03-21-2016, 07:40 PM | #1 |
Calling all quadrajet experts
I replaced my holley on my 402 with a quadrajet I ordered from national carburetor and I'm having some tuning issues with it running rich. The carb is set up for a bone stock big block engine and I had to replace the power piston spring to match my cam which made it driveable but it still seems rich at idle. I tried adjusting the mixture screws and they are mostly unresponsive except I got my highest idle with the screws all the way in which leads me to believe too much fuel is coming in somewhere else. I could use any tips or ideas at this point because I'm pretty stuck
03-21-2016, 08:14 PM | #2 |
One of the First
Re: Calling all quadrajet experts
What was the symptoms before you changed power piston spring? Did it idle rich before you did the work? What size jets and rods are you running?
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
03-21-2016, 08:29 PM | #3 |
Before I changed the spring it was extremely rich smoking at idle and would stumble if idle. Now that I have a softer spring it idles decent and is much smoother than before but it still isn't perfect. I didn't pay attention to what size jets were in there. If it helps any the rebuilder was supposed to use stock jetting which i wouldn't think would cause the idle screws to be ineffective even with a mild cam. It smells rich and still isn't as smooth and crisp as it should be at idle
03-21-2016, 09:12 PM | #4 |
If your mix screws are like that, then your primary throttle is to far open and you're idling on the power circuit. You need to get the throttle closed. One way is to maximize your initial timing.
Higher initial will speed up the idle allowing you to close the throttle and cover the transition slot. Read this link on the transition slot. It mentions a holley but yours is the same. http://www.crankshaftcoalition.com/w...EI_distributor So, what's your initial timing? |
03-22-2016, 04:25 PM | #5 |
*** That's interesting ***
+1. What geezer said.
Adding more initial timing or using the vacuum advance connected to full manifold will bump up the idle, then you can back off the carb idle stop screw. After you do this, then you can readjust your idle mixture screws.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
03-22-2016, 04:27 PM | #6 | |
03-22-2016, 06:16 PM | #7 |
Does it have a new float. A heavy float or the float level set too high will cause this.
03-22-2016, 06:36 PM | #8 |
03-22-2016, 07:18 PM | #9 |
Yes I plugged it and checked it idling in neutral. I had a mechanic dial the timing in when I first got it since im new to this and he said he turned it up as much as he safely could so it doesn't sound like adjusting the timing is going to fix my problem but I'm out of options at this point. I'd hate to have to throw my money away and get another carb
03-22-2016, 10:46 PM | #10 |
A few things!
What rpm did you check the timing at? You better check the accuracy of your timing tab. http://www.crankshaftcoalition.com/w...op_dead_center Check the secondary throttle plate isn't hanging up on the gasket. |
03-23-2016, 04:40 PM | #11 |
maybe princess wiggles will come on here and educate us all in quadrajetanese
03-23-2016, 06:19 PM | #12 |
Catchy title goes here..
03-23-2016, 07:07 PM | #13 | |
03-23-2016, 07:12 PM | #14 |
Look down the throat of the carb and look for fuel dripping at idle. If the mixture screws are basically unresponsive your timing is wrong or its pulling air through the throttle plates or both. Mass rebuilt carbs especially quadrajets can be an issue. People that have no idea what it is they are working on and assembling parts for the most part. I would be suspect that the engine actually starts with the timing at 24 advanced at 600rpm without vac advance hooked up. It should be kicking back hard on the starter. You need to verify actual top dead center and make sure your balancer and timing tab actually match.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
03-23-2016, 08:22 PM | #15 |
Fabricate till you "puke"
I will be another , to jump on timing (verify the TDC)....then look to shoot for 14-16 initial/ total around 36 on that BB. then add 8 to 10 degrees to the vac advance manifold vac. Cut the 'curve " all in 2800-3200, depending on what she likes....Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
03-23-2016, 10:07 PM | #16 |
I didn't have this idle problem on the holley with its current timing setting, so would a different carb want different timing?
03-23-2016, 10:13 PM | #17 | |
03-24-2016, 12:57 AM | #18 | |
Cliff Ruggles (the Q-jet guy) stated recently that he has seen a great number of defective Brass floats recently. So many that he only builds with Nitrophyl now. Might be worth taking it out and doing a bubble test to be sure. |
03-24-2016, 04:31 AM | #19 | |
03-24-2016, 05:01 AM | #20 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 03-24-2016 at 05:15 AM. |
03-24-2016, 06:45 PM | #21 |
I think I'm going to get a rebuild kit and hope i find something like a faulty needle and seat or something of that nature and if that doesn't do it then a different carb might be in my near future. Thanks for everyone's input btw
03-24-2016, 07:09 PM | #22 |
A few links for you.
http://www.digitalcorvettes.com/foru...ad.php?t=88376 Pay particular attention to the section in here regards the needle clip on the float. http://www.crankshaftcoalition.com/w...4MV_carburetor And one more. http://www.vetteprojects.com/kstyer/quadrajet.htm |
03-26-2016, 06:32 PM | #23 |
Before I cracked into the carb again I decided to check my fuel pressure and at idle the needle on the pressure gauge jumps back and forth from 6-9psi so I have two questions
Is it normal for fuel pressure to be that unsteady? And I've read that more than 6-7 is too much pressure for a qjet so should I try a new fuel pump? Thanks to all |
03-26-2016, 06:48 PM | #24 |
It shouldn't be that unsteady.
You might want to install a fuel regulator you can set at 5 psi. Just in case you change carbs in the future and need one. |
04-01-2016, 10:51 PM | #25 |
Good info on the Q-Jet here - I will need this someday. Thanks to those who contibuted.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
