a new crossmember that I had to locate. I have enough room in front for the fans and whatnot. A little more clearance at the back of the engine would make changing plug wires easier.
Last straw was modifying the clutch linkage. Whoever installed the V-8 modified the L-6 Z-bar, and I would have had to do some fab to make it work in the forward position. Plus I would have had to mod my exhaust. Didn't seem worth it, so I put the engine right back where it was (I swapped the 327 for a crate 355 at the same time I did the TREMEC).
Shawn
Old 01-30-2014, 09:41 AM   #18
Acorn
Thanks lattimer. That's good info to know. That shorn is a purdy engine ya got there!
Old 01-30-2014, 10:17 AM   #19
Lattimer
Lattimer's Avatar
Thanks. Unfortunately, that one came right back out. Started knocking after about 50 miles. Its still on the engine stand, I haven't gotten the courage to open it up. I got pissed off and bought a Vortec 355 crate motor and dropped it in.
Shawn
Old 01-30-2014, 10:21 AM   #20
72freak
Rottenwood Garage Member
72freak's Avatar
Yep...move them forward. I think you will need V8 stands. Why crowd the firewall and leave an ugly gap between the fan and radiator. Do it right the first time. I have passed on buying trucks that had the V8 conversion in the I6 holes.
2001 Chevrolet 2500HD Crew 6.0
1999 Chevrolet Tahoe 4x4
1999 Harley Davidson Electra Glide
1996 Chevrolet C3500 Ex-cab 5.7
1982 Chevrolet C10 short fleet
1980 Toyota Corolla "Rock-n-Rolla"
1972 Chevrolet Ex-cab K-30 Dually Cummmins 5sp
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A, "Hot Rod"
1931 Ford Model A Tudor "Silverback"
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 01-30-2014, 10:40 AM   #21
mjjjracing
Junior Member
The last two stepsides I bought had small blocks in the 6 cyl stands,Luckily I had parts trucks with the v8 stands as the 6cyl and v8 stands are different they wont move to the front holes ,at least the ones I had would not work and it gave me alot more room behind the motor
39 Chevy pickup,70 GMC short bed 4x4 ,72 short bed step side 4x4 ,71 short bed fleet side , 2-72 K20 long beds ,79 4x4 standard cab dually , 02 Dodge 4x4 dually
mjjjracing is offline   Reply With Quote
6 cylinder, c10, small block, v8 mounts
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
