Old 04-07-2014, 11:52 AM   #1
K98AL
K98AL's Avatar
Pinging 6
I can't figure out what I'm doing wrong...
Got a 235 with about 27k on it since rebuild, Fenton headers, Tom Langdon's HEI, and a 2-bbl Weber,3:38 rear end, granny 4 speed.
I only run 91 octane gas.
Truck runs great, but going up some hills at 50-60MPH, I get some pinging. It wasn't doing this 6 months ago - I've retarded the timing, but when I get it retarded enough to lose the uphill ping, it's too retarded to run at max efficiency. Spark plugs are toast brown, no other problems I know of.
Reading Sharps40 disaster story kinda has me worried. Should I be?
K98AL is offline   Reply With Quote
Old 04-07-2014, 12:43 PM   #2
PGSigns
PGSigns's Avatar
Re: Pinging 6
Check advance weights and springs and see if they are working well. Also you could check the vacuum pot to see if it is returning correctly. If both of those look fine a lean condition will also cause detonation.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-07-2014, 12:50 PM   #3
K98AL
K98AL's Avatar
Re: Pinging 6
I'll sure check that out, Thanks!
Old 04-07-2014, 01:03 PM   #4
TJ's Chevy
Chevy I6 and GMC V6 Nut
TJ's Chevy's Avatar
Re: Pinging 6
You obviously have carb adjusted right...might consider richening it a tad. Sharp's issue was to much advance, to lean and not enough octane far as I can remember. Note..to much retarding can cause issues as well...8-10 degrees below TDC is a good setup I believe...I'm not a go pro on timing. lol
"6 in a row makes it go!"
"I prefer a buzzin half-dozen"
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-07-2014, 04:05 PM   #5
K98AL
K98AL's Avatar
Re: Pinging 6
Thanks to y'all for the advice - will do as advised!
It is shore nice to have this wealth of info on the board.
Old 04-14-2014, 07:19 AM   #6
K98AL
K98AL's Avatar
Re: Pinging 6
I backed off the timing a bit, re-adjusted carb. Pinging quit, idles a bit different, but running strong. I had just listened to it to get best running, prob had it way too advanced. Got a 400 mile trip up into the Ozarks in a couple weeks, ought to see how it does on some real hills.
Old 04-14-2014, 10:26 AM   #7
K98AL
K98AL's Avatar
Re: Pinging 6
good luck!
Old 04-14-2014, 11:12 AM   #8
TJ's Chevy
TJ's Chevy's Avatar
Re: Pinging 6
Glad yer truck is running better...hope it pulls the hills better to.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
