Old 09-06-2014, 11:34 AM   #1
scuderia
scuderia's Avatar
How to assemble bed?
So got my truck with the bed in pieces and have just scored some original wood and need to start the process of putting it back together. I hear guys say it's best to remove the bed to install the wood so I figure I'm one step ahead.... Then I see photos of what looks like the entire bed assembled but just not on the frame?? Can someone shed a light on the easiest way to assemble.. Thank you
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 09-06-2014, 12:11 PM   #2
earl84
Re: How to assemble bed?
Probably easiest with the bed off and standing up. This is due to having easy access to the 100,000 nuts that hold it all in place. Laying on your back with all the frame and suspension in the way is not easy or fun. That's the way I was forced to do it because I work alone, and it took me every bit of 8 hours to do it.
You will have to have some help to then lift it onto the frame, either people or an engine hoist with some type of apparatus to attach to the bed.
earl84 is offline   Reply With Quote
Old 09-06-2014, 12:12 PM   #3
62 Barnfind
62 Barnfind's Avatar
Step or fleet?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 09-06-2014, 01:44 PM   #4
scuderia
scuderia's Avatar
Originally Posted by 62 Barnfind View Post
Step or fleet?
fleetside...
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
Old 09-06-2014, 02:48 PM   #5
jayoldschool
I took my bed off with an engine hoist and a recovery strap. Put it on stands. Did the cross sill install, wood install, strips, header panel, tubs myself. It was a pain doing the strip bolts because I had to keep sliding under and getting up to put bolts in.
Started with this:
Made these:
Put things together:
Ended up with this:
Truck is back together:
Although... I had a bad day when the wind blew the bed of the metal stands. I switched to good jackstands after this.
jayoldschool is offline   Reply With Quote
Old 10-24-2016, 12:26 PM   #6
brut
i put the bed on stands too, is a lot of work with all the screws...
brut is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
