07-02-2014, 09:24 AM | #1 |
Clifford Exhaust Mani Install
I bought a Clifford exhaust manifold (http://www.cliffordperformance.net/M...gory_Code=C250 ) for my 66 C10 (250 i6). Will it install correctly with my original intake? Or do I need to wait until I get a new intake?
Thanks guys! |
07-02-2014, 09:42 AM | #2 |
Re: Clifford Exhaust Mani Install
You will need an aftermarket intake to run the headers.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-02-2014, 10:32 AM | #3 |
Post Whore
You can use the stock intake manifold if you can find a way to water heat it...I believe Langdons Stovebolt.com makes a water heating plate for the 1 barrel intake manifold..if not..its for the offenhouser. What are you doing to the engine? Are you doing head work? And thing to the bottom end? I can give you a ton of info if I know what you want...the type of carb you use is fairly critical pending on what you do. Pm me or let me know.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
07-02-2014, 11:28 AM | #4 | |
07-02-2014, 12:43 PM | #5 |
Thanks guys! I am looking to upgrade the intake and exhaust manifold to get full dual exhaust. Looking to upgrade the horse a little bit, but I want it to sound good. I have the manifold and was hoping that I could install it now instead of waiting until I determine the exact set-up I want on the intake and carb.
07-02-2014, 05:38 PM | #6 |
These are pictures of the engine at the moment...
07-02-2014, 08:34 PM | #7 |
the only thing you will have to do is grind the little acorn fasteners that hold the intake and exhaust together. this is because the thickness of intake and exhaust are different thicknes or you can grind the manifold or exhaust down to match. i never had manifold heat on my 250 and it ran fine. edelbrock manifold and 390 holley carb. but i live in cali.
07-03-2014, 12:05 AM | #8 | |
Post Whore
