Old 07-06-2014, 07:42 PM   #1
mooseknuckles
mooseknuckles's Avatar
Owen's C10
So I picked up this beauty Saturday as project to work on with my son. It was sitting in the neighbours back yard for the last 10 or 15 years, maybe more....lol. It's pretty rough, but I've seen a lot worse, and since I only paid $100 if I start to feel like it needs too much work I can just push it aside...
mooseknuckles is offline   Reply With Quote
Old 07-06-2014, 07:42 PM   #2
mooseknuckles
Re: Owen's C10
slammed!
Old 07-06-2014, 07:43 PM   #3
mooseknuckles
Re: Owen's C10
I'm not 100% sure of the year, the cab and front end lead me to believe it's a 68, and all of the red parts on it are from a GMC of roughly the same year. there's a 920 badge on the left fender...the chassis has 8 lug wheels and a strange rear end with a bolt in center section and a bolt on diff cover, the neighbour says he has the ownership somewhere...
Old 07-06-2014, 07:46 PM   #4
mooseknuckles
Re: Owen's C10
gutted the interior and ripped the box off, also cut all the springs out to keep me motivated...lol. floors, mounts, rockers, and cab corners are gone, but the rest is pretty decent, I'll know more when I pull the front clip off, but so far the windshield area, cowl, and firewall look good.
Old 07-06-2014, 07:47 PM   #5
mooseknuckles
Re: Owen's C10
the frame gets rusty from the axel back which also makes it a good candidate for a step notch and back half. I also want to make it into a short bed truck.
Old 07-06-2014, 08:21 PM   #6
71swb4x4
71swb4x4's Avatar
Re: Owen's C10
If the blue front fender is original it's a 67. The cigarette lighter is a 67 only piece as well.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-06-2014, 08:52 PM   #7
mooseknuckles
Re: Owen's C10
67 because of not having the side marker light right?
Old 07-06-2014, 09:24 PM   #8
71swb4x4
71swb4x4's Avatar
Re: Owen's C10
Yes. And the small window cab is the biggest clue, 67 was the only 67-72 year when you could get the small window in the 1/2 ton - 1 ton series trucks .
Old 07-06-2014, 09:28 PM   #9
mooseknuckles
Re: Owen's C10
so any idea on the goofy looking rear end? wtf is it?
Old 07-07-2014, 12:18 AM   #10
NurseBen
NurseBen's Avatar
Re: Owen's C10
Looks like an Eaton HO52
NurseBen is offline   Reply With Quote
Old 07-07-2014, 08:36 AM   #11
67chevy1series
67chevy1series's Avatar
Re: Owen's C10
The red parts are 68 gmc and as stated above the rest of the truck is 67, the ignition is 67 only the fire wall is a little different from 68-72 as well lots of little things are different on 67's compared to 68-72
67chevy1series is offline   Reply With Quote
Old 07-07-2014, 08:48 AM   #12
mcbassin
Still Learning
mcbassin's Avatar
Re: Owen's C10
Looks like a nice build. I'm in
mcbassin is offline   Reply With Quote
Old 07-08-2014, 05:50 PM   #13
mooseknuckles
Re: Owen's C10
question: will my 86 stock control arms bolt up to the 67? that way I could use my old arms, spindles, and brakes, then I could put some normal wheels on it. well on the front anyway.
Old 07-09-2014, 10:05 PM   #14
mooseknuckles
Re: Owen's C10
I'm gonna pull the cab off this weekend so I can work on the frame, I got a notch ordered for it, and also the cab floor needs some work!....actually it needs a new floor. then I need to look for a rear end....
Old 07-13-2014, 05:41 PM   #15
mooseknuckles
Re: Owen's C10
So we got quite a lot done this weekend, I had some really good help....got the front end off....
Old 07-13-2014, 05:44 PM   #16
mooseknuckles
Re: Owen's C10
next went the cab, and the old 283...
Old 07-13-2014, 05:48 PM   #17
mooseknuckles
Re: Owen's C10
long bed to short bed conversion.
Old 07-13-2014, 05:52 PM   #18
mooseknuckles
Re: Owen's C10
welded back together..... I just welded the outside for now till I figure out what to do for the bodydrop...
Old 07-13-2014, 05:59 PM   #19
mooseknuckles
Re: Owen's C10
Owen workin hard cleaning up the crossmember.....cut the rear cab mounts, bed mounts, and old tranny member off, then cleaned the frame up a little with the grinder, and gave it a quick coat of paint. I'll probably get my bro to sand blast everything when we get finished with the frame...
Old 07-13-2014, 06:05 PM   #20
mooseknuckles
Re: Owen's C10
she's now a 67 c20 short bed! I also gave the cab a good degreasing and wash job.
Old 07-13-2014, 06:19 PM   #21
mooseknuckles
Re: Owen's C10
8 lug drum to 5 lug disc conversion....I used the old control arms and spindles off my c10 and swapped them to the 67...glad I saved that crap!...I was surprised at how easily it came apart after 40 some years....hopefully I can get some drop spindles and some rotors this week, and I can use the old calipers, then get the front wheels bolted up.
Old 07-13-2014, 06:28 PM   #22
mooseknuckles
Re: Owen's C10
found a 10 bolt rear end from a Camaro that my bro had lying around, actually the same rear end I got the posi and gears out of....according to my calculations the Camaro rear is roughly 3" narrower than the 12 bolt in the 69...that should make for a nice wide wheel! now just need new axles or have them re-drilled...
Old 07-14-2014, 03:52 PM   #23
mooseknuckles
Re: Owen's C10
what colour is 536?
Old 07-15-2014, 10:24 PM   #24
mooseknuckles
Re: Owen's C10
got a sweet deal on a pair of rust free cali doors...I'll be picking them up this week!
Old 07-15-2014, 11:42 PM   #25
Slammed66
Needs a Big Block
Slammed66's Avatar
Re: Owen's C10
I'm in, your square body is rad, this will be even better!
1964 short step Dropmember, 8 inch step notch ,4 link and running a carbed 5.3/ th400 on 18's an 20's. may drive again some day.
check its rebuild here.Project: TALL GRASS
http://67-72chevytrucks.com/vboard/s...d.php?t=449019
1972 long fleet 26,000 original miler , bagged with accuair on 20" Coys
1968 Camaro SS/RS relaxing
1978 BIG 10, long 4/5 drop on rallys relaxing
1987 long fleet relaxing
1998 Reg Short Z71 Black, n chrome daily beater
2012 Sierra crew short. All black 6.2 shiny
Slammed66 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
