Old 03-18-2014, 09:18 PM   #1
Iceburgh
Iceburgh's Avatar
1953 Burb build
My original thread was all jacked up so I am starting a new one.
I picked up a '53 suburban in Long Island
Not bad , I was told it came from Ca. but I cant confirm that.
Toe boards have been replaced as have the inner kick panels. The rear fenders have had some work and I would like to replace the passenger side. Rear doors , passenger side is great the drivers side needs work and again I would like to replace if possible.
Fenders and hood are great as is the roof. The doors are good except for the bottoms inside but that is a easy fix.
Wood floor needs replaced as does the floor on the passenger side .
Plans are to put in a LS motor, mustang II and leaf springs in the back. No bags but get it down to about 5" off the ground.
Me along with my FIL and uncle will do all the work and a buddy will do the paint. Hope to have it at his shop ready for paint by Aug-Sept time frame.
I have built or helped build 7 or 8 trucks, always used Camaro clips and small blocks. The mustang II and LS will be different for us but I like the challenge.
I am sure I will have many questions.
The suspension is in boxes in the garage as is the LS just need to get cracking on this thing....but that damn thing called work continues to get in the way
Almost forgot.....finding the turn signal bezels is like finding the winning lottery ticket
Iceburgh is offline   Reply With Quote
Old 03-18-2014, 09:22 PM   #2
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
Tear down phase
Old 03-18-2014, 09:27 PM   #3
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
last few days making progress.
New wood floor in place. The plans are to have 4-5 chrome strips over the floor that will be stained and have clear over it. One strip will cover the seam.
Anyone doing this you will make life easier with a hand held router or one for your dremel. Route the edges and the cross members
Old 03-18-2014, 09:28 PM   #4
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
Getting the rear ready
Old 03-18-2014, 09:30 PM   #5
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
Engine tranny ready to test fit...hope by this weekend
Old 03-18-2014, 09:32 PM   #6
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
front suspension...out and sold
Rear suspension out ( lug 3:73 open rear for sale)
Old 03-18-2014, 09:35 PM   #7
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
rear suspension in ( TCI swears two leafs will be enough I am not sure)
Old 03-18-2014, 09:36 PM   #8
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
Mustang II welded in...bolt on parts and C notch to be done tomorrow
Old 03-18-2014, 09:37 PM   #9
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
Patch panels started
Old 03-18-2014, 09:38 PM   #10
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
Roll pan mock up
Old 03-18-2014, 09:41 PM   #11
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
Plans for the next two weeks.
1. Finish roll pan
2. Replace floor under the seat
3. Fit motor/trans/build trans tunnel
4. Finish patch panels
5. Place gas tank
6. Fit steering column and linkage
7. Get frame to powdercoat
Old 03-18-2014, 10:45 PM   #12
youngrodder
youngrodder's Avatar
Re: 1953 Burb build
Looks good. I will be interested to see your patch panel for the driver side quarter panel. I saw in a pervious pic that you cut it out. I need to do the same to mine, and I was kicking around making my own patch.
Let me know how you repair yours.
Marc
...........__________
.................. ||__|__||___\____
..;.;;.:;:;.,;..;|/_(O)\____ /_(O)|
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completion date: Spring of 2020
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
youngrodder is offline   Reply With Quote
Old 03-19-2014, 12:09 AM   #13
oldman3
oldman3's Avatar
Re: 1953 Burb build
Moving right along, nice work...Jim
oldman3 is offline   Reply With Quote
Old 03-20-2014, 09:53 AM   #14
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
Marc
Marc,
It is the same panel as the lower door. LMC item 38-7920 will fit in and is only $35
Old 03-20-2014, 10:25 PM   #15
youngrodder
Re: 1953 Burb build
Originally Posted by Iceburgh View Post
Marc,
Cool deal. I was thinking that it would be tha same curve as the door. The quarter patch that I found from Jim Carter was $59.00. I like the price of your solution better.
Marc
Old 03-21-2014, 06:36 PM   #16
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
Old 03-21-2014, 10:39 PM   #17
youngrodder
Re: 1953 Burb build
Looking good....
Marc
Old 03-21-2014, 11:28 PM   #18
oldman3
oldman3's Avatar
Re: 1953 Burb build
Looks real nice...Jim
Old 03-22-2014, 01:01 AM   #19
alaska gasser
alaska gasser's Avatar
Re: 1953 Burb build
Lookin good!!
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude
http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU
alaska gasser is offline   Reply With Quote
Old 03-22-2014, 09:18 AM   #20
FarmerSid
FarmerSid's Avatar
Re: 1953 Burb build
Makes a big difference when things are cleaned up and some new shiny parts are installed.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 03-27-2014, 01:33 PM   #21
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
Starting the roll pan
Old 03-27-2014, 02:05 PM   #22
youngrodder
Re: 1953 Burb build
Looks good. I like the roll pan. Are you not using the rear splash panel that goes between the bumper and body? If your interest in selling it I would like to talk to you about it.
Marc
Old 04-05-2014, 03:37 PM   #23
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
Roll pan is complete...close enough to take it off massage it and use a little plastic
Old 04-05-2014, 03:41 PM   #24
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
Got a radiator at a good price that fits perfect and also got the GMC radiator top sent in from Alaska
Never noticed just by looking how much of a difference there is from a Chevy and a GMC rad support.
In any case Sparky and the gang at RnD did a great job and this will fit GMC and they will also make them for Chevy. Same rad just mounting points are slightly different
Old 04-05-2014, 03:47 PM   #25
Iceburgh
Iceburgh's Avatar
Re: 1953 Burb build
Motor is in place....waiting on Headers before we weld in the motor mounts from Dirty Dingo
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
