Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-11-2014, 12:31 AM   #1
2000Limited
2000Limited's Avatar
Project "Colonel"
Hello all, new to this site and this is my first post. I'm wanting to start a build thread. So here we go.
Everyone meet Colonel. Its a 78 Chevy Scottsdale 4x4. It has a 350 engine with Turbo 350 Tranny, 3.73 gears in the 12 bolt rear end. Unsure of the front axle or gears yet. I brought it home May 18th after inheriting it from my father. (My fathers nickname was Colonel so that's where the name come from!)
The pic included is it on the trailer the day I brought it home. More to come as I go along
2014 Dodge Charger SXT 100th Anniversary Edition
2009 Chevy Silverado Z71
1978 Chevy Scottsdale 4x4-Project "Colonel"- Build
http://67-72chevytrucks.com/vboard/s...d.php?t=632039
2000Limited is offline   Reply With Quote
Old 06-11-2014, 12:39 AM   #2
2000Limited
Re: Project "Colonel"
Heres the block I'm going to use for my 383 stroker build.
Old 06-11-2014, 12:47 AM   #3
2000Limited
Here is the pics of when I pulled the rear diff cover off to find out what gears it has
Old 06-11-2014, 01:20 AM   #4
winningz
Awesome truck man, looks similar to mine.
78 chevy scottsdale 4x4 k10
Alaskan Members Check In
http://67-72chevytrucks.com/vboard/s...22#post5094422
winningz is offline   Reply With Quote
Old 06-11-2014, 07:31 PM   #5
2000Limited
I picked up some parts today! Holly renew kit for the Holley 670 Truck Avenger carb I'm guna run, a clear fuel filter for the same, and the fluid to finish the rear diff cover change! More pics to come
Old 06-11-2014, 07:37 PM   #6
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Looking good! I'll follow along..
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 06-11-2014, 07:42 PM   #7
2000Limited
Thanks Kyle! See the block I got from Rex?
Old 06-11-2014, 11:48 PM   #8
screaminchevypickup
Laid Back
Yep he told me about it!!
72 chevy swb
Kyle
Old 06-12-2014, 12:01 AM   #9
2000Limited
Here are the headers and carb I will be using. Once I make sure the headers fit, I will have them powdercoated. The other pics are just random pics taken the other day
Old 06-12-2014, 12:03 AM   #10
2000Limited
I hope it was good stuff he told you! just kidding.
Old 06-12-2014, 02:47 PM   #11
Hankster
Hankster's Avatar
I like the truck, I'll be following this one!
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 )
Instagram- shaggin_c10
Hankster is offline   Reply With Quote
Old 06-16-2014, 07:33 PM   #12
2000Limited
I got some parts for the stroker build today. I got the heads and the engine bolt set. I'll post pics in a lil while
Old 06-17-2014, 08:34 PM   #13
2000Limited
Here are the packages I received yesterday 6-16-14.
Old 06-17-2014, 08:43 PM   #14
2000Limited
And here are all the stuff I received today
Alum Air Filter
Valve covers
Comp Cams Cam and lifter set
Timing chain
Push rods
ARP main bolt set
Comp Cams break in additive
1.5 Self Aligning Roller Rockers
Rough Country Front ext brake lines
Old 06-17-2014, 08:48 PM   #15
2000Limited
I received a call from the company I ordered my rotating assembly from, they shipped it out today.
Old 06-18-2014, 11:54 PM   #16
2000Limited
Questions, comments, snid remarks. any and all comments welcome
Old 06-19-2014, 12:45 AM   #17
2000Limited
I received my Edelbrock Intake and Carter Electric fuel pump today.
Old 06-23-2014, 11:45 PM   #18
2000Limited
New parts came in over the weekend!
Pictures
1. Pro Street Harmonic Balancer
2. King Main and Rod Bearing, Hastings Moly Rings, Melling Oil Pump w/ext pick up.
3. Scat Stroker Crank
4. Dist w/ coil
5. Accel 8.8 plug wires
Old 06-24-2014, 05:09 AM   #19
2000Limited
6. Scat Flexplate
7. 7qt Zinc Oil Pan
8. Probe .060 Pistons and Scat rods w/ ARP bolts
9. Alum Timing Cover
Old 06-25-2014, 01:09 AM   #20
Hankster
Hankster's Avatar
Looks like you got quite the parts pile! I can't wait to start playing around with my 454
Old 06-25-2014, 02:57 AM   #21
2000Limited
The fun hasn't even started yet! I'm going to try and take the front end off this weekend.
Old 07-01-2014, 06:37 AM   #22
2000Limited
I got the front end off the truck, and got the 305 that was in it out. I also used my new toy, an electric power washer, to clean all the grease and dirt from the frame and engine.
Old 07-01-2014, 07:04 PM   #23
Hankster
Hankster's Avatar
Sweet! One step at a time!
Old 07-02-2014, 08:33 PM   #24
2000Limited
more pics
Old 07-02-2014, 08:41 PM   #25
2000Limited
Gasket Set
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
