Old 06-29-2014, 08:18 AM   #1
bj383ss
bj383ss's Avatar
Manual Gear Box Grease
So I replaced all the seals in my manual steering box and cleaned out all the old grease. Can I use regular grease like for suspension or wheel bearing grease? I did a search but only found grease as answer. Also how full do I fill it?
thanks for the help,
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 06-29-2014, 10:42 AM   #2
Wrenchbender Ret
Re: Manual Gear Box Grease
If the seals are good use gear lube, like 85-140 GL-5. Fill it to the top of the plug opening.
Wrenchbender Ret is offline   Reply With Quote
Old 06-30-2014, 08:39 AM   #3
1963c-10
1963c-10's Avatar
John Deere corn head grease works great also. Can order on line or at the dealers....let it sit in the sun a little and it'll go right in. Around $3-4 a tube.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-30-2014, 09:24 AM   #4
slorio
slorio's Avatar
One comment on this:
85-140 GL-5 Gear Lube
You need to read the bottle to make sure it is safe for "yellow metals" when you are using it in transmissions. The yellow metals would be your brass synchronizers. Not all of the GL 5 Hypoid Gear Lubes are safe. I have found that only the more expensive lubes have this characteristic.
Regards,
Steve
New Orleans
slorio is offline   Reply With Quote
Old 06-30-2014, 10:54 AM   #5
padresag
80 - 90 wt hypoid gear oil the old std gear oil) is all that you should use in there . grease "should" not be used in there.
ron
padresag is offline   Reply With Quote
Old 06-30-2014, 11:15 AM   #6
WhippinSaw
WhippinSaw's Avatar
napa sells sta-lube "gl-4" gear oil, I think thats what the service manual calls for, just to be safe. I saw somewhere that GL-5 attacks yellow parts. They also might make a synthetic oil that would work.
Good luck
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
