Old 02-16-2014, 06:56 PM   #1
nolimitssjca
Solenoid Wiring Hook-up
I took out my starter to change my solenoid (intermittent problems). I noticed there were 3 wiring locations with 2 attached (battery and something else). There was a 3rd wire hanging down with no connecter end (and not connected). Any thoughts about what this is? Does it need to be attached?
nolimitssjca is offline   Reply With Quote
Old 02-16-2014, 07:00 PM   #2
LockDoc
The Original Thread Killer
LockDoc's Avatar
Re: Solenoid Wiring Hook-up
If you have an HEI distributor and the wire is yellow you don't need it....
LockDoc
Leon
LockDoc is online now   Reply With Quote
Old 02-16-2014, 07:07 PM   #3
nolimitssjca
Not HEI. Original. Apparently the other is the switch. Not sure as to the other wire.
Old 02-16-2014, 07:38 PM   #4
LockDoc
LockDoc's Avatar
Wire from the neutral start switch to the "S" terminal on the solenoid is a 10 or 12 Ga purple wire. The wire from the coil to the "R" terminal on the solenoid is a small yellow wire. I don't remember what Ga it is.
LockDoc
Leon
Old 02-16-2014, 10:56 PM   #5
nolimitssjca
It's odd because I don't think it was connected. It definitely doesn't have a connector and is a bit shorter. Will is start with just the switch and power?
Old 02-16-2014, 11:07 PM   #6
LockDoc
LockDoc's Avatar
Had it been starting OK before you removed the starter? With a points distributor the Yellow wire from the solenoid (R) post supplies a full 12 volts to the coil when the engine is cranking over. After it starts the voltage to the coil drops to 6-8 volts through the resistor wire.
LockDoc
Leon
Old 02-17-2014, 10:34 AM   #7
burnin oil
Like doc said. The points wire is closet to the frame rail when the starter is installed. The ign switch is closest to the block.
burnin oil is offline   Reply With Quote
Old 02-17-2014, 01:02 PM   #8
nolimitssjca
It must be the points wire. It was starting fine (except for the solenoid not kicking out fully.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
