Old 02-07-2015, 06:21 PM   #1
First c10
First c10's Avatar
Frame differences
Hey guys
What are the difference between a c10 and k10 frame? Can a c10 long bed frame be used in a k10 long bed. If so any big changes?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 02-07-2015, 06:33 PM   #2
john@thepier
john@thepier's Avatar
Re: Frame differences
c-10=2wd k-10=4wd a body can be swapped to either frame, only minor differences, cab will need high trans tunnel for 4wd
john@thepier is offline   Reply With Quote
Old 02-07-2015, 06:36 PM   #3
First c10
First c10's Avatar
I mean can I take a c10 frame and use it on a k10?
GO GO!!!
Old 02-07-2015, 07:44 PM   #4
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
You can but it will take some work. The rear section is a little different where the suspension attaches, not to mention the leaf spring attachement points on the front, and the bracketry up there, bumper brackets, etc. Also the K10 frame would have a higher section modulus (strength) assuming lwb. If its coil spring, its even further from being correct for 4wd.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 02-07-2015, 10:11 PM   #5
SS Tim
SS Tim's Avatar
Metal by the numbers
C Blazer
C10 115"
C10 127"- 6.04" section height, 2.53" flange width, 0.156" thick, 2.98 section modulus
K Blazer
K10 115"- 6.02" section height, 2.71" flange width, 0.141" thick, 2.70 section modulus
K10 127"
K20 127"- 6.09" section height, 2.75" flange width, 0.186" thick, 3.48 section modulus
SS Tim is offline   Reply With Quote
Old 02-08-2015, 03:06 PM   #6
First c10
First c10's Avatar
Ok I was told that the frames were all the same between C and K's. Just the brackets and such were different. So I thought I would ask.
Thank you all for the info I will look for a lwb k10 frame.
GO GO!!!
Old 02-08-2015, 04:08 PM   #7
SS Tim
SS Tim's Avatar
K10 LWB or K20 frame would work for you.
There are a lot of frame variations looking at them as rivited assemblies. While some can be easily modified its best to start with as close a match as possible.
Old 02-08-2015, 04:25 PM   #8
First c10
First c10's Avatar
Great to know... What is different on a k30 frame?
GO GO!!!
Old 02-08-2015, 04:43 PM   #9
SS Tim
SS Tim's Avatar
There were no regular production factory K30s 67-72 only upfitter conversions like NAPCO's.
The factory K30 wasn't offered until '77 with a 131.5" & 164.5"wb.
Very different frames than the 72 down frames.
But since you asked here is something to digest.
These are the different PICKUP TRUCK frames as I understand.
Referenced from the GM 1970 truck engineering specifications book. This list does not differentiate between manual and automatic versions, that about doubles the list!
Any corrections are invited.
SS Tim
C Blazer COIL
C/10 115" COIL
C/10 115" LEAF
C/10 127" COIL
C/10 127" LEAF
C/20 127" COIL
C/20 127" LEAF
C/30 133" LEAF (Longhorn C/20 & C/30, 9' Stepside)
C/30 157" LEAF (Chassis Cab only) included for reference
K Blazer
K/10 115"
K/10 / K/20 127"
The frame section and modulus numbers, 39k psi carbon steel through C30s. Note the increased section height, flange width and thickness changes of the frame as the series step up.
C Blazer
C10 115"
C20 127"- 6.11" section height, 2.46" flange width, 0.194" thick, 3.71 section modulus
C20/30 133" (Longhorns)- 7.20" section height, 2.77" flange width, 0.194" thick, 5.05 section modulus
C30 157"- 8.18" section height, 2.97" flange width, 0.224" thick, 7.29 section modulus
K Blazer
K10 127"
A note on frame stiffness.
By lukecp
"I had a course in Mechanics of Materials last semster, which is basically calculating stresses and strains in deformable bodies (beams, pipes, columns, ect), along with deformation, ect. I don't remember going over it, but I cracked open my book from the class and this is what it says:
S = I/c, where:
S = Section Modulus
I = Moment of Inertia
c = Distance from Neutral Axis (center of gravity) to edge of beam
The section modulus is used then to calculate the maximum stress in any section of a beam using the formula:
Max Stress = -Mr/S, where:
M = Resisting Moment. This is the moment (think a rotational force, like a torque applied) that is resisting the forces applied to a beam. If you had a steel beam solidly attached to a wall, where the beam is free at one end, and hung a weight from it, the resisting moment would be the torque needed at the attached end of the beam to resist the force of the weight of the beam and the added weight, and keep the beam from ripping out of the wall.
It also says that the section modulus becomes larger if the shape of the beam is altered to concentrate more of the area as far as possible from the neutral axis (center of gravity). This could include raising the height of the "C" channel, making it wider, or having a frame with thicker horizontial sections than vertical sections. I'd assume that the frame is "taller" than a C-10 frame, but every C-20 I've seen has had a frame that looks identical to my C-10. The frame could be wider, that is my guess for the difference.
So, what does all of that mean? The larger the section modulus, the smaller the maximum stress in the beam caused by the weigth of the truck and whatever cargo or trailer is being carried/towed. So, a larger section modulus causes a beam (or frame in this case) to be able to safetly carry larger loads without deforming or breaking.
In this case, increasing the section modulus from 2.7 to 3.48 would decrease the maximum stress felt in the beam/frame by 22.4%."
So...
K10-20 vs C20, the C20 is about 8% stiffer
K10-20 vs C20-30 Longhorn, the Longhorn is about 45% stiffer
C30 & C20-30 Longhorn (133") vs C30 (157"), the C30 (157") is about 44% stiffer
K10-20 vs C30 (157"), the C30 (157") is about twice the stiffness of a K10-20.
Old 02-08-2015, 05:38 PM   #10
Vintage Windmills
Vintage 4x4s
Good info Tim. The effects of section height are apparent here. The base equation for moment of inertia of a rectangle is 1/12 x base width x height cubed. So adding a couple inches on 6 inches of frame height doesn't add 33% strength, it approximately doubles it. Add material to the height and it gets cubed!
39,000 psi is on the low end for steel, do you know when the grade used by GM increased?
Old 02-08-2015, 06:04 PM   #11
SS Tim
SS Tim's Avatar
Since my at hand data is showing 36K?-39K up through '85 it probably remained the spec. until the T400s were released. Even then they probably remained longer with the legacy models like the Crew Cabs Subs and Blazers.
Sombody needs to buzz Kieth on that answer.
If you are thinking about Big Red its probably a 39k frame.
Old 02-08-2015, 09:29 PM   #12
First c10
First c10's Avatar
Wow this is great info I really had not seen before....
Scott
GO GO!!!
Old 08-10-2017, 05:48 PM   #13
1972K20
1972K20's Avatar
Older thread, but really good info.
1972K20 is offline   Reply With Quote
Old 08-10-2017, 05:56 PM   #14
toolboxchev
And I still learn something everyday on these rigs from the people that form this site.
toolboxchev is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
