Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 01-25-2014, 04:47 PM   #1
mattcrp1
mattcrp1's Avatar
FAQ - Rebuilding Calipers
Hi all I thought I would post my caliper rebuild. I found that a rebuild kit was only three dollars. I wasnt trying to be cheap, but I dont have a lot of extra cash. I started by removing the piston,**DO NOT PUT YOUR FINGERS IN FRONT OF THE PISTON**. A little compressed air and POP, out if came. I used a block of wood and a rag to dampen the blow. I then removed the dust boot and looked inside. Yuk! a lot of nasty stuff in there.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline
Old 01-25-2014, 05:02 PM   #2
mattcrp1
mattcrp1's Avatar
Re: 76 Caliper Rebuild
After I cleaned up the caliper and piston I started the assembly proccess. If there are any scores, lines or pits on the piston do not reuse it. I used some 1200 grit sandpaper to polish the piston. It looked pretty good. I cleaned the caliper body and had to scrape a deposit out. I used a scotch brite pad to clean the inside bore of the caliper, mainly to remove any stains. I then used some fresh brake fluid on the new square cut oring and installed it into the caliper. I lubed the piston with brake fluid as well and pressed it into the caliper, before the piston was all the way down into the bore I installed the dust seal. Now that it done I can paint it and install it. Feel free to add to ask questions or crticizes. I just thought I would post this simple process, I noticed when doing a search that some guys were a little hesitant to rebuild a caliper. Hope this helps.
Matt
IG mattcrp1
mattcrp1 is offline
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
