Old 04-29-2014, 08:46 AM   #1
encasedmetal
tricks for removing bumper bolts?
wondering if there's any tricks out there for removing the front bumper bolts. was trying to take off the front bumper and one of the bolts just spins as I'm turning the nut- guessing the square hole is rounded. any tips besides cutting it off? thanks
encasedmetal is offline   Reply With Quote
Old 04-29-2014, 08:49 AM   #2
McCoyAZ
McCoyAZ's Avatar
Re: tricks for removing bumper bolts?
Grab a large pair of vice grips, hold the bolt at the end of the thread, then slip a wrench on the nut and loosen it until you can switch places with the grip and the wrench.
McCoyAZ is offline   Reply With Quote
Old 04-29-2014, 08:52 AM   #3
encasedmetal
thanks. it's not that I don't have common sense (I swear), it's just that I don't want to make old issues on the truck worse. I'm an engine guy learning to do body work, welding etc. this site i where I spend alot of time now.
Old 04-29-2014, 09:38 AM   #4
cg285
if they are old and rusty i use a long handled 1/2 ratchet and break them off (righty tighty). other wise you fight it until the head spins
cg285 is offline   Reply With Quote
Old 04-29-2014, 09:53 AM   #5
1963c-10
1963c-10's Avatar
Ive had to drill the heads out of them also. Had a set that were so bad you couldn't get ahold of the bolt from the back and the nuts were only 3/4 there from corrosion. Just drilled a 1/2" hole through the head of the bolt and knocked the caps off.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-29-2014, 09:54 AM   #6
Softpatch
Softpatch's Avatar
I used a torch .
Torch from behind so not to harm chrome
no way were mine coming off without it.
then bought a new set from Classic for $20
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 04-29-2014, 09:59 AM   #7
ncoonen
ncoonen's Avatar
Originally Posted by Softpatch View Post
I used a torch .
^^^This^^^
The smoke wrench is your best friend when working on a 50 year old truck. I used mine (MAPP gas torch) this past weekend to get the thermostat housing bolts out of my '63 230. Might have been the original t-stat in there.
...ned.
'63 C10 long wide; '61 Corvair Lakewood; '74 BMW 2002tii; '89 BMW 325i, '49 Ford 8N
ncoonen is offline   Reply With Quote
Old 04-29-2014, 09:33 PM   #8
Kingjasn
Kingjasn's Avatar
if you have access to a welder, you can weld a nut to the front, or cap, of the carriage bolt and then use a wrench on the front and back...
Kingjasn is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
