Old 07-28-2014, 04:59 PM   #1
no1udknow
no1udknow's Avatar
68 c10 2wd in Sacramento, CA
hey guys, I joined this forum for another project I was going to do. I had a 58 swb step, but it had a lot of issues including back fees. I had paid 1000 for it and it was something my dad and I were going to do together. My dad passed away the day before easter and when I was a child, he had a 71 lwb fleet side from the time I was 2 till I turned 25 and it caught fire. It is probably kicking around in a junk yard or someones garage by now so I found this 68. I find it funny looking back now because as a teenager, I had 4 of these trucks including a 67 lwb with factory air. After my dad passed, I really wanted another so I traded my 58 project for this 68 project. The 68 is running, titled, and currently registered. I had many good memories in my dad's old truck and opening the door to my 68 brought them all rushing back. I am very excited about this project and although I will not make it look exactly like his old truck, I know with my son, it will be a memory maker. It has been in an accident. It was parked on the side of the road in the snow where it was broad sided and sent into a ditch. Mostly sheet metal damage and the front left steering knuckle which I am replacing anyways.
plans:
Short bed conversion
lower 2-4 inches in the front
disk brake upgrade
transmission swap (current th350)
rear end gears or rear end swap (current 4.11's and the truck comes with a 3 mile long hose to tether it to a gas pump)
sheet metal repair
and paint inside and out. (it is currently a blueberry color and I hate it)
i know, i know pics right ;-)
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 07-28-2014, 05:22 PM   #2
Hardesty454
Hardesty454's Avatar
Re: 68 c10 2wd in Sacramento, CA
Good start. I see some panel replacement in the future.
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 07-28-2014, 11:01 PM   #3
67chevy1series
67chevy1series's Avatar
Wow! Man you got lucky that they missed the cab! To bad though 67 besides and fenders are getting harder to come by with each passing year...
67chevy1series is offline   Reply With Quote
Old 07-28-2014, 11:36 PM   #4
Saclandman
Saclandman's Avatar
Glad to see another Sac-area member. Good luck with your project.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 07-29-2014, 11:24 AM   #5
no1udknow
no1udknow's Avatar
I actually have a 67 at the house with good fenders and bedsides. It has a little cancer in places, but I am going to cut some of the panels from the cab and use them to repair my 68.
Built not bought!
Old 07-29-2014, 12:06 PM   #6
jimbosprint
jimbosprint's Avatar
Nice! I bought my truck in Orangevale a week ago. It also needs a little body work. (Links in my sig below if you want to check it out.)
jimbosprint is offline   Reply With Quote
Old 07-29-2014, 12:18 PM   #7
no1udknow
no1udknow's Avatar
Have you talked to the guy in citrus heights with the c10 wrecking yard? He has ads all over craigslist for c10 parts. I've talked to him a few times, pretty nice guy and pretty knowledgeable. He specializes in old c10s from the 60s through the square bodys
Built not bought!
Old 07-29-2014, 12:47 PM   #8
jimbosprint
No, I'm a hundred miles north of there. (and mine's a c20)
Old 08-01-2014, 04:02 PM   #9
no1udknow
no1udknow's Avatar
so I got the bed and front end pulled off today. I'm picking up the replacement front suspension this weekend.
Built not bought!
Old 08-01-2014, 04:11 PM   #10
Hardesty454
Citrus Heights is right out of sac? You area says you live in sac. Also the only difference between a c10 and 20 is the heavier suspension and they are all long beds. Just an FYI.
Rob
Old 08-01-2014, 07:21 PM   #11
no1udknow
no1udknow's Avatar
Yes, I am I'm the Sacramento area, but he is in Chico, that's quite a ways away.
Built not bought!
Old 08-03-2014, 12:23 AM   #12
no1udknow
no1udknow's Avatar
Woot. Got me new front suspension. I was given an 86 c10 heavy half when I was starting my58 project. I was going to use it as a frame donor but since I'm not doing that truck I no longer needed it in tact. It only has 79k miles on it, so today a friend and I to the front clip, pulled the motor and trans to go in his 86 4x4 and then pulled the front suspension and full brake system to be swapped into the 68. And as A bonus, I found a local guy that has a set of 6 lug CPP rotors for $40.
Built not bought!
Old 08-05-2014, 10:40 AM   #13
no1udknow
no1udknow's Avatar
Got the cab off yesterday. Getting ready to do the suspension/crossmember swap and the frame chop. Picked up some oven cleaner, that plus the steam cleaner we have at work should take off most of the road grime then I will touch up with some black paint.
Built not bought!
Old 08-05-2014, 10:41 AM   #14
no1udknow
no1udknow's Avatar
Built not bought!
Old 08-07-2014, 09:24 AM   #15
no1udknow
no1udknow's Avatar
On Wednesday I used some oven cleaner, and the diesel steam cleaner we have work to clean up the chassis and engine on my lunch break. Then after work I pulled the engine and trans to prepare for the frame shortening and the front suspension swap.
Built not bought!
Old 08-07-2014, 09:39 AM   #16
no1udknow
no1udknow's Avatar
Thursday I laid out the cuts for the shortbed conversion.
