08-20-2015, 10:52 AM | #1 |
TH400 Kickdown operation
I see that the trans has a vacuum connect and a power wire from a key-on source. The connection on the trans has 2 wire connections. I read that the vertical one is for the kick down operation. Whats the horizontal one for? How does the trans know when to down shift? Is there another switch some place?
My trans wont kick down for passing etc. and shifts up very early until its in 3rd. I checked that the vacuum is connected (it is) and then checked for power at the vertical trans terminal with the key on. No power. My first correction to try to fix this will be to run a new key-on power wire to the vertical terminal on the trans. If this solves the problem then no issues. If it does not fix the problem, where do I go next?
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
08-20-2015, 11:01 AM | #2 |
Never Ending Projects
Re: TH400 Kickdown operation
You need a kickdown switch, which could be either at the carb or in the cab where the gas pedal would hit. Earlier trucks used the switch at the carb but these are really hard to find the switch and correct bracket. Later trucks used a switch mounted up under the dash and the gas pedal arm would hit it. You can mount a manual switch if you want. Basically you give it 12 volt to down shift. I haven't seen the switch on the trans with 2 connectors before. Likely something from a really late model that tied into a computer or emissions stuff. All of mine have only had 1 connector.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-20-2015, 11:13 AM | #3 |
Thanks Mike, Ill look to see what I have at the pedal. I know there is not one at the carb. I included some pics to reference the 2 prong plug.
Also, where does the switch at the pedal connect into the system? How does it operate?
08-20-2015, 11:17 AM | #4 |
If I have this right, the power runs from the fuse panel to the switch at the pedal then runs from the pedal to the trans vertical connector...right??
08-20-2015, 12:48 PM | #5 |
Ok so there is no switch at the pedal or carb. I guess that means I need one of these to get things working.
or
08-20-2015, 02:08 PM | #6 |
member #16
Here's a pic of the sw and bracket, and a link to a bracket.
http://www.rickscamaros.com/camaro-k...1967-1969.html I posted wtb on the parts board and bought the switch from a member.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
08-20-2015, 05:54 PM | #7 | |
08-22-2015, 07:07 PM | #8 |
What my brain hears when people start talking about Automatic Transmissions! https://youtu.be/6kAeN5knZMQ
So my question is simple yet complex What does a kickdown switch actually do? Does it change the shift parameters so the trans will shift only at a higher RPM when energized? Does it force the trans to shift to the next lower gear until de-energized?
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. Last edited by ranger danger; 08-22-2015 at 07:18 PM. |
08-22-2015, 10:05 PM | #9 | |
When the Detent Solenoid is activated, It dumps line pressure off the Detent Valve allowing it to shift, Then Drive Oil (Forward Clutch Oil) is allowed into the Detent Oil passages (Becoming Detent Oil). Detent Oil is sent to the following.... 1. Modulator Passage 2. 1-2 Valve 3. 2-3 Valve 4. 3-2 Valve 5. 1-2 Accumulator Valve 6. Vacuum Modulator Valve 2-1 Detent.... Below 20 mph detent oil directed to the 1-2 valve exhaust port will close the 1-2 shift valve, shifting the transmission to First Gear. 3-2 Detent.... Detent oil at the 3-2 "Downshift" valve will close the 2-3 shift valve below approximately 70 mph shifting the transmission to Second Gear. Oversimplified version....Without getting into Modulated Pressures & Governor Pressures & how they interact with Detent Oil. |
08-22-2015, 10:58 PM | #10 | |
Ok so when activated, it reprograms the shift point to a higher RPM for each gear, right?! If I wanted to, I could hook up a toggle switch to the trans and, when turned on, it would effectively reprogram the shift points?
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. Last edited by ranger danger; 08-22-2015 at 11:06 PM. |
08-22-2015, 11:42 PM | #11 |
60-66 Nut
A little more simplified......when the kickdown is energized, the trans shifts down to the next lower gear to aid in acceleration. This typically happens when the when the gas pedal moves to WOT.
08-23-2015, 08:58 AM | #12 |
I would look for a gas pedal from a th400 truck first. 2nd choice I would look for the carb mounted switch. It's just something extra to deal with when removing the carb. FWIW I have driven th400's a few years without a kickdown switch with no ill effect. I was driving so slow I didn't realize I had no kickdown.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
08-23-2015, 09:39 AM | #13 |
Thanks everybody, I think I got a handle on it now!
08-23-2015, 11:02 AM | #14 |
laying low
You can drive it normally and it shifts automatically without that switch. When a down shift is needed for passing, etc. you can pull the shift lever down one notch to 2nd and accelerate as wanted then simply put it back in drive to resume cruise. Sort of a semi-automatic for those who like to shift.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
08-23-2015, 11:28 AM | #15 | ||
08-24-2015, 07:02 AM | #16 |
Dang throttle rods! I didn't catch the year of your truck. If it's an oldie then there may not be a gas pedal switch. I guess carb mount it is. Cadillac used to use a carb mount switch too (qjet) for a while in the 70's. I have never took one off to see how they mount but it could be a cheap option if you find one in a junkyard.
08-24-2015, 08:32 PM | #17 | |
08-24-2015, 11:59 PM | #18 |
60-66 Nut
What year of truck are you working on? Cable throttle conversions have been done many times.
08-25-2015, 06:40 AM | #19 |
Its a 69' Suburban with a TH400 and a crate 454 running a edelbrock performer intake, qjet carb and MSD pro billit dizzy.
08-26-2015, 12:20 AM | #20 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-26-2015, 12:35 AM | #21 |
60-66 Nut
I was thinking that the '69's had a cable throttle. I guess maybe it wasn't until '71? I'm more familiar with the '60-'66's. It should be a fairly simple upgrade for your '69 Burb.
08-30-2015, 06:26 AM | #22 | |
The difference is that if you manually downshift from drive to second, the front band is engaged, which provides engine braking. Using the electric kickdown doesn't engage that band, and does not provide engine braking. And when you're downshifting to pass, you definitely don't want engine braking. That's how I understood it anyway. Actually, here are the pages I'm talking about. Maybe I misinterpreted what I read. |
08-30-2015, 07:23 PM | #23 | |
08-31-2015, 05:36 AM | #24 | |
Did I miss something when I was reading about the TH-400 in the FSM? Did I misinterpret what I read? Or are you one of the people used as a reference when they write textbooks about transmissions? (I'm not being a smart-***. That knowledge started in people's heads before it was ever put to paper.) |
08-31-2015, 07:45 PM | #25 | |
It states the Front Band applies....So the Sun Gear & Direct Drum cannot Overrun on the Intermediate Sprag or Roller Clutch (Depending on year). If your accelerating in 2nd, The Sun Gear & Direct Drum are held stationary (By the Intermediate Sprag & Clutches)....Whether the Front Band is applied or not. The engine braking only applies when you let off the throttle, Instead of the engine returning to idle (Direct Drum & Sun Gear Overrunning Clockwise), The Band holds the Direct Drum stationary basically locking the Sun Gear to the engine......Like a Manual Transmission. |
