Old 02-01-2014, 04:29 PM   #1
FrankyV8
Best way to lower torsion front suspension?
Need some help here guys, wanna lower my '60 torsion front suspension, but what is the best way. Wanna see something like 4 to 6 inches
Thnx a bunch
FrankyV8 is offline   Reply With Quote
Old 02-01-2014, 04:37 PM   #2
cb1965
cb1965's Avatar
Re: Best way to lower torsion front suspension?
you can do it by either screwing in or out the adjusting bolts on the bottom. turn both sides the same amount of turns to keep it level. or by doing a suspension swap and adding drop springs and spindles. or air ride
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 02-01-2014, 05:14 PM   #3
lolife99
lolife99's Avatar
They do make 60-62 drop spindles for the torsion bar frames.
Keith
Convert to disc brakes.
WTB: Radio Delete Plates and clips.
Old 02-01-2014, 06:16 PM   #4
FrankyV8
Mmm ok, thnx for the info CB1965. You have a name for me for the dropped spindles Keith?
Old 02-01-2014, 06:37 PM   #5
lolife99
lolife99's Avatar
Almost all the spindle manufacturers make them.
Three versions here:
http://www.summitracing.com/search/y...-type/spindles
Keith
Old 02-02-2014, 08:09 AM   #6
FrankyV8
Thnx Keith, Didn't know lots of manufacures make them. New in the pick up scene
Old 02-03-2014, 01:02 PM   #7
par4tom
You may want to check out "Belair Tim" on Ebay...he handles these spindles and they are USA built by McGaughy's...very high quality built in Fresno California and they will take care of the disc brake conversion for the front as well...
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 02-03-2014, 03:01 PM   #8
63burban
Chevy addict
Best drop spindle for the money are from McGaughy's. I have installed some of the generic spindles on customer cars and trucks and they suck big time. Generally the cheaper spindles need work to make them perform the way they should. Such as - grinding the control arms for clearance, grinding the spindles for clearance, changing tie rod ends to get enough room for adjustment.
I have used several McGaughy kits and get the best fit and turning radius without any problems.
63burban is offline   Reply With Quote
Old 02-03-2014, 05:32 PM   #9
par4tom
If you want McGaughy's, PM me and I will give you Tim's cell phone number. He's also the manager for McGaughy's manufacturing here in Fresno. He has an EBAY site which is how I first found him...
I think I paid about $525 for the drop spindles with disc brakes conversion...they were all built in Fresno...he even installed the whole set up for me out of his own shop in Madera. Very nice guy...
Tom
My Build Thread
Old 02-04-2014, 11:46 AM   #10
FrankyV8
Tom
PM sent, thnx for the advice Tom
Old 02-04-2014, 02:24 PM   #11
Brad54
Brad54's Avatar
Tom
Have you installed them on T-bar trucks?
Looking to see how they do on the turning radius, and fender clearance.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
Nostalgia Altered drag car with 2x4 FE Ford.
'57 Chevy 2dr 150 wagon gasser
'76 Power Wagon daily driver
'56 Chevy 2dr basket case
'54 Buick Special
'73 Duster on a rotisserie
Hi, my name is Brad, and I have a problem!
Brad54 is offline   Reply With Quote
Old 02-04-2014, 03:08 PM   #12
WCHLVR
WCHLVR's Avatar
I just made a set of dropped torsion keys for my buddy's 61 'Burb. After a little extra clearancing up front and relocating the shocks, the ride is outstanding and the keys aren't dragging on the ground.
WCHLVR is offline   Reply With Quote
Old 02-04-2014, 06:29 PM   #13
par4tom
Brad,
My 61 has the t-bars. I don't think the turning radius changed...the 15 inch wheels I had on there previous will have to be changed as the end of the tie rod only has about 1/4" clearance. That was the only issue.
I just wanted to give a Kudo's to McGaughy's out of Fresno...all american built right here and 55BelairTim who sold them to me, refused to use anything but American parts on anything he did during the install. Cost a few bucks more...but he obviously took pride in what he did.
I was treated fairly...
My Build Thread
Old 02-05-2014, 04:52 PM   #14
FrankyV8
Mmmm that looks easy enough to make myself a set!! Thnx for sharing
But this does look very tempting too, for a (what I think) good price. Set of bags and your done!!
Old 02-05-2014, 11:52 PM   #15
Monte's62
I have been looking for torsion keys for my 62 like the ones WCHLVR has made. Does anyone know if anyone makes them, and if not, what are the rules about seeing if WCHLVR could make me a pair.
Sorry I don't know how to respond to WCHLVR's post directly, so hopefully he or someone can help me out with my question.
Monte's62 is offline   Reply With Quote
Old 02-06-2014, 10:56 PM   #16
FF SIX ONE
FF SIX ONE's Avatar
I would like to know too.
FF SIX ONE is offline   Reply With Quote
Old 05-24-2014, 08:09 PM   #17
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I'd surely buy one of these 'drop keys'
66 Service truck build:
Old 05-24-2014, 09:59 PM   #18
60n60Apache
60n60Apache is offline   Reply With Quote
Old 05-25-2014, 08:30 PM   #19
1320warrior
I'd be interested in those keys as well! Look very well made!
1320warrior is offline   Reply With Quote
Old 05-25-2014, 11:03 PM   #20
WCHLVR
WCHLVR's Avatar
Might be able to work something out.
Old 05-26-2014, 12:21 AM   #21
LVPhotos
LVPhotos's Avatar
I went over the top and got PorterBuilt crossmember.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-05-2014, 12:45 AM   #22
LostMy65
LostMy65's Avatar
What do you plan on doing with the torsion bar keys?
I'm trying to design a key that provides different drop heights, but I need a loose key to get my measurements off of.
Old 09-05-2014, 11:01 AM   #23
LVPhotos
LVPhotos's Avatar
Mine are still in, for now but I will see if Tuckers got some in the bone yard. Like everyone else they have been scraping these front ends. I have some more parts to gather up before I tear down. I have to make some room for this. I plan on cab off but it might have to wait.
Old 09-05-2014, 04:43 PM   #24
forestb
forestb's Avatar
I would get the drop spindles and then start using the torsion bars to lower it. It will give you a better idea of how low you want it.
forestb is offline   Reply With Quote
Old 09-05-2014, 05:12 PM   #25
LVPhotos
LVPhotos's Avatar
Too late, way past this. If you poke around there is a shot of mine next to one with drop spindles. Lost My 65 the last ones are gone but if not in a hurry mine will be off soon. Vacation checks and Turbine work soon, so I can spend it all on the mistress.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
