04-22-2014, 03:44 PM | #1 |
Advice for TH350 Transmission Swap on 62' C10
Anyone have any tips or advice on swapping in a TH350 trans into a 1962 C10 long bed? The truck already has a 350 SBC in it from the previous owner, using the front horseshoe style motor mount and bellhousing mount from the 4-speed. Would I need to change to the later style side mounts since I'm swapping the trans and removing the old trans cross member and making a new one? ( Has the x-frame so I think making a new one is probably easier) I'm just worried about getting everything lined up right and also if the motor will have enough mounting points and support. Also, I don't have a lift to drop the old 4 speed trans out, so I was going to just pull the motor and trans together, pop on the new TH350 trans and re-install both. I've been reading as much as I can on the topic but any advice or tips would be great! Anyone have any links or good threads they'd read about this swap? Thanks in advance to everyone.
04-22-2014, 05:14 PM | #2 |
Re: Advice for TH350 Transmission Swap on 62' C10
You have to have at least three mounts total, and the TH350 will only have one mount at the tail, so yes, you'll want to ditch the horseshoe mount at the front and go to side engine mounts. That should be very easy.
04-23-2014, 12:03 AM | #3 |
60-66 Nut
Yes you will have to convert to side mount engine mounts. From a quick test fit, the '67-'72 small block rnginr mount brackets seem to fit rather well. Some say a ~1/4" spacer is needed on top of the frame. If this were my truck, I would modify a set of '73-'87 engine mount brackets to fit the early frame. Those engine mounts are a much better design. The original bellhousing crossmember will need to be left out and a trans crossmember fabricated.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 04-23-2014 at 12:36 AM. |
04-23-2014, 01:47 AM | #4 |
You can pull the old 4 speed with a motor hoist by coming thru the passenger side door. Simply pull the shifter, remove the hump, and bolt a short chain to the tranny top cover using the existing bolts. Makes it a one man operation.
06-07-2014, 12:33 AM | #5 |
But Found Her 25yrs Later!
Have you made any progress?
Got any pics of the install? Did you run into any issues?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
06-07-2014, 10:05 AM | #6 |
hello! suggest you use a shor ttail shaft th350, it will be easier to remove if you ever have to service it. you can use the longer tail shaft models but it will stick past the t/bar crossmember you will have to do some twisting and tuning to get it out. that's if you have engine in stock location good luck.
06-07-2014, 09:11 PM | #7 |
Not a T350 but put a 2004R in my wifes 62.
I think that was about it for the trany swap. The truck is still a work in progress, not a frame up just something for my wife to drive around town; clean body with paint, clean interior, power breaks, auto transmission, power steering, 283 rebuilt for reliability, repositioned short person gas pedal etc. probably should have used a 700R4, my thought was that the 2004R might have a less noticeable shift. Last edited by lbspd; 06-07-2014 at 09:17 PM. |
06-07-2014, 10:56 PM | #8 |
Thanks,
That helps a lot. Fortunately I already installed the same motor perches when I installed a V-8. My goal right now is to just get an Auto installed for as little cost as possible. I don't do a lot of highway driving, so the OD wasn't my need. Lots of Hills and Stop and Go. - Tired of the constant shift up and down of a Manual.
06-08-2014, 08:23 AM | #9 |
I'm doing the same thing with my 62 but putting in a 5 speed manual, I see the one crossbar has to go but im worried about the crossbar the torsion bars hook to, any thoughts?
06-08-2014, 03:45 PM | #10 |
Shouldn't be a problem, hard to tell in the above photo but that rear mount for the 2004R bolted to it dead center.
06-08-2014, 10:07 PM | #11 | |
What exactly do you have to do as far as modifying the mounts? Also, this is the first I've heard discussed as far as needing side mounts for a TH350 Trans. I'm confused and nervous at the same time and, wondering if I'm gona be able to pull this off...LOL I remember in a previous thread that I posted about engine mounts you saying that '73 - '87 mounts were in your opinion the best ones to use. I havn't bought any yet in fact, I just got the old motor( 283 with 2 speed powerglide ) out yesterday. |
06-08-2014, 10:37 PM | #12 |
Trucks that came with the manual granny-lo transmission have a single front horseshoe shaped motor mount with side support provided by the transmission mounts, but with the powerglide you already have side support provided by the motor mounts.
Since your mounts are nearly impossible to find those of us starting with a manual transmission and the horseshoe motor mount need to come up with alternatives. Link with photos |
06-08-2014, 11:55 PM | #13 |
Senior Enthusiast
Welcome to the forum. Perhaps the following thread will help. I shows installing a 350/350 in a 1960 GMC:
http://67-72chevytrucks.com/vboard/s...light=sbc+1960
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
06-09-2014, 12:33 AM | #14 | |
60-66 Nut
Since you already had a 283/PG in your truck, you will already have the side engine mounts. You're good to go.
06-09-2014, 12:14 PM | #15 | |
I guess I was thinking you meant side mounts for the trans. So, everything mouts at three places, the two side mounts for the motor and, one at the back of the trans? |
06-09-2014, 01:40 PM | #16 |
06-09-2014, 06:12 PM | #17 |
I had never seen the 'Horseshoe' engine mount thingy.
My 62 donor didn't have one. Mine was a V6 so it had two lower side mounts fabbed as part of the frame. Here is a pic I found of the Horseshoe engine mount.
06-10-2014, 06:31 PM | #18 |
06-11-2014, 09:01 AM | #19 |
My 62 had the front mount at first but I went up to the later side mounts and fabbed something up for the tail shaft using the old bell cross member and some plate I found in the garage.
I think years ago on my last build I made the old torsion bar cross member work too (after flipping the front clip up to coils). rg |
12-07-2014, 03:54 PM | #20 | |
. Are you saying you just mounted your auto tranny to the torsion bar crossmember?
12-07-2014, 08:16 PM | #21 |
Yes, motor in front crossmember in back, which is why the motor needed the side mounts.
12-07-2014, 09:54 PM | #22 | |
My question was pertaining to the auto mount. I ask because most have to install an auto crossmember. But it appears you didn't. Because you just used the torsionbar crossmember. I guess I'll have to see where my tranny tail lands.
12-07-2014, 11:25 PM | #23 |
Simple to make in place...I used some steel bar and some angles for mine
12-07-2014, 11:53 PM | #24 |
Wow, looks nice under there!
Yea a TH350 is approx. 20 3/8 inches from front to rear mounting bolts, 6 5/8 inches shorter than the 2004R. This link might help. http://www.tciauto.com/tc/trans-dim |
12-08-2014, 12:53 AM | #25 |
That's a good link...I have 700r4 also and kept my options open with the additional length. The 200r will pose some serious interference with the torsion crossmember.
Thread Tools | |
Display Modes | |
