Old 03-14-2014, 07:29 PM   #1
66Submarine
66Submarine's Avatar
I-6 really weird "overheating" story
Just got done chasing this over the last couple days. I swapped the 283 in my truck out for a 250 I-6 I had. Used the same temp gauge; worked fine when I drove the truck into place to pull the engine, and didn't do anything to damage it.
Got the 250 in, filled it up with coolant and drove it maybe 1/2 mile down the street and back; it wanted to peg the 250 temp gauge. Winding it up to 3,000+RPM would cool it down a bit, and it seemed like it would hold something like 210-220 IIRC; idling or slow driving and it would shoot right up. Damn it all! So much for a victory lap.
I'd never run this engine in a truck with the cooling system hooked up, only with an old spare radiator loosely attached leaking water everywhere (adding as needed), and only for a minute or two. So, a few thoughts came to mind. The first was that thermostat was stuck; the second that the head was cracked by being run without water too long before I bought it; the third that it was full of some crap rats packed in there, and not flowing water.
Changed thermostats; same result. Head didn't seem to be cracked, as there was no bubbling visible running it with the waterneck off and waterpump unhooked. For kicks, I left it out after that; seemed to act somewhat normally, and would idle at 172. So, must be a problem with the flow, right? Something that restricted flow enough that it wouldn't work with the thermostat in, or something. I could see the flow through the radiator with no thermostat.
So, I took everything apart and flushed it all out with a hose. Some rust came out, but not much, and no evidence of rats. (The heater core was more plugged than anything else.) Flow seemed just fine. WTF? Put it back together, same deal.
So, maybe a bum waterpump or something? Nope. Wiped some aviation sealer and the old waterpump and put it right back where it was. I also repeated the "flush", and probed around with a hooked wire; no evidence of plugged cooling passages.
So, maybe somehow the exhaust is doing something? Grasping at straws here, but the muffler was somewhat plugged by rats when I put everything together. So, being confused and frustrated, I pulled the exhaust off and ran around the block without nothing off the manifold. Louder, but otherwise unchanged. Really getting frustrated at this point.
It doesn't seem to be overwhelming the radiator, so I decide to plug the exact thermostat I ran for over 5K miles in the 283 in there. Same. Damn. Thing.
So, everything is OK, but it can't get out of the driveway without pegging the temp gauge!?!
So I just let it sit there to see how high it would go idling. Only got up to 210 or so; the other stuff I had done showed slight improvements for whatever reason. But I had a revelation when feeling around; I could actually hold my hand on the head! No damn way that thing is 210 and I can touch it! I also then noticed that the gauge needle would move a little if I moved the truck (getting in it, for instance).
So... you can guess where this led. I pulled the gauge for another one that that seemed to work OK when it was pulled; the truck was "fixed" at that point! The old gauge seemed to work/act normally, but it obviously didn't.
Just thought some would enjoy a long, rambling story of stupidity, and maybe I could save someone else some trouble. Moral of the story; if the gauge says it's overheating and it shouldn't be, make sure it actually is!
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 03-14-2014, 07:38 PM   #2
MikeS.
MikeS.'s Avatar
Re: I-6 really weird "overheating" story
"Just thought some would enjoy a long, rambling story of stupidity, and maybe I could save someone else some trouble. Moral of the story; if the gauge says it's overheating and it shouldn't be, make sure it actually is! "
I like the moral of the story and actually the whole story.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 03-14-2014, 07:57 PM   #3
TJ's Chevy
Chevy I6 and GMC V6 Nut
TJ's Chevy's Avatar
I enjoyed it to! Makes me wanna double check my temp gauge.
"6 in a row makes it go!"
"I prefer a buzzin half-dozen"
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-14-2014, 08:12 PM   #4
WhippinSaw
WhippinSaw's Avatar
Good thing it wasn't the oil pressure gauge, I almost pulled my motor because it said my oil pressure was really low
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 03-14-2014, 09:16 PM   #5
rideblue00
rideblue00's Avatar
that woulda been a bummer especially if you'da torn it down and no problems
rideblue00 is offline   Reply With Quote
Old 03-15-2014, 06:13 AM   #6
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Seems most issues are diagnosed as major issues before discovering the simple solution. Went through a over thought starting issue that came down to dirty battery post connections, but they looked clean!
Old 03-15-2014, 07:33 AM   #7
tincan1966
tincan1966's Avatar
I bought an infrared thermometer with laser pointer, just because of this exact same problem once. it's an investment that will let the hair remain on your head and the dents out of your forehead!
Great job of discovering the source, tho!
tincan1966 is offline   Reply With Quote
Old 03-15-2014, 08:48 AM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Your tale would be the EXACT situation I would be in. Glad it worked out without too much headache for you.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-15-2014, 10:30 AM   #9
Jeff La
Unfortunately we tend to believe our gauges first and not check them causing much work. I say we because I have done the same thing LOL
Jeff La is offline   Reply With Quote
Old 03-16-2014, 09:19 AM   #10
ljackson
ljackson's Avatar
I wouldn't say "stupidity". I've been there, It feels that way when you spend a day when I could have been an hour. You know more about your truck now than you did before.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 03-16-2014, 09:39 AM   #11
lmdangerous
Don't feel bad my friend. I did the exact same thing when I put a 250 in my 1951. New aluminum radiator electric fan the works. The factory gauge had always worked with the 235 I figured it was good.
An infrared heat gun is money well spent. Mine never rattled, lost water, lost power or any of the normal signs. I replaced a factory radiator that I believe to this day was perfect. I kept it but I had already ordered the new aluminum one so I put it in. Funny how we are all so much alike at times.
God love crazy things. I guess that kinda proves where we are. Lol
lmdangerous is offline   Reply With Quote
Old 03-16-2014, 09:53 PM   #12
Lowl!f3
Lowl!f3's Avatar
I just ran into this last week. truck ran fine and all gauges worked. All of a sudden the temp was pegged. shut it down and popped the hood. No sign of overheating? Hmmmm
unplugged the electric temp sensor and hooked up my old trusty manual temp gauage. Started the truck up and discovered. it was not running hot. either the sensor went out or the gauge.
Keeping a manual temp gauge and fittings in the garage is a good starting point for trouble shooting overheating. Next is to absolutly make sure you didnt install the thermostat upside down.
1965 C10 Project
Lowl!f3 is offline   Reply With Quote
Old 03-17-2014, 12:16 AM   #13
66Submarine
Glad to hear you all liked the story. I've actually been meaning to get one of those infrared thermometers for a while now; it certainly would be useful for stuff like this!
And yeah, it was nice that there wasn't really a problem with the engine; although by the end I was about ready to pull it and drop a different one it anyway.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
