03-27-2016, 08:59 PM | #1 |
Custom Truck Lover!
options for gas pedal and throttle cable
I put in a 350/350 in my 64 c10. A guy I work with says to use an early 90's suburban gas pedal and throttle cable. What do you think is a good option?
Squarebody guy |
03-27-2016, 09:04 PM | #2 |
Re: options for gas pedal and throttle cable
I used a 72 c10 one.
03-28-2016, 12:35 AM | #3 |
This link: http://www.persh.org/pickup/CableThrottle.htm inspired me.
I used a pedal and cable assembly from around a 76 or so chevy, and it was only about a 2 hour project |
03-28-2016, 05:48 AM | #4 |
Firewall mounted Lokar gas pedal and matching cable. I also added a matching brake pedal. I did weld in a flat spacer to mount it to, I used a chunk of a old bed rail to make it from.
03-28-2016, 08:40 AM | #5 |
Anyone know where to get a complete new assembly for a 73-87 truck- or even a 67-72? I want to do this swap as well. I have a matching one to dodgiesdad's but mine has bent and looks ugly after several years of use.
03-28-2016, 04:45 PM | #6 |
What year is you truck? and did you need to do any modifications to get that break peddle to work? I could not find a break peddle for my 62 on the Lokar sight.
03-28-2016, 05:32 PM | #7 |
First, I was concerned with an aluminum pedal so I went with the chrome plated steel version, I sure hope it lasts more than a few years. As to the brake pedal I cut off the factory curved pedal and welded a small piece of flat stock in its place to give me somewhere to bolt the new pedal to.
03-28-2016, 09:34 PM | #8 |
I wish I could remember exactly what all I used in my conversion - but if I remember correctly I used the throttle cable from a 73 C-10, the throttle mount assembly came from a 75 Pontiac and the plastic gas pedal came from a 72 Nova. I had to do a lot of heating & bending to get the pedal bracket the way I wanted. I couldn't find a 72 C-10 gas pedal assembly at the time. I also even got a little more carried away I cut the brake pedal pad mount off the 73 C-10 and welded it to my 64 brake pedal arm.
03-28-2016, 09:52 PM | #9 |
Custom Truck Lover!
looks very nice and well done
Squarebody guy |
04-02-2016, 11:25 PM | #10 |
Custom Truck Lover!
any other options out there?
Squarebody guy |
05-25-2017, 11:21 AM | #11 |
Ttt.....
