Old 07-26-2014, 05:26 PM   #1
tjsblazer
tjsblazer's Avatar
My SBC 383 Build.
Sooooo, after much back and forth about what Engine I was going to build for my K5 restoration I am doing, I decided to go with the common 383 stroker. I had debated about getting in to a 421 on a Dart shp block but I just don't need it for this vehicle. It is going to be a sunny weekend family cruiser. The 383 will save me a little bit of $ and be plenty of get up and go. Finding a late model OE roller block with 1pc rms local for a great price was final decision maker for me.
So here is my parts list so far:
1989 One pc rms, roller block. 4 bolt with mech fuel pump provisions.
Eagle forged Crank. Cut for internal / internal balance.
Scat forged procomp Rods. 5.7 inch.
Mahle forged Pistons. Reverse dome. -16cc.
AFR Eliminator street Heads. 195 runner. 65cc intake.
Comp Cams Ultra pro magnum roller Rockers. 1.5.
Trend Performance pushrods.
Edelbrock Performer rpm air gap Intake.
Quickfuel SS carb. 680cfm. Vacuum secondaries.
Cloyes Hex adjust Roller timing chain.
Ram Clutches billet steel Flywheel. Neutral balance.
Pro-Race steel Harmonic Balancer.
MSD pro billet Distributer.
All ARP hardware and Fel-Pro gaskets.
Cam. OE Hydraulic roller style. I know the ballpark lift and duration I am looking at but haven't picked exactly yet. I am looking at many including Comp, Lunati, Howards and Crower. I've also been looking through the Bullet lobe catalogue a bit ...
Some recent shopping. About 1/2 of the eye candy.
[IMG][/IMG]
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 07-26-2014, 05:36 PM   #2
tjsblazer
tjsblazer's Avatar
Re: My SBC 383 Build.
Block was hot tanked and checked for cracks. All good. When we took the factory rotating assembly out it looked great. Bearings all nice even wear patterns and no bad coloring anywhere. I spent a few hours on the block grinding some of the external parting lines out and wire wheeling in the tight spots. Sorry, forgot to take any pictures.
Mahle specs show to run these pistons clearances fairly tight. I am very impressed with the power pak forgings. For this part number they recommend .0025 - .0033. I'm shooting for a final hone right in the middle at .0029 clearance. Nice ... No cold start up slap.
Just did a quick mock up to see where the deck is sitting. 4 corner check and it is within .002 thousand so pretty good starting condition. With the new rotating assembly the Pistons are sitting around .028 - .029 in the hole. I'm going to take .025 off to get the pistons sitting around .004 in the hole. Using a 1010 gasket will give me a final quench of .043 thousand. Right in the pocket for a street build.
[IMG][/IMG]
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 07-26-2014, 05:40 PM   #3
tjsblazer
tjsblazer's Avatar
Need a little clearancing on the bottom end for the Crank counterweights and 2 bores need a little clearancing on the bottom for the rods but that is it. These newer style blocks have the bottom of the cylinder bores brow cut up a little higher compared to old school first gen. and with the stroker rods, less massaging is required when going to a stroker build.
[IMG][/IMG]
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 07-26-2014, 05:46 PM   #4
tjsblazer
tjsblazer's Avatar
Block just went to the machine shop for Final hone and Decking. Pick it up in 2 weeks.
More to follow then ...
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 07-26-2014, 07:09 PM   #5
DBD
Boy, that's a great setup with all the right parts and machine work!
DBD is offline   Reply With Quote
Old 07-26-2014, 07:28 PM   #6
geezer#99
geezer#99's Avatar
Finally!!
A well thought out engine assembly!!
Go conservative on the cam and it'll be perfect.
Old 07-26-2014, 07:45 PM   #7
tjsblazer
tjsblazer's Avatar
Originally Posted by geezer#99 View Post
Finally!!
I appreciate that. I have certainly had some help along the way. Yes Cam selection will be key. I'm will be running a 5spd manual (NV4500) so I have a little bit of room for duration but need to keep it suitable for upwards of 4500lbs of truck.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 07-26-2014, 08:01 PM   #8
geezer#99
geezer#99's Avatar
I say conservative but my rule of thumb has been to pick the cam I think I'd like or has been recommended and then go one or two steps milder.
Cam choice is one place where "More's Law" doesn't work.
More's Law means 'If some is good, more is better'!!
When it comes to cam choice, usually less is better.
Old 07-26-2014, 10:06 PM   #9
tjsblazer
tjsblazer's Avatar
I'm happy with the direction for sure. Hoping it will pull strong.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 07-27-2014, 10:27 PM   #10
89DEKE
Hey bro I was wondering if you had any idea what the hp/tq numbers may be, the reason I'm asking is I have a '89 silverado with the stock tranny and was told that it wont hold the 383 I'm planning on buying at the beginning of next year. The #'s for the 383 I want are 440hp 460tq and if I could use a nv4500 that would be great. Tremec is more $ then i wanted to spend. Any help would be appreciated.
