Old 07-27-2014, 04:44 PM   #1
Towmater454
1960-1966 GMC headlight adjuster kit
I couldn't find any kits online so here is what I used that fit perfectly.
1958-1982 Corvette Headlight/Headlamp Adjuster Kit 244005
Use 5/32"dia rivets if available, I used 1/8" because I couldn't find any 5/32" at the stores i went to. I used 1/2" long which I had to drill 1/8" holes in some bracket behind the horizontal adjuster holes that kept the rivets from going in far enough. Some of these kits come with nuts/bolts for installation but I believe the whole assembly would have to be removed in order to use them so I would do the rivets. Installation was a lot quicker than finding parts that fit so hopefully this will save someone else some time.
I saw some posts that suggested using thread extenders or threaded couplers, I had purchased some but needed the bolts that came with this kit and i'm glad I took the chance.
Towmater454 is offline   Reply With Quote
Old 07-27-2014, 04:53 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 1960-1966 GMC headlight adjuster kit
Thanks for posting this.
My 65 has a GMC Grill.
66 Service truck build:
Old 07-28-2014, 05:46 AM   #3
Dismas
My headlight adjusters were all broken, But I just went to pick and pull and yanked some from a late 70's early 80's chevy. worked just dandy
Dismas is offline   Reply With Quote
Old 08-17-2014, 11:03 AM   #4
ljackson
ljackson's Avatar
Thanks for the post. Just picked up a GMC grill to put on my '64 Chevy. What did ya'll do for headlight wiring?
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