I measured 4" forward from the front rivet of the rear cab mount. That's where I made my 1st line. I then measured 12" forward and made my 2nd line. then I measured 12" forward from the 2nd line to make my 3rd line.
I then measured 3" down from the top of the frame rail,(since it is a 6" tall rail) and made marks about every 6" and connected them with a straight edge.
I then used a Teflon tape roll to radius the corners of the cuts (learned that from Stacy David's Gearz), and marked out the pieces that I was going to cut out.
Next I took the Teflon tape roll over to my hole saw kit and found a hole saw that matched the outer diameter. (in my case I believe it was a 2") Note: you could always use the hole saw of your choice to mark the radius cuts in the corners. I cut out my radius cuts first by removing the pilot bit from my hole saw, lining it up with the lines, and sliding a small punch down the pilot bit hole to make a centered mark.
then I simply cut out the rest with a sawzall. I made my cuts flipped from each other to increase strength, but it makes it harder to line up.
Built not bought!
Old 08-07-2014, 09:53 AM   #17
no1udknow
no1udknow's Avatar
Next I lined it all back up... which was not as easy as it looked on the episode of Gears Note: if you are attempting to line up a frame for welding, ensure all of your tires are the same size and have equal air pressure! For the life of me I could not figure out why it would not line up to the point I was worried the frame was bent. Then I remembered I had to put a different tire up front due to a flat I got while loading it on the trailer. it was causing the front portion of the frame to torque to one side.
finally with the use of clamps, and vice grips, I was able to get it lined up. I measured length on both sides from specific points, and diagonally from the same points. It took some grinding and adjusting, but I got the lengths within less than a 1/16th of an inch and my diagonal measurements right at 1/16th difference. Note: as I said, it will not line up as easy as you think. unless the cuts are being made by a robotic arm, it is near impossible to get it perfect but take your time and grind a little at a time to make things line up. measure twice, cut once is a good idea, but I measured about 30 times. no one wants a truck that goes down the road crooked or eats up tires. Also, think about the tool or pen you will use to mark out your lines. I used a paint pen and it was a little fat, so I cut to the side of the line that was the throw away piece and the ground it to where I wanted it.
I got it all lined up and welded it back together. I welded short 1 inch spots so as to not over heat the metal and warp it. So I would weld an inch, skip 2 inches, weld another inch, skip 2 etc. I was able to weld the whole seam in 2 or 3 passes like this.
in this picture you can clearly see where I started each 1 inch pass.
More to come.....
Built not bought!
Old 08-07-2014, 09:57 AM   #18
no1udknow
no1udknow's Avatar
Saclandman, where are you located. I am down in Galt, but i work in Rancho.
Built not bought!
Old 08-11-2014, 09:31 AM   #19
no1udknow
no1udknow's Avatar
Big score this weekend. Craigslist has been good to me. I picked up a set of early classic 6 lug rotors for $40 and a set of centerline knockoffs with 3 brand new and 1 used 275/60/15's for $50
Built not bought!
Old 08-11-2014, 10:15 PM   #20
no1udknow
no1udknow's Avatar
Out with the old, in with the new. Did the front suspension and disk brake swap. Very easy. The 85 cross member nearly bolted right in. I had to Willow out the holes in the side of the frame a bit and drill one of the holes.
Here's the old drum kit
Here's the cleaned up, rattle canned, disk brake setup from the 85 c10 donor along with the freshly installed 6 lug rotors from early classic.
Built not bought!
Old 08-12-2014, 04:28 PM   #21
Saclandman
Saclandman's Avatar
I'm in Natomas, and the truck's in W. Sac. Nice work on the frame. I'm keeping mine long.
Rich J.
Old 08-12-2014, 04:36 PM   #22
no1udknow
no1udknow's Avatar
I might have a passenger bed panel for you if your interested. It is the one in the first set of pictures that is sanded/primered. It has a slight dent in the body line over the wheel well, but other than that its fairly straight. I have another bed that has better panels that I am going to utilize. But I saw yours was pretty munched. After I am done plucking the parts from my 67 parts truck I will be putting the leftovers up for grabs and then junking the rest or giving it away.
Built not bought!
Old 08-12-2014, 04:56 PM   #23
Saclandman
Saclandman's Avatar
Thanks. I'll keep that in mind.
Rich J.
Old 08-13-2014, 02:56 AM   #24
jimbosprint
I might be interested in that passenger bed panel too. Please let me know.
Old 08-13-2014, 02:11 PM   #25
no1udknow
no1udknow's Avatar
oh... my bad saclandman, it was jimbo sprints truck I was looking at with the munched passenger bedside.
yah, jimbo sprint, I have a passenger bedside that is in a little better shape than yours, it does have a mild crease through the body line going over the rear wheel. If you want it, I will let you know when I pull it.
I also have a complete drum brake front suspension left over from my 68, it has a bent drivers side steering knuckle and needs bearings, but if someone needs it, they are welcome to it. it has the cross member, a-arms, springs, all steering arms and pitman arm, drums, and brake lines. first come first serve, pick up only not gonna ship it. if not I'll take it to the scrap yard or the c10 recycler guy here in sac.
Built not bought!
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
