Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 08-04-2003, 02:52 AM   #1
Solver
Solver's Avatar
Neutral saftey on van column
Just moved neutral saftey on my van column and thought I'd post what it took.I got a 68-72 column at swap meet today so I finally had a template to go by.Needed air cutoff tool , dremel cutoff tool, magnet,and 9/64" drill bit
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline
Old 08-04-2003, 02:55 AM   #2
Solver
Solver's Avatar
I first drew center line from top of column tube to the notch at bottom of shift mech. Then measured up 5 1/2" from notch in shift mechinism for the bottom end of neutral notch.
Solver is offline
Old 08-04-2003, 02:57 AM   #3
Solver
Solver's Avatar
Next drew 5/8" wide lines and 1 1/16" long in each direction from center line
Solver is offline
Old 08-04-2003, 02:59 AM   #4
Solver
Solver's Avatar
Used a regular air cutoff tool to cut out the hole . Didn't have to worry about the lenght of lines to much as the switch hides the overlap.
Solver is offline
Old 08-04-2003, 03:01 AM   #5
Solver
Solver's Avatar
Next I marked off the inside slot. I found it to be just a 1/16" off the center line, The full 5/8" of your first cut and 3/8" or slightly wider for the tang of the switch to fit in
Solver is offline
Old 08-04-2003, 03:04 AM   #6
Solver
Solver's Avatar
I used cutoff tool for the perpendicular cuts but had to use a dremel cutoff wheel to get down into the tube for the straight cuts. I found my dremel wheel was just alittle large to go down in but after grinding for a few seconds the wheel shrinks down enugh to get in.
Solver is offline
Old 08-04-2003, 03:11 AM   #7
Solver
Solver's Avatar
I used a small magnet to pickup any filings that fell in (not sure if thats a concern or not. Once the inner hole was cut I just set the switch in and Drilled 2 9/64" holes for the switch in the center of the elongated switch holes and bolted it back down. The colmn I got today was an original tilt and thats where I got the 5 1/2" measurement from. I have not got it mounted in the truck yet but its now the same as a factory tilt as far as location so don't know why it wouldn't fit.
I just posted this cause I have been setting on my column and thought maybe some of this info could help someone else
Solver is offline
Old 08-20-2005, 10:57 AM   #8
86swb
Born a Chevy Man
86swb's Avatar
What about the old safety switch hole. Do you leave it open or close it up? Or does it really make a difference?
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline
Old 08-20-2005, 01:40 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I cover them with electrical tape or leave them open, either way.
Kevin -
My Instagram
Tx Firefighter is offline
Closed Thread
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
