Old 10-06-2015, 04:22 AM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
Talking 1978 2wd Blazer
So I was looking at a 1978 2wd K5 Blazer about two weeks ago.
The PO bought it as a project, no motor or trans. He had a friend help with a motor swap that's supposed to be a 91 Camaro motor with new HEI, Edelbrock intake and carb. Has headers but no exhaust so I'm probably going swap for Ram Horn manifolds. No provision for a mechanical fuel pump. I'm leaning towards a factory EFI pump in the tank from a later model truck with a fuel pressure regulator in the engine bay. Was an AC truck that had all the engine bay AC parts removed. Supposed to have a rebuilt TH350. Someone covered it in flat black primer. New tires on 15" chrome smoothies. The plan is just clean it up and get it reliable....
Supposed to finalize the purchase on Thursday. I'll update with details and pictures.
Rich
1972 K5 Blazer CST Click HERE
Old 10-06-2015, 11:15 AM   #2
eighteenninetytwo
Re: 1978 2wd Blazer
looking forward to the pics
eighteenninetytwo is offline   Reply With Quote
Old 10-06-2015, 11:56 AM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Re: 1978 2wd Blazer
No joke, post em up when you can...
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-06-2015, 08:04 PM   #4
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
Stole this picture off Google Maps
Rich
Old 10-08-2015, 01:18 AM   #5
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
Google capture again...
Rich
Old 10-08-2015, 01:20 AM   #6
YBNORML
YBNORML's Avatar
Re: 1978 2wd Blazer
Looks like a cool truck with lots of possibilities.
This is also why I hate google maps. Those are pretty close up pics .
Jason.
Please note : Any items I have posted for sale are also listed locally and listing may end at any time.
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 10-08-2015, 06:04 AM   #7
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
I should pick up the truck tomorrow. (well later today actually) If the motor is as new as I was told, there is no provision for a mechanical fuel pump. I need a better fuel system to replace the $20 parts store pump on the front frame rail. I am leaning towards a new Spectra Premium 31 gallon EFI tank and factory style in tank pump with an Aeromotive 13301 bypass fuel pressure regulator up on the firewall. I am in hopes that there is a fuel return like going back to the tank to facilitate the bypass regulator.
Rich
Old 10-09-2015, 01:45 AM   #8
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
A few pics...
Rich
Old 10-09-2015, 01:46 AM   #9
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
the interior is a little messy...
Rich
Old 10-09-2015, 01:48 AM   #10
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
needs a good cleaning...
Rich
Old 10-10-2015, 06:58 AM   #11
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
Need to work on the wiring.... Anyone know what wire feeds power into the fuse panel from the battery?
Also, anyone know what years a can get a donor AC box for the firewall? 73-91? 77-80? Only 1978?
Rich
Old 10-10-2015, 08:20 AM   #12
Jonboy
Slots go on anything!
Re: 1978 2wd Blazer
Any airbox from 73-up will bolt up. I am sure there are a few differences, but they will all work. Looks like a good start.
1974 Jimmy- 5.3/4L80e/NP241
Old 10-10-2015, 10:55 AM   #13
68Timber
68Timber's Avatar
Re: 1978 2wd Blazer
I can't shake the feeling that truck has been posted here before. Congrats. Is that an old round-eye Benz following the truck?
John
74 Honda Z50 build
Old 10-10-2015, 06:12 PM   #14
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
That's my 1986 Mercedes-Benz 560SEL in Astral Silver over black leather... I'm selling the Benz to build the Blazer...
Rich
Old 10-13-2015, 05:07 AM   #15
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
Got the tank the other day and snapped a few pics. You can see the internal baffle for the fuel pump... The pump showed up before work but forgot to get a picture.
Rich
Old 10-13-2015, 08:51 AM   #16
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
Does anyone know if they make adapters to fit the connections on the fuel pump? This is from an 88 K5 and I would like to come up with something that uses the factory connection at the pump/tank and that I can rig up to the hard line. Need both the feed and return line. I don't want to run braided line. Either EFI rated rubber hose or the modern nylon type.
RockAuto sells another male connector for the feed line but I need the female end....
Fitting Attachment End 1 Male O-ring - M16-1.5
Fitting Attachment End 2 None
Fitting Size End 1 16 mm
Fitting Size End 2 3/8 In.
