Old 02-03-2014, 09:22 PM   #1
McCoyAZ
McCoyAZ's Avatar
Projector Headlights??? Is it possible?
My wife has a 2014 GMC Acadia with some of the coolest and brightest projector headlights I have ever experienced.
Being a guy that likes to mess with stuff that should be left alone I was wondering how hard it would be to retro fit a set of projector beam lights into some old sealed beam bulbs........
Anybody have opinions one way or another?
It would not be that hard to cut open an old head light, the rest of it though might be more than is possible....
Just wondering out loud
McCoyAZ is offline   Reply With Quote
Old 02-03-2014, 09:46 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Projector Headlights??? Is it possible?
Amazon
7 Inch Projector Headlights Round with H4 Bulb... 7 Inch Projector Headlights Round with H4 Bulb... Genssi 7" Round H6017 Clear Round Projector... Genssi 7" Round H6017 Clear Round Projector...
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-03-2014, 10:49 PM   #3
theastronaut
theastronaut's Avatar
Dapper Lighting has exactly what you need. 7" round headlights with High/Low HID projectors. They're not the ebay HID-in-a-H4-housing junk. They
http://www.dapperlighting.com/collec...ssic-projector
theastronaut is offline   Reply With Quote
Old 02-04-2014, 12:14 AM   #4
siggyfreud
siggyfreud's Avatar
There is a vendor over on the pro touring forums that makes some as well.
siggyfreud is offline   Reply With Quote
Old 02-04-2014, 01:47 AM   #5
66LSx
66LSx's Avatar
7" is 7" is 7" round...
I'll EVENTUALLY be running my headlight switch... to an HID ballast/relay box.
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 02-04-2014, 02:43 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Where are the ballasts in the dapper kit? I don't see them on the page.
You can also find the GLASS conversion housings, that have the standard round bulb, but the center uses the regular removeable 9004 bulbs. They aren't HID, but fit easily, and only require a re-wire and relay (instead of direct to switch). They do a nice job inscreasing the light over stock...and the housing itself would also be where I would look to start.
Do NOT use a plastic conversion housing, as the HID or even the high-output halogens can great enough heat to melt many of them.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-04-2014, 10:35 AM   #7
McCoyAZ
McCoyAZ's Avatar
I have the 61 grill with the 4 headlights so the 7" is too large for my application.
I like the look of the Projector light encased in the old style sealed beam bulb. That's what I am looking for.
The wiring harness was upgraded to heavy duty with relays already so it should handle these newer lights without issue...
Old 02-04-2014, 10:48 AM   #8
theastronaut
Dapper sells 5 3/4" also for quad light grills.
Old 02-04-2014, 11:41 AM   #9
McCoyAZ
McCoyAZ's Avatar
You guys ROCK!
Thank you.
Old 02-04-2014, 12:41 PM   #10
theastronaut
Here are the 5 3/4" HID's on Dapper's site. Didnt' realize that the 5 3/4" units are low beam only.
http://www.dapperlighting.com/collec...ctor-headlight
Since those are low beam only, I'd get a pair of spot-pattern 100W Par46 (5 3/4") bulbs for the high beams, they're used to land airplanes so they'll be plenty bright enough I have a pair in a set of fog light housings that are wired in to the highbeams on my VW, and the long distance visibility is incredible.
http://www.ebay.com/itm/Wagner-Par-4...item3cd6344fa3
Another option is Par46 housings that accept an H3 bulb.
http://duckworksav.com/Upgrades.html
Old 02-05-2014, 11:30 PM   #11
64shortbox
64shortbox's Avatar
Definitely possible. I added them to my 64 C10. I got the glass lenses. I sure didn't want the plastic junk. the 3 stainless screws you see is where I bolted the ballast (0ne on each side) The kit I bought uses a 20 amp fuse but I'm going to run a 20 amp circuit breaker - the one pictured in the middle that isn't hooked up yet.
64shortbox is offline   Reply With Quote
Old 02-06-2014, 08:48 AM   #12
McCoyAZ
McCoyAZ's Avatar
I need to check Dapper's site to see if they sell those with out that dorky looking halo .
Old 02-06-2014, 10:52 AM   #13
theastronaut
If the don't, you can add projectors from The Retrofit Source to a set of clear lens H4's.
http://www.theretrofitsource.com/
Old 02-06-2014, 12:48 PM   #14
rideblue00
rideblue00's Avatar
subscribed
rideblue00 is offline   Reply With Quote
Old 02-06-2014, 05:14 PM   #15
dapperlighting
Active Member
dapperlighting's Avatar
Those aren't true projectors. Those are just a plastic/glass lens imitating a "projector lens". Perfectly fine for halogen bulbs but if you run HIDs in them, it will blind people on the road and put out a terrible light spread.
Dapper Lighting - Plug and Play LED Projector Headlight Replacements | The Most Trusted Name in Classic Car Lighting
support@dapperlighting.com
(833)-327-7371
Visit us our Website
Learn about our Headlights
dapperlighting is offline   Reply With Quote
Old 02-06-2014, 07:31 PM   #16
theastronaut
That's what I was thinking..
Old 02-07-2014, 12:27 AM   #17
siggyfreud
siggyfreud's Avatar
So for those of us with quad lights is the best solution to do two HID low beams on the outside, and then two really bright Halogens on the inside for high beams?
Old 02-07-2014, 01:55 PM   #18
dapperlighting
Active Member
Exactly. You don't want to have high beam HIDs because of the warm up/cool down time. We do have some H4 high power LED bulbs that would be great for high beams.
(833)-327-7371
Old 02-07-2014, 02:27 PM   #19
66LSx
66LSx's Avatar
5 years from now HID, halogen, incand will be obsolete anyhow... (both in heat, current draw, EVENTUALLY COST... and performance)
LED is already on the market as DOT approved in a 7" but prepare for your wallet to cry.
1966 C10 SWB Fleet
Old 02-07-2014, 02:34 PM   #20
theastronaut
Of all the DOT LED lights I've seen, the light pattern is terrible. The technology for LED's is improving though, and cost are starting to come down. Still not as good as HID or quality H4's yet IMO.
Old 02-07-2014, 02:38 PM   #21
66LSx
66LSx's Avatar
^^^ Bingo.... think of it right when LCD/Plasma first came out.... vs. High-Def projector(bulb) TV's....
OEM's in Europe are already releasing them as original equipment.... DOT has been bullish so far only allowing front accents and rear tail lights.... but headlights are on the way from the OEM's.
Anyone know of a 'blank' 7" housing you can buy were I could retrofit a used HID Benz/BMW projector into the 7" housing?
1966 C10 SWB Fleet
Old 02-07-2014, 04:36 PM   #22
theastronaut
I don't think blanks are available, everyone just cuts a hole in the back of a clear lens H4. The Retrofit Source has a nice selection of projector bezels that make the conversion look more finished.
Old 02-07-2014, 05:54 PM   #23
66LSx
66LSx's Avatar
there not that hard to manipulate... on my old truck... I took el-cheapo Audi R8 LED f150 units... baked the housings and ripped them apart and put in a set of BMW 3 series in...
It was kinda fun... FYI HID runs cooler than halogen
1966 C10 SWB Fleet
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
