#201 | |
Re: What can be said about the 4-speed New Process NV833 overdrive manual transmissio
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#202 |
Great !
I hope I have no speedo probs with this iron unit (NP440) thats being built , they have one less gear to find before its complete . I just bought an 1981 shifter on ebay today for it .... I have an 66 GMC 3/4 w/ 292 6 cly . The original muncie ( we should come up with a slang name for it like "Slow Mo Box" ) has got to go lol ! |
#203 | |
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
#204 |
Can I still get parts or does anybody rebuild the 833, I have one and my buddy said it sounds like the countershaft bearing is going out, I can hear a distinctive rolling mumble when coming to a stop even with the transfer case in neutral.
#205 | |
#206 | |
Moderator
![]() Join Date: Oct 2008
Check that the countershaft hasn't wallered out the case. They seem to like to do that on the aluminum case units. You can bore and sleeve it with steel. Check with Brewers for parts. http://www.brewersperformance.com/
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#207 |
Thanks, mine is a cast iron 4x4 case 1985, I havn't removed it yet pending on parts. If I cant get the parts I will probably go with a nv4500 5 speed
#208 | |
These transmissions I heard are good for the V8s and that they are heavy duty almost as much as my original Muncie 4 speed |
#209 |
Man wish someone could do these cheaper lol
#210 |
When you think about it you gotta see there is only a few of these around , like 2 yrs they made them but if thats not enough you get the same beefyness as an muncie 460 yet without that horrible compound gear but a real 1st gear PLUS-
I'll get 20 miles per gallon on this 66 GMC with 292 6 cyl and it will make the engine last alot longer . I dont need to change out the rear end now . I found mine at a place called Eagle Motors or something for cheaper- and they have engines and **** that they recon . BUT another tip is to get an used one Tom Myers Wreckers in Oklahoma BECAUSE he had an **** load of nothing but old GM trucks from the 40s to now ! |
#211 |
Yeah I been looking found a couple an they either sold before I got ahold of the seller or they never contacted me back lol
#212 | |
Just be ware that you have to get the shifting linkage knob assembly thing too , it is different and Im expecting to do a little fabricating so that it holds an original feel to it as well as usefulness . Its gotta look good . I found one on ebay for $250 with shift boot , knob , everything . Its gonna look KILLER . T |
#213 | |
Post Whore
![]() Join Date: Aug 2014
I have a couple extra of the GM shifter fingers (2 of the three needed, I am missing one) if anyone is interested in buying them |
#214 | |
T |
#215 | |
Post Whore
maybe some of these pics will help you out |
#216 |
Gregski I followed your build with the 833 that is a slick setup I too want to install one in my 65 c10
#217 | |
SO how does yours perform ? Good on gas now ? |
#218 | |
Post Whore
awesome in overdrive on the freeway, I am going 75 MPH at 2250 RPM so nice such a big difference from the SM465 Muncie which reved way up in 3rd gear which was its direct drive, also first gear is now usuable so nice, love it biggest problem or the only issue with it is a pesky fluid leak from the darn speedo drive, that stupid little seal, I have now bought two new ones and am running my old one and a new one so two little seals on there, the orange one is the older style and fits better but is old and tired, the black one is the new one and it is loose like a goose (kinda upset at an eBay seller who advertised the orange one in his auction and its even on that piece of paper in the pic and than shipped me the black one, sucks) the other thing is noise, the transmission when properly filled with transmission fluid makes noise in some of the gears I forget which ones 2nd and 4th maybe, but if you let the fluid run low a little bit it's not as bad, I am not saying there is no noise I am saying its less, I run the AC Delco expensive manual transmission stuff now to answer your question about mileage I am not done tuning my truck yet, you can check out the progress here INNOVATE DLG1 Wideband O2 Oxygen Sensor Tuning Diagnostics Logging Air Fuel Ratio etc but last weekend I got 15 MPG fully loaded up for camping, with coolers, chairs, three bikes and a 15 foot kayak on the rack above the cab, so not bad at all for a 350 SBC climbing hills up to 4,000 feet elevation Last edited by Gregski; 08-18-2016 at 03:08 AM. |
#219 | |
I was told to use regular engine oil like an 30 weight , try that maybe . Weird about the leak .Mine has an 292 motor so we'll see what I get milage wise . |
#220 |
So which gm crossmember would this transmission use?
#221 |
Post Whore
depends if you are going 2WD or 4x4 I guess, but in the 2WD situation it will take the old double hump one which is great for dual exhaust as it allows for plenty of clearance, (top pic)
but it also can take the TH350 style one as well the lower rise one (second from bottom the bare metal one) the first one is for a 4x4 and I don't have a 4x4 so I can't vouch for it and I am missing the 5th style which is the wrap around one where the driver side wraps around the outside of the frame, can't vouch for that one either (single pic off the web) |
#222 |
Ok sweet it is 2wd style an wanting to install one in a 65 c10
#223 |
#224 |
The 4x4 cross member only works on the 4x4 version, which mounts via the T-case adaptor which replaces the rear housing that is on a 2wd.
#225 |
Definetly keep you in the loop an that would make sense for the 4x4 crossmember do you guys knownwhat that 2wd double hump crossmemeber would come.out of an what kind of transmission mount one would use for this transmission
Thread Tools | |
Display Modes | |