Fuel Line Connector Design Male O-Ring
Gasket Material Viton
Material Steel
Package Contents Steel Fuel Line Repair Kit - 3/8 In. X 18 In. W/16mm Fitting
Rich
Old 10-14-2015, 12:20 AM   #17
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
Originally Posted by mcmlxix View Post
This is a fuel pump assembly from an 88 K5 Blazer with TBI.
I need an adapter to either rubber or the new nylon hose.
I don't want to go AN so either a barb fitting or a nylon specific fitting....
Female, 3/8 M16-1.5 and the smaller return (5/16?)
Originally Posted by dayj1 View Post
Are these what you want?
Dorman part number 800-078 -- 3/8 nylon to m16x1.5
Dorman part number 800-079 -- 5/16 nylon to m14x1.5
And finally the other end that will mate the Nylon line to the factory steel fuel and return...
Dorman part number 800-135 -- 3 pack of 3/8, 5/16 and 1/4
Rich
Old 10-15-2015, 04:38 AM   #18
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
Out with the old .. in with the new... well I didn't install the new tank yet. I'm going to see about getting it covered in Line-X. Black it out so you don't see it as much, added layer or protection and sound insulation.
Rich
Old 10-15-2015, 12:21 PM   #19
slammed427
slammed427's Avatar
Re: 1978 2wd Blazer
Nice! I'll be following along. I want a 2wd blazer so bad!
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 10-15-2015, 12:48 PM   #20
Low Elco
Re: 1978 2wd Blazer
Good info! Clean 'ol Blazer!
Low Elco is offline   Reply With Quote
Old 10-17-2015, 02:04 AM   #21
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
SO they wanted $240 bucks to Line-X the thing....forget that... I talked to my powder coater. Was going to do a gloss black textured coating, but with the neck soldered in, they couldn't guarantee that it wouldn't be an issue when curing the powder coat in the oven... I'll either POR-15 the tank or just install as is...
Rich
Old 10-17-2015, 05:10 AM   #22
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
I could use some advice on a few electrical items.
1. The motor is out of a 91 Camaro and it has an electric oil pressure sensor next to the HEI. I believe the 78 was mechanical oil pressure. What are my options? (see question 2 first)
2. I am using an in tank electric fuel pump. Without an ECM to prime the pump, how do I set up a relay to the pump. I would like to incorporate the oil pressure sensor to control the fuel pump relay? Do I need two relays? One to prime and one to run?
Anyone recognize one of these part numbers for the oil pressure switch to operate the fuel pump relay?
OEM Part Number(s): 12353898, 1S6812, 2011345, 25036845, 25036938, 6000092, PS215
Rich
Old 10-17-2015, 12:54 PM   #23
MTCK
MTCK's Avatar
Re: 1978 2wd Blazer
Cool blazer. I think you are just needing one relay that stays hot with the ignition on. The tbi oil pressure switches duplicate the current coming from the relay in case of a relay failure the pump keeps going. I've never run an electric pump with a carb but assume it would work the same with a return style fuel pressure regulator.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2017 Yukon XL SLT
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 10-19-2015, 10:14 AM   #24
gmclowsierra
Re: 1978 2wd Blazer
You can get a Painless harness for the fuel pump. it uses the oil pressure switch to control the relay. you need ignition voltage in the switch to the control side of the relay. the power side of the relay goes to the battery to the pump. if you want a prime you would need to add a push button from battery to the power side of the relay. I ran a holley blue pump for years and never had a prime. the only time I had an issue with it is from sitting all winter long. all I did was crank the enginr till it got oil pressure and then the pump would fill the carb. after that it was good to go. you still need to run a regulator in the system to knock the fuel pressure down to about 5 pounds.
gmclowsierra is offline   Reply With Quote
Old 10-20-2015, 04:22 AM   #25
mcmlxix
mcmlxix's Avatar
Re: 1978 2wd Blazer
I have some Bosch relays so I'll just build a harness off keyed power. I was trying to over engineer it where it primes for 5 seconds and stops powering the pump till its running. Doesn't need it, but thought it would be cool.
I did find this.... http://www.revolutionelectronics.com/Fuel_Pump.html
I have the Aeromotive bypass regulator that I'm going to mount on the firewall. I have a 0-15 psi liquid filled gauge that will be mounted on the front of it. I'm upgrading fuel lines to late model GM style nylon line with a quick connect frame mounted fuel filter.
Rich
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
