Old 08-25-2003, 12:02 PM   #1
racedvl's Avatar
487X cylinder heads. . .
Are 487X heads any good? I have a set, I'm I'm thinking that I would rather have a set of non-906 casting Vortec heads. Does anyone have any input on this for me?
racedvl is offline   Reply With Quote
Old 08-25-2003, 01:16 PM   #2
Formerly yellow72custom
lukecp's Avatar
487X heads are a fairly rare find....they came on early '70's LT1 350 engines.....being a "X" casting, the intake ports are 10cc bigger than the standard 487 heads. They might already have 2.02/1.60 valves too. The combustion chambers are 75cc's though, so if you want high compression you would have to run a domed piston.
If they are in good shape, i would use them, especially if they have 2.02/1.60 valves. Pretty much, they are a open-chamber performance head. Vortecs will flow better.....and make more power though.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 08-25-2003, 03:11 PM   #3
bpmcgee's Avatar
Regarding your comment on the 906 Vortechs -- Chevy High Performance actually retracted their first comment about 906s not flowing as well as 062s. They now say that both castings are about the same.
Just FYI,
1961 GMC Suburban
bpmcgee is offline   Reply With Quote
Old 08-25-2003, 07:50 PM   #4
487's are a good head and the 487x's are better, also very rare and "should" have 2.02/1.60 valves. They are a pretty thick casting and only have a single crossover, so they are not as likely to crack like the 882's and such. With a little bit of work, they will flow nicely for a driver/cruiser.
Fawker Fab three seater rock crawler buggy 454/SM465/203/205 Fawker Fab doubler, 5.13's, 42" PB Rockers
'86 CUCV "Buster" RIP
'96 Dodge 4wd 12 valve five speed (Tow Rig)
'17 Silverado
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 08-25-2003, 08:31 PM   #5
bigjimzlll's Avatar
My advice...Sell them to someone who needs them for class racing or a numbers matching restore. What hurts is the 75cc chambers and the soft valve seats. They are nice heads though..for real old school
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
bigjimzlll is offline   Reply With Quote
Old 08-26-2003, 12:19 AM   #6
i used to have a set of 487x's. the x really means that they have hardened seats. the intake ports are the same size. they made them from 71-73 on vette lt1's. 1970 lt1 heads were closed chambers. my 487x's had 1.94 valves.
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 08-26-2003, 03:18 AM   #7
Nate I recently traded a set of 487X heads due to the fact every single excaust port needed hardened seats installed. Not to mention guides all-around. I was lucky the machinest had a set of 487's laying around that did'nt need as much work.
Member of the "Old Farts Club"
ChopTop is offline   Reply With Quote
Old 08-27-2003, 10:15 AM   #8
milner's Avatar
Question about the 487X heads. I bought my 72 custom deluxe with a bad motor(I was told it had a rod out). I put a motor I had lying around in with vortecs on it. Anyway,I came across a deal on a 383 that I couldn't pass up. It is a shortblock only,I want to put it in my 79 K10. It has a THIRSTY 400 that is worn out,also has fulltime which doesn't help matters. I checked the heads on the motor last night and they are 487Xs,I was thinkin about using them on the 383. It is not a race motor,I was thinkin about vortecs again but with 64cc heads the c/r would be 10.3-1,alittle to high. What do you guys think?
milner is offline   Reply With Quote
Old 08-28-2003, 12:34 AM   #9
the 487x's that i had, had hardened seats. i think they were 1972 casting date
Old 08-29-2003, 02:50 AM   #10
73stepside's Avatar
10 on the cr is high but with vortecs you can retard the timing and probably not get any detonation and be happy with the power output. i've heard that vortec'd motors do not reqiure nearly the amount of initial advance than non-vortec'd motors.
04 GMC Sierra RCSS
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Copyright 1997-2013
