07-28-2015, 10:45 AM | #351 |
Re: 72 K30 Build
Our new poly mounts and bushings are here. First thing the rear spring bushings were swapped for the correct ones, way better fit. Not too excited with the washers that came with the new motor mounts though (wimpy). Pretty sure I've got the correct (beefy) old style ones in my nut, bolt & washer collection.
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
07-29-2015, 09:08 AM | #352 |
Re: 72 K30 Build
The later K35 trans/tc cross member is going to be the cleanest and easiest to install by far. Here are some pics of prepping and installing ours it had a small chunk missing from an earlier driveline failure as well as needing some straightening.
The original 67-72 style member would have required a pedestal to fit the larger longhorn frame section. It could be done but I felt it would always be a battle to work with and not worth the extra effort.
07-29-2015, 09:10 AM | #353 |
Re: 72 K30 Build
Some more pics installed.
08-03-2015, 10:46 AM | #354 |
Re: 72 K30 Build
With the new motor & trans/tc mounts installed made the carb level get even better. In addition the exhaust manifolds clear now.
08-03-2015, 09:03 PM | #355 |
6>8 Plugless........
Re: 72 K30 Build
It's looking nice! It's nice to see the manifolds clear now too!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-04-2015, 10:55 AM | #356 |
Re: 72 K30 Build
Thanks DW!
It's time to install the tc and side mount. Couldn't locate the exact right length (they are really, really short) bolts from bracket to case so we just cut off the extra to make ours, no problemo.
08-05-2015, 10:28 AM | #357 |
Re: 72 K30 Build
Our rear pinion angles look close enough for me, tc 2.5 down & diff 1.5-1.75ish up, roughly 1 degree or less off the same plane. With the angles that good and we like the overall stance the rear most hangers did get bolted. Went ahead and finished mounting the sway bar to the new mounts. Sway bar looks pretty flat with the motor/trans/tc weight in place.
08-05-2015, 06:01 PM | #358 |
Re: 72 K30 Build
Nice work! It's getting closer!
08-05-2015, 11:23 PM | #359 |
Re: 72 K30 Build
Looking good!
08-06-2015, 12:03 AM | #360 |
Re: 72 K30 Build
Real nice progress!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
08-07-2015, 09:54 AM | #361 |
Re: 72 K30 Build
Thanks for the kind words it’s pretty cool seeing it start to resemble a truck again!
We built a new high lift type cab lifter much more stable and just in time to fit the cab with some new body mounts. Our mockup big block fits great, plenty of room in the forward 2wd position.
08-07-2015, 12:31 PM | #362 |
Simple? What's simple?
Re: 72 K30 Build
Nice!! That truck is going to have a killer stance.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
08-08-2015, 01:36 PM | #363 |
Re: 72 K30 Build
Good work Brett!!! Maybe when I'm dropping my truck off (possibly) to a buddy of mine in Centerville, I'll have to stop by and check this thing out in person.
08-08-2015, 06:51 PM | #364 |
Re: 72 K30 Build
Very good progress! That looked like a LOT of work to get a 4wd roller.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
08-10-2015, 10:20 AM | #365 | ||
Re: 72 K30 Build
Thanks Jim we're very happy with the stance! Guessing maybe a tad lower in the front compared to your 72 GMC build.
Well our fenders did not line up right off also found the TC was touching the cab floor with the high hump removed. Added 3 more (4 total) shims each to both front cab mounts brought the fenders inline and raised the cab enough to clear the TC.
08-10-2015, 10:50 AM | #366 |
Re: 72 K30 Build
I'm in the same spot right now on the '50 (well minus the T-case ), my tailhousing is pretty close to the floor and not so sure I'm happy about it.
08-11-2015, 02:43 AM | #367 |
Re: 72 K30 Build
How thick is your rubber bushing under the cab in front and rear. I will check mine later.
08-11-2015, 10:20 AM | #368 | ||
Re: 72 K30 Build
From these angles I’ve got some déjà vu going on. Reminds me of when we mocked up our sheet metal on the donor 84 K35 Crew Cab chassis last winter (green cab). Difference is this time we got to bolt down the old RV cab (without the little hole in the back) and it’s not a limo anymore it’s probably a good 3’ shorter at least!
08-12-2015, 09:48 AM | #369 |
Re: 72 K30 Build
With the cab/body on we need to fit a few things. Started by installed the tc shifter and nailed the factory position. The console also got fit for the last time prior to restore it’s the first time it was actually bolted to the floor.
08-12-2015, 11:12 PM | #370 |
Re: 72 K30 Build
Great work! I've got a 72 C30 Longhorn to convert to a K30 for a board member soon. Too bad the body is nice and the owner may not want to remove it.
08-13-2015, 09:38 AM | #371 |
Re: 72 K30 Build
Cool DW do you think you'll do a build thread? I'd like to see that!
Here's what's up with the trans shifter linkage. If you recall we covered up one of the original mounting holes with the shackle bracket on that side. Flipped the bracket around until it lined up and bolted it to the upper existing mounting hole, and wala! Looks like it’ll work just fine right there but we’ll test it with the rest of the column in later to make sure. Front drive line from the K35 looks perfect.
08-17-2015, 11:53 AM | #372 |
Re: 72 K30 Build
Started a hydroboost conversion, wasn’t really sure we were going to do this but after giving it some thought it made sense. GM went to this system with the brakes we now have and I don't want any pedal pressure issues later, the donor truck stopped on a dime! Jim (JJorgensen52) did this conversion on one of our main inspiration trucks and he made it look easy http://67-72chevytrucks.com/vboard/s...d.php?t=631136 what a really great write up Jim, thanks! We’ve got the same core parts essentially as Jim did so our push rod length was the same (ours was marked 71217).
08-17-2015, 12:26 PM | #373 | |
Re: 72 K30 Build
Are you going to be using the stock big block remote reservoir steering pump? If so, you might want to look into a GM 26073040 or similar reservoir; they came in Astro/Safari/Express/Savanna vans with hydroboost and have dual return fittings, but they look pretty much identical to the stock unit, and they're made of welded steel so easy to add/modify a bracket to mount it where you want it.
08-18-2015, 09:30 AM | #374 |
Re: 72 K30 Build
Yes that is the plan we'll use the stock big block remote reservoir steering pump with a tee in the return line. Our thinking is we'll go down the same road as you did with the steering box and plumbing easy peasy!
Here are some pics of our modified brake pedal prior to the final fitment. Going to wait until I've got the rebuilt HB in place to punch the hole and finish fitting this piece.
08-18-2015, 10:09 PM | #375 |
Re: 72 K30 Build
Do you think it would still work lengthening the rod and using the factor hole.
Tags |
72chevy, dually, flatbed, k30, motorhome |