89DEKE is offline   Reply With Quote
Old 07-28-2014, 12:14 AM   #11
tjsblazer
tjsblazer's Avatar
Well Cam selection which I haven't 100% decided will determine a lot. I will probably Cam to prioritize torque and shoot for it to peak no higher than 4000rpm. With that said I am hoping for 470 ft lb range. I'm not too concerned about the HP numbers but I am assuming they would come out around the 430 range. We have to do some actual accurate cc calculations on the next mock up after the block is all machined to get the accurate compression ratio but it should be in the 9.8 neighborhood. Many dyno proven builds you can Google and numbers in the 450+ ranges are not too hard to achieve. I have no idea about your tranny strength. I will be running a fresh NV4500. I am pretty sure in my case the tires x pavement will be breaking before anything else.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 07-30-2014, 10:49 AM   #12
89DEKE
Thanks for the reply bro will definitely be following your build
Old 07-30-2014, 11:37 AM   #13
D.PASSMORE
One of the First
D.PASSMORE's Avatar
What did the engine come out of? Or how about a block number?
**1989 One pc rms, roller block. 4 bolt with mech fuel pump provisions
Interesting build, I will follow...
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 07-30-2014, 03:56 PM   #14
tjsblazer
tjsblazer's Avatar
Came out of a 89 truck. That is why it is a 4 bolt and has the mechanical pump provision. It was actually a tappet cam in a truck but the blocks are still drilled properly to fit a factory roller cam. GM drilled them all at machining time because they didn't know the final vehicle destination at that point in the process. I can get a block number if you want but it is just at the machine shop right now for another week or so.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 07-30-2014, 05:42 PM   #15
haysonj
haysonj's Avatar
I started my 385 with the same basic block as yours. Mine came from a 93 3/4 ton van and was a TBI engine
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 07-30-2014, 06:29 PM   #16
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Finally!!
I was thinking the exact same thing.
Looking forward to seeing this to completion.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
GASoline71 is offline   Reply With Quote
Old 07-30-2014, 09:42 PM   #17
D.PASSMORE
One of the First
D.PASSMORE's Avatar
If you can, I've been playing with the notion of running a roller cam in my Blazer - OE GEN1 motor, not to sold on the retro kits. I will look around in the junk yards / craigslist for a good donor. Your expectations and setup for your build is what I'm looking for too. I've squeezed about everything I can out my OE 350 without major overhauls. This route sounds like a lot more fun. Thanks
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 08-01-2014, 08:46 PM   #18
duallyjams
PICS IM MY PROFILE
duallyjams's Avatar
Great thread
James
2002 GMC cc dwr sporting alcoa D-max 22MPG
63 GMC V6 4speed carryall
64 GMC lwb 3/4 V6 4speed seeking factory optionSOLD
65 chevy swb bbw V8 auto
66 GMC swb bbw buddy bucketsSOLD
68 K20 327/4 speed, buddy buckets
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 08-07-2014, 10:39 PM   #19
tjsblazer
tjsblazer's Avatar
Picked up the Block today from the machine shop all honed and decked. Ready to rock. Did a mock up again of the rotating assembly. This time all 8 slugs. They are all bang on .004 in the hole. With the Fel-pro 1010 it will put the quench at .043 so very respectable for the street and no worries on Cam timing.
Final hone just what we wanted at .0029 over piston size. Hopefully get the heads cc'd this weekend. I mostly read the AFR heads are pretty much bang on advertised but gotta check to know for sure. You can always get a lemon.
Couple pictures to keep it interesting.
[IMG][/IMG]
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 08-07-2014, 10:43 PM   #20
truckdude239
truckdude239's Avatar
pretttyyyyyyyh
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-11-2014, 08:22 PM   #21
tjsblazer
tjsblazer's Avatar
Did an old school water cc check on the Head chambers and Pistons in the bore. Wanted to see how close the numbers are to published.
In the end the 65cc AFR heads came in at 64.6cc.
The piston in the bore is a little subjective trying to capture cc including down to the compression ring. The 16 cc Mahle piston came in at 17.5cc set .004 in the bore. It think the piston machining is bang on the 16cc.
Ran a bunch of different calculators but I'm settling in at 9.69 compression. Pretty darn close to the 9.73 projected on paper. Really just a gut check to make sure nothing was way off of published specs.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 08-11-2014, 08:26 PM   #22
tjsblazer
tjsblazer's Avatar
Next steps are to get the Rotating Assembly balanced, Check the Intake to the Heads for alignment now that the Deck is machined and get a Cam and Lifters ordered ...
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 08-11-2014, 08:46 PM   #23
jjzepplin
jjzepplin's Avatar
I'm IN!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-11-2014, 11:08 PM   #24
Average Joe
Average Joe's Avatar
Nice build
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 08-29-2014, 05:44 PM   #25
tjsblazer
tjsblazer's Avatar
Some progress. Did a mock up to set main and rod clearances. Took a couple of different bearing sets to get what we wanted. This is what we ended up with on a 82 F day.
Runout measured .008
Crank endplay is .005
Main clearance is set up between .0017-.0019
Rear main set at .0025
Rods came in at .0022
Based on these I'm going to run Std volume / Std pressure oil pump. Going to use the Melling Select series.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Thread Tools
Display Modes
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
