![]() ![]() Join Date: Apr 2005
![]() HartRod Hood Brackets! When I started getting ready to install my Porterbuilt dropmember hood hinges, I decided I didn't want to weld the provided hood brackets to my painted hood. I also looking for a way to have some side to side adjustment to allow for better alignment of the hood between the fenders if needed. So I spent some time trying to figure out a feasible way to accomplish this. After some trial and error, I finally came up with design that would bolt directly to the hood, requiring no welding. My brackets use the 2 factory hinge mounting points along with 4 - 3/8" nutserts installed in the hood brace. The Porterbuilt hood hinges attach directly to the mounted hood brackets. It's a very simple and clean installation. Let me know if you any specific questions or are interested in a set of the brackets. I'm offering the first batch at $200 shipped via USPS (CONUS only). Just paypal robhartley@aol.com and include "Hood Brackets" in the message. Rob P.S. Below is a great step by step thread written by boardmember Rockcrwln that shows you how to install your PBFab hood hinges. When you get to the step that shows you how to weld on the hood mount, you would continue you the installation process with with HartRod hood brackets! http://67-72chevytrucks.com/vboard/s...+hinge+install
Rob - http://instagram.com/hart_rod As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: ChubTubz- http://67-72chevytrucks.com/vboard/s...d.php?t=675754 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 FAQ: http://67-72chevytrucks.com/vboard/f...play.php?f=220 Last edited by Hart_Rod; 01-28-2016 at 01:48 PM. |
Re: Bolt on hood brackets for Porterbuilt hood hinges.
Nice work
US Army Bomb Squad 83-96 There is no problem that a suitable amount of explosives cannot solve |
![]() Join Date: Jul 2008
did it change the cowl to hood alignment?
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
Thanks!
Absolutely not!!! ![]()
Rob - http://instagram.com/hart_rod As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: ChubTubz- http://67-72chevytrucks.com/vboard/s...d.php?t=675754 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 FAQ: http://67-72chevytrucks.com/vboard/f...play.php?f=220 |
Here are some more pictures. I have a lot more on my Instagram, Hart_rod_chubtubz.
So you could run a fiberglass hood with these?
Nice! Keep coming out with innovative products!
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
Thanks Wesley!
I would think you would have no problem as these brackets helps spread the load over 12 points instead of 4 like the original. You would just have to make sure you secured the nutserts in the fiberglass. Let me know.
A guy with a truck
I like the radiused corners and better flowing lines of the production version. Nice work!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#10 | |
A guy with a truck
I'd be proud! Man, I sure hope this stuff is still around when I get back to the 'states and have a place to work on trucks again...
I don't have one of these trucks but those could give people more options on hoods or help those who can't weld.
#13 | ||
#14 |
bump
#15 |
Hey this is a great idea. Your original post says you wanted a way to have some side to side adjustment. This is my concern with these hinges. But I am not seeing how you accomplish the side to side movement. I must be missing something.
#16 |
The mounting holes can be slotted to give you some side to side movement.
#17 |
Installed pictures from a happy customer!
#18 |
Any thoughts of doing this for other year models? 60-66? 73-87?
#19 |
Not at the moment. I can't keep up with what I currently have going on....
#20 |
Bump!
#21 |
I second this thought...poor 60-66 trucks are always forgotten. Keep us posted if you decide to make them available.
Chuck Instagram: c_lo_garage Check out my 1966 C10 project "El Viejito" here: http://67-72chevytrucks.com/vboard/s...d.php?t=674614 |
#22 |
Will do!
#23 |
bUMP!
#24 |
bump!
#25 |
Can you give me a paypal. I want a set Of these.
Thread Tools | |
Display Modes | |
