Old 09-16-2014, 04:16 PM   #1
RockinKees
RockinKees's Avatar
Dutch '59 Fleetside Longbed
Finally!!
I am gonna live my childhood dream!
Today arrived the 59 Fleetside at my friends home, where we make it ready for the Dutch registration.
After that I will lower the truck somewhat
This is going to be a low-budget build, so don't expect a full on showcar, this one is going to be driven!!
As I said, just arrived, it's an original V8 car, according to the VIN.
It has a V8 and automatic, but don't know which block or what automatic...we will see tomorrow.
Only I thought it to be a 1958, see the trim, but the VIN says 1959.
So be it, I am a happy guy!!
Pics follow later, must upload them...
Grtz,
Kees
RockinKees is offline   Reply With Quote
Old 09-16-2014, 04:51 PM   #2
RockinKees
RockinKees's Avatar
Re: Dutch '59 Fleetside Longbed
The pics:
The arrival:
Stoved to the roof of a 45 foot seacontainer.
This has to change...
Sorry for the big size, have to look for how to make it smaller.
Grtz,
Kees
Old 09-16-2014, 08:49 PM   #3
Kim57
Kim57's Avatar
Welcome.
Looks like a real clean truck.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-16-2014, 10:20 PM   #4
tune_1
Glad to see you on board. Include lots of pictures.
Dwight
tune_1 is offline   Reply With Quote
Old 09-17-2014, 03:56 AM   #5
RockinKees
RockinKees's Avatar
Thanks!
It is a "clean", solid truck.
Have some work to make it my own tho.....
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
Old 09-17-2014, 02:45 PM   #6
RockinKees
RockinKees's Avatar
Today's work:
Cleaned the inside of the cab a little, so I know what to do...
Two rust spots in the corners by the front cabmounts, nothing serious and one little thin spot at the left step, that's all.
The engine is a 350, but can some identify the trans for me?
I think a powerglide, but not sure. Didn't count the bolts yet but have a look:
And some cleaning of the mess, called autowiring...
Cheers!! Kees.
Kool Guyz CC
Old 09-17-2014, 03:03 PM   #7
Larry Lindley
welcome to the forum,looks like a turbo 400 for the transmission.
Larry Lindley is offline   Reply With Quote
Old 09-17-2014, 03:29 PM   #8
RockinKees
RockinKees's Avatar
Thanks Larry!
If it is a Turbo 400, that should be a good trans, or??
Cheers!! Kees.
Kool Guyz CC
Old 09-17-2014, 03:37 PM   #9
Kim57
Kim57's Avatar
Here's a GM pan guide that should help identify it.
Kim
My build thread
Old 09-17-2014, 04:50 PM   #10
RockinKees
RockinKees's Avatar
Thank you, Kim!
I found this too, by the look of it, it must be a TH400.
Cheers!! Kees.
Kool Guyz CC
Old 09-17-2014, 05:31 PM   #11
Kim57
Kim57's Avatar
If it's a TH400 that's a very strong trans.
Kim
My build thread
Old 09-17-2014, 06:05 PM   #12
RockinKees
RockinKees's Avatar
I've heard that too, Kim.
The trans looked small to me.
Before I had a 81 Chevy Van with a TH350, that looked much bigger.
But maybe I get older and need glases to see right ;-)
Cheers!! Kees.
Kool Guyz CC
Old 09-19-2014, 03:27 PM   #13
RockinKees
RockinKees's Avatar
So today I worked at the wiring a bit.
I have no diagram yet, so it was more cut out what not was connected to anything.
Basicly all wiring
I didn't get any keys with this truck, so had to demolish the ignition switch.
Made a starter knob out of two relais, one to get current (+15) and from there one to get the starter activated. This works....
For the Dutch title you need turnsignals and a horn, among other things of course, so pulled the "wiring" out of the steering column, well it had a small fire in there in his previous life.
Took the turnsignal switch apart, and soldered on new wiring.
Also checked the light switch, isn't any better, except for the burned wiring...
My plan is to make my own wiring harnass, have done it before so it'll be fine. I therefor need a diagram, and OrrieG is so nice to get me this.
From there I make my own harnass, own colors and a nice fusebox and relais to keep it save. All written down of course!!
Rest me to say, I am Dutch, I also live there, so if my language is not correct, excuse me for that
I know you all love pictures, so here they are:
Cheers!! Kees.
Kool Guyz CC
Old 09-19-2014, 04:07 PM   #14
Kim57
Kim57's Avatar
You're doing a nice job.
Your English is just fine, better than my Dutch.
Kim
My build thread
Old 09-19-2014, 04:14 PM   #15
RockinKees
RockinKees's Avatar
Thanks Kim!
I'll do my best, only just began
Cheers!! Kees.
