Old 04-20-2014, 07:54 AM   #1
Ronw435
Ronw435's Avatar
Spare tire reinforcement for step side.
Does anyone have any ideas on how to reinforce the spare tire carrier to keep from getting stress cracks in the box? Any information would be appreciated.
Ron
Ronw435 is offline   Reply With Quote
Old 04-20-2014, 09:22 AM   #2
1963c-10
1963c-10's Avatar
Re: Spare tire reinforcement for step side.
Welcome to the forum Ron. This thread will give you all the info and pics you'll need on the subject. Let me know if I can be of any help.
http://67-72chevytrucks.com/vboard/s...d.php?t=505728
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-20-2014, 05:58 PM   #3
Ronw435
Ronw435's Avatar
Thanks for the info 1963.
Old 04-20-2014, 06:40 PM   #4
1963c-10
1963c-10's Avatar
no problem at all
Old 04-21-2014, 09:44 PM   #5
WhippinSaw
WhippinSaw's Avatar
The wear iron for the carrier I installed didn't fit so I made one out of angle and bolted to the cross brace
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 05-21-2014, 11:59 AM   #6
old cool
I have a 66 short bed that has been redone. I cannot move the spare around so I assume it's reinforced correctly. Let me know if I can describe the bracket system or better yet I will get someone to show me how I can post pictures.
old cool is offline   Reply With Quote
Old 05-21-2014, 02:20 PM   #7
1963c-10
1963c-10's Avatar
old cool...check out the thread on spare mounted fenders....should give you all you need to know on them.
Link: http://67-72chevytrucks.com/vboard/s...d.php?t=505728
Old 05-21-2014, 02:44 PM   #8
old cool
Smile Re: Spare tire reinforcement for step side.
C10, I thought Ron was asking about spare tire carriers under bed. My mistake. However, I'm sure there are others who will be able to use your leads. Thanks
Old 05-21-2014, 04:11 PM   #9
1963c-10
1963c-10's Avatar
The under bed carrier doesn't connect to the box in any way. It only connects to the frame. When you convert a standard stepside to a spare carrier fender, there are reinforcements that need made due to the weight of the carrier and tire on the bed side.
I could be mistaken, but I thought he was referring to the fender mounted spare.
Old 05-22-2014, 06:41 AM   #10
Ronw435
Ronw435's Avatar
The problem I was addressing was when I took the truck apart it had stress cracks at the mounting point on the side panel. Was wondering if anyone had experienced this. Was trying to come up with a solution to keep it from happening again with the truck all done. Thanks for all the inputs though. I do love this forum.
Old 05-22-2014, 08:34 AM   #11
1963c-10
1963c-10's Avatar
The carrier has several support brackets. Was your truck originally a spare fender model or was it converted? Can you post any pictures of what you have and the stress cracks?
Old 05-23-2014, 06:30 AM   #12
Ronw435
Ronw435's Avatar
I will try to get some pics of the parts as I have taken it apart. I will also get some pics of the stress cracks on the side of the panel. As I am retiring today it may be a couple days (going to have to recuperate from partying) before I post the pics. Thanks for the reply.
Old 05-23-2014, 06:59 AM   #13
Ronw435
Ronw435's Avatar
Hey 1963-C10 was looking at your thread about the 348. Did you get it broke loose? Is it rebuilt yet? Those along with the 409's were cool looking engines. And from what I understand were torque monsters.
Old 05-23-2014, 09:08 AM   #14
1963c-10
1963c-10's Avatar
No, haven't had time to get back on it yet. Got side tracked with a roof project on my barn. Will be back on it Sunday when I get back from a camping trip with some friends up in the Uhwarrie Nat'l Forrest.
I've got the conversion done on the fleetside from manual to auto, the new cab mounts came in last week for it so I can mount the cab permanently. Will be ready for an engine to drop in soon.
I'll probably have to pull the heads if I can't get it to rotate. I have gone out one a week and soaked the cylinders, so maybe she's ready to spin now and I won't have to pull the heads. I'll keep you updated.
Old 05-23-2014, 05:49 PM   #15
Ronw435
Ronw435's Avatar
Looking forward to hear about it. I am posting some pics of the mount locations for the spare tire and what I was talking about with the stress cracks.
It does have the mount at the front of the panel the to the back panel. It also had two L brackets that go vertical for support as well as the rods.
Thanks for the information.
Ron
Old 05-23-2014, 05:52 PM   #16
Ronw435
Ronw435's Avatar
I will try some bigger pictures. Let me know if these are any better.
Old 05-27-2014, 09:31 AM   #17
1963c-10
1963c-10's Avatar
Can you get them any larger? I tried to copy and enlarger, but they came out blurry. There is a small mount that fits over top of the fender and under the bed rail also...and then the carrier support rod through the fender.
Old 05-27-2014, 10:41 AM   #18
Ronw435
Ronw435's Avatar
Let me try again. Let me know if this helps any.
Old 05-27-2014, 10:43 AM   #19
Ronw435
Ronw435's Avatar
I have all the rod supports but I am not familiar with a mount over the top rail. Is this something that overs over the top of the bed panel?
Thanks for your response.
Ron
Old 05-27-2014, 10:44 AM   #20
Ronw435
Ronw435's Avatar
checking to see if theses are bigger.
Old 05-27-2014, 10:47 AM   #21
Ronw435
Ronw435's Avatar
One more time.
Old 05-27-2014, 10:51 AM   #22
1963c-10
1963c-10's Avatar
Ronw435.....where is this damage at? Guessing the inside of the side bed panel?
Old 05-27-2014, 11:32 AM   #23
Ronw435
Ronw435's Avatar
Yes that is correct. The PO had bondo'd over it on the inside. Going to weld it up and would like to know if they make something that will keep it from cracking it again that is stock? The gold color is my current driver in the back ground, which is going to be leaving this next week so I can make the 65 my daily driver.
Old 05-27-2014, 11:43 AM   #24
1963c-10
1963c-10's Avatar
My guess is it cracked due to the damage caused by the PO. If you replace the bad metal, the factory carrier brackets you have should be more than adequate to hold the weight. I've carried a 235/75R15 spare for years with no issues.
Old 05-27-2014, 02:32 PM   #25
Ronw435
Ronw435's Avatar
Thank you sir I will do that. Appreciate all your input. Great forum!!!
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
