Old 07-04-2014, 02:32 PM   #1
Metalaroundstone
Question about sealing seams on cab
I have had several leaks that have penetrated through the plenum assembly that goes across the front of the truck just in front of the windshield. Many of these leaks caused rust inside my cab (cowl) up underneath the dash. All this was damage was very hard to cut out and repair since I am not doing a frame off restoration. IMO the plenum system is extremely problematic in terms of the longevity of the cab. The air intake grill essentially allows anything smaller than a field mouse to fall into the plenum which then either gets stuck in the plenum or on the little sills above the air vents, or at the top or bottom of the fender.
Question #1: Has anyone figured out an attractive way to reduce the crap than fall into the plenum.
Question #2: Shouldn't I use seam sealer on the joints between the firewall and the plenum assembly? I can't tell it this joint was sealed from the factory. See pic below.
Question #3: Should I use seam sealer on the joints between the plenum and the cowl. See pic below. I don't think this joint was sealed at the factory (except for the vertical one), but it seems to me it might be helpful to seam seal this joint except for the area behind the windshield wiper stubs. Opinions appreciated about this.
I also included some photos of my process of fixing the rust in the plenum, staring with cutting a access hole, cutting out metal, replacing metal, and welding up the access hole. Even though the work was in an area that will never be visible to the eye, when I was finished you could not tell it was not from the factory except for the seam sealer I added.
Metalaroundstone is offline   Reply With Quote
Old 07-04-2014, 02:57 PM   #2
earl84
Re: Question about sealing seams on cab
Seems like it should have been sealed. I don't know who did it, but I have seen the grill part all sealed off by welding in fresh sheet metal in place of the grill. Of course, the kick panel vents will be non-operational at that point.
You did nice work on that repair, BTW.
earl84 is offline   Reply With Quote
Old 07-05-2014, 10:24 AM   #3
joesscamaro
I'm right there with you. The second picture you posted is where mine was leaking and it caused some rot on the inside of my cab also. Without blowing the cab apart, there seems like there's nothing you can really do. I wire wheeled those seems, sprayed some rust converter, primed and painted, and then I'll seam seal them when all is said and done. Hopefully that'll solve the issue. Good job on the repair!
joesscamaro is offline   Reply With Quote
Old 07-05-2014, 11:36 AM   #4
Woogeroo
this is an option... or a product like it :
1960 GMC Suburban post #194
-W
Find answers for your 1960-1966 Chevrolet Truck Questions.
Matraca - my 1965 Chevrolet C10 lwb step side
I am unable to reply to send/reply Private Messages since October 2014, so I am not ignoring anyone. Please visit my linked pages above if you wish to ask me anything... I am no longer welcome on the forum, it is a simple fact, nothing more. shadowbanned!
Woogeroo is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