Kool Guyz CC
Old 09-20-2014, 12:36 PM   #16
_Ogre
_Ogre's Avatar
truck looks solid, floor pan is good
needs a total rewire; but that can be expected
the side trim is 58 for sure
but that interior
shop air compressor timer
Old 09-20-2014, 01:34 PM   #17
RockinKees
RockinKees's Avatar
Interior is allready gone, I developed a bit asthma in there
I thought it was a '58 too, bought it as '59, so says the title....
The truck is pretty solid, only a few places that need to be done.
Today I tried to start, probably after 8 years of standing, and you know?
It runs
But boy, it's loud!
There are only two cherrybombs on two exhausts of three foot length...
After that we pushed it at a car bridge or ramp (how do you call it??) and found out that there's an old damage, the driveshaft is bent. The PO must have felt that I would think?
Other than that I need new brake hoses, and indeed a complete wiring.
No Problem
Cheers!! Kees.
Kool Guyz CC
Old 09-20-2014, 10:46 PM   #18
1958Warrior
1958Warrior's Avatar
Maybe the PO did feel the vibration from the bent drive shaft ...., that could've been his thinking he needed more down force , by added that wing on the back.
I'm pretty sure you could loose that thing and not notice any handling drawbacks.
CHEERS!
[IMG]url=http://67-72chevytrucks.com/gallery/showphoto.php?photo=39392&title=shiner&cat=1928][/url][/IMG]
1958Warrior is offline   Reply With Quote
Old 09-21-2014, 04:40 AM   #19
RockinKees
RockinKees's Avatar
Hahaha, I think you are right 1958Warrior!!!
I'm also pretty sure I loose that wing... ;-)
Cheers!! Kees.
Kool Guyz CC
Old 09-24-2014, 01:42 PM   #20
RockinKees
RockinKees's Avatar
Didn't find a driveshaft that fits...so I ordered two conversion U-joints. A friend had an Heavy duty driveshaft of a Chevy Van lying around.
I only have to move the engine forward, about 11/16", is a good thing because the distributor sits almost against the bulkhead, problem solved!
Next was the frontaxle, leftside was loose at the leafsprings. The bolt in the center of the leafs was broken, made a new one.
I also did get my new brake hoses, so that's for tomorrow!
Also made a new eye for the rightside shock, was broken off.
Next on the list is a radiator, mine is leaking. I can let it fix or I can order a new one.
I thought of ordering a new, aluminium one from Speedway Motors. These radiators are very, very expensive overhere!!
Tips about the radiator are welcome!
As you might have read, this is only to get my Dutch registration. Plan is to put a Jag IFS and IRS under the truck.
Well, you can see where it's leaking, don't you?
Cheers!! Kees.
Kool Guyz CC
Old 09-24-2014, 11:48 PM   #21
Kim57
Kim57's Avatar
Nice fix on the shock mount.
I'd probably replace the radiator.
Kim
My build thread
Old 09-30-2014, 02:30 PM   #22
RockinKees
RockinKees's Avatar
Ordered a new radiator today, coming from Speedway Motors in about 10 days.
Made a small frame for the fueltank and fitted it at the back between the framerails, and plumbed it. I only have to make a fillerneck. This is temporaraly going to be at the back above the rear bumper.
In the near future there should be a filler with a nice door so you don't see it right away. How and where I don't know yet...
First I took the fuelpump out of the tank, it was broken,and put in a suction tube. So I hope the mechanical pump at the engine does the job..
Test fitting fueltank..
Fits like a glove
New temporaraly plates to get my engine 1 inch forward and a bit higher at the front.
When I get my IFS, I build new motormounts and do it the right way
Again a few points nearer to my Dutch Title
I'm getting there....
Cheers!! Kees.
Kool Guyz CC
Old 09-30-2014, 05:17 PM   #23
Kim57
Kim57's Avatar
Fuel tank fits real nice.
Kim
My build thread
Old 10-01-2014, 12:39 PM   #24
RockinKees
RockinKees's Avatar
Thanks Kim, that's all I need, a small fueltank.
In the near future I will ride on liquid gas (LPG or GPL, what's it called in English?) LPG is much cheaper, it's a third of the regular petrol price, so this fueltank is only a backup for when I run out of LPG.
Engine and trans are at their place, with the new enginemounts I had to adjust the trans crossmember...
One inch to the front and 3/4 inch up. This is the leftside of the engine, you have an idea how it sits.
Even for temporarely fitment you must do it right
This should work for a few weeks!
Tomorrow I will make a fillerneck for the fueltank and start with an exhaust, so it is almost ready to start up.
Next on the list is all new wiring.
We're getting there!
Cheers!! Kees.
Kool Guyz CC
Old 10-01-2014, 04:15 PM   #25
Kim57
Kim57's Avatar
Nice job on the mounts.
Kim
My build thread
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
