Old 02-02-2014, 07:19 PM   #1
lenguini
lenguini's Avatar
Need 1964-66 headlight assembly pic
I was hoping someone could take a pic or two and post em here of the headlight assembly...... with detailed close ups of the adjuster screws, nuts,spring and bucket intact.
Thanks in advance.
Always a place in my heart for old Chevy trucks:
My build thread-project truck dream 65"
http://67-72chevytrucks.com/vboard/s...d.php?t=510863
lenguini is offline   Reply With Quote
Old 02-02-2014, 07:38 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: Need 1964-66 headlight assembly pic
I just took these yesterday. Just the grille and headlight back plate.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 02-02-2014, 08:03 PM   #3
lenguini
lenguini's Avatar
Thanks for the pics ! I have had mine apart 4 years,cant seem to get it right with the spring...where does it connect on the bucket or is it the oblong slot in the outer ring??
Old 02-02-2014, 08:18 PM   #4
Lugnutz65
Lugnutz65's Avatar
I wish I had the buckets handy, but they are in storage. Maybe someone else has a good photo. Sorry.
Old 02-02-2014, 08:52 PM   #5
lenguini
lenguini's Avatar
Anyone pit there know where the spring on the bucket connects ?I'm guessing the outer headlight ring........oblong hole.....? Looks like the hook faces the wrong way for that ?
Old 02-02-2014, 08:58 PM   #6
rickywideglide
rickywideglide's Avatar
hook side of spring connects to outer headlamp trim other side goes in hole on inboard side that has indent
rickywideglide is offline   Reply With Quote
Old 02-02-2014, 09:34 PM   #7
lenguini
lenguini's Avatar
I have the spring in place on the bucket(indent)but when the spring connects to the outer headlight ring...does it rest against the outer ring or should it be to the inside,It looks wrong at this end.
Old 02-02-2014, 10:33 PM   #8
DPowers
DPowers's Avatar
Inside
DPowers is offline   Reply With Quote
Old 02-03-2014, 01:55 AM   #9
lenguini
lenguini's Avatar
Which is correct positioning for the spring ?
Old 02-03-2014, 08:39 AM   #10
Lugnutz65
Lugnutz65's Avatar
When I disassembled my headlights, the hook on the spring points to the passenger side (both sides of the grille). You can see a few more pics on my website. You can see the hook is pointing left. Those are factory hooks. I may not be thinking clearly, but base on the way mine look, the hook enters the headlight ring from the outside. That's the only way it could work. Maybe you can twist your spring hook a little.
Old 02-03-2014, 12:48 PM   #11
rideblue00
rideblue00's Avatar
pic 1....outside
rideblue00 is offline   Reply With Quote
Old 02-03-2014, 07:53 PM   #12
Lugnutz65
Lugnutz65's Avatar
I dug out my Chevy school bus grille and found just what I was looking for. Ta daaaaaaaah!
Old 02-04-2014, 02:10 PM   #13
cutb4udye
cutb4udye's Avatar
cutb4udye is offline   Reply With Quote
Old 02-08-2014, 08:35 PM   #14
VictoriaHardware
VictoriaHardware's Avatar
Had a grill out today and gave it a close look as I had the same problem on my truck. Pictures below with the headlamp out show the spring clearly. The spring hooks into the headlamp bucket. The stainless headlamp retainer then goes over it. That makes sense; so you can change the headlamp without messing with the whole bucket and it's adjustment. Both sides are identical.
VictoriaHardware is offline   Reply With Quote
Old 02-08-2014, 08:39 PM   #15
VictoriaHardware
So this way is correct, just hook the spring into the bucket, not the stainless ring.
Old 02-09-2014, 12:54 PM   #16
rideblue00
rideblue00's Avatar
As far as i know when i installed mine, the spring goes into the stainless ring. I have an un molested 66 and thats the way it is. You have to be careful with putting the hook into the bucket because the glass bulb may ride on top of the spring hook. In your pic from yesterday VH, that small notch your spring is in, my bulbs have a little projection the fits in that notch.
Old 02-09-2014, 01:07 PM   #17
Lugnutz65
Lugnutz65's Avatar
I'm not trying to start any arguments, but the photos I posted earlier are correct. The photos that VictoriaHardware posted is not correct. Sorry VH.
Old 02-10-2014, 01:02 PM   #18
rideblue00
rideblue00's Avatar
oh yea lugnutz, yours are the same as mine. spring goes in the trim ring
Old 02-10-2014, 10:31 PM   #19
lenguini
lenguini's Avatar
Want to thank everyone here for the input.Just want to do it right the first time !
Old 03-10-2014, 12:45 PM   #20
1963c-10
1963c-10's Avatar
x3
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-31-2015, 11:26 PM   #21
jtrichard
X4 ......hooks in ring as seen on lugnutz post/pics
jtrichard is offline   Reply With Quote
Old 01-01-2016, 05:41 AM   #22
BOE
i thought mine was after market but it looks like they all require the bezel to be removed to aim the lamp?
BOE is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
