Old 07-27-2016, 10:02 PM   #1
63 & 64 Bowties
and a few others
63 & 64 Bowties's Avatar
What did you do with your truck today, Part 3
Part 1 & 2 were pretty overloaded, so let's get going on a new one.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 07-27-2016, 10:10 PM   #2
iowaboynca
iowaboynca's Avatar
Re: What did you do with your truck today, Part 3
Alright!
Up to 3!!! Oh yeah i tried to cook an egg on my truck w/the 106 F heat...not so much luck...
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 07-28-2016, 12:04 AM   #3
my56chevytruck
my56chevytruck's Avatar
phew, I started mine, made a rum and coke and listened to it purr. Then went back in the house to the AC.
RUBBER DOWN AND HIT THE ROAD!!!
my56chevytruck is offline   Reply With Quote
Old 07-28-2016, 03:52 AM   #4
MiraclePieCo
MiraclePieCo's Avatar
I removed my stock non-functioning gas gauge. It used to work, now it stopped. Not sure how to test it, but for $57 (Classic Parts) I'll just buy a new 12-volt unit.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 07-31-2016, 01:06 PM   #5
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Here are a couple of videos to compare the sound difference between my Flowmaster Super 40s and the newly installed Black Widow Exhaust Venoms.
https://www.youtube.com/watch?v=zrjKKxVke1Q
https://www.youtube.com/watch?v=MpDibidhYsA
ChuckDriver is offline   Reply With Quote
Old 08-09-2016, 10:14 PM   #6
my56chevytruck
I sure llike those Black Widow venoms.
Old 08-10-2016, 04:38 AM   #7
MiraclePieCo
Last week I got my gas gauge functioning - what a relief! Next I needed to address the heating issues I have at freeway speed (indicating an airflow deficiency).
I removed the old Chevy Cavalier 14" electric fan that was in my truck when I bought it (4-cylinder fan - pathetic!) and installed a Spal 16" high-performance unit. I've used this model before - they pull about four times the air of a cheapo fan. Ha ha, I should be able to throw my truck in neutral and the fan will pull me down the road like an airplane propeller!
I also removed the fan shroud that was in the truck. The shroud actually blocks much of the radiator, restricting airflow at speed by forcing all the air through the relatively small fan opening (see illustration below in case I haven't clarified this). Now I have unobstructed airflow front and rear through the radiator!
It's going to be in the mid-90's all week, a good time to test it out.
Old 08-12-2016, 07:24 AM   #8
b-mac
b-mac's Avatar
I'll be interested to see which way works better with your radiator. I used to try to run an electric on my "Hot Rod" 2.2 S10. It wouldn't keep it cool without a shroud. Ended up modifying my stock shroud and mounting the electric fan a few inches from the radiator.
b-mac is offline   Reply With Quote
Old 08-15-2016, 04:02 AM   #9
MiraclePieCo
Ongoing improvements to my '50. Today, door weatherstripping - Frost King self-adhesive from my local home improvement store. 10-minute installation. I'm hoping it will make a big reduction in wind noise.
Old 08-15-2016, 04:13 AM   #10
MiraclePieCo
Underhood airflow dynamics can be weird. I've seen some guys install flaps in their shrouds that open at speed to allow airflow, then suck closed when the fan activates.
I'll be driving the truck this weekend. It's supposed to be 102* and I have three 6% mountain passes to climb, so I'll report back on how it does.
Old 08-18-2016, 05:04 PM   #11
cyclonewade
Do tires count?
cyclonewade is offline   Reply With Quote
Old 08-19-2016, 04:57 PM   #12
MiraclePieCo
Originally Posted by cyclonewade View Post
Do tires count?
Yep - nice!
Old 08-19-2016, 09:05 PM   #13
tsmith8
did it make a difference?
tsmith8 is offline   Reply With Quote
Old 08-21-2016, 08:54 PM   #14
cyclonewade
First drive.
https://youtu.be/lFdxR-IfFmw
Old 08-21-2016, 09:16 PM   #15
my56chevytruck
Aside for going for a cruise, I put a new lokar shifter in the truck, along with the boot and chrome ring.
Old 08-21-2016, 09:17 PM   #16
my56chevytruck
that's great, nice looking ride as well.
Old 08-22-2016, 04:14 AM   #17
MiraclePieCo
Finally took the truck for a test drive after all the stuff I've fixed lately. It all worked better than I'd hoped!
Door weatherstripping: The Frost King self-adhesive weatherstrip significantly reduced wind noise and door rattles, while still allowing the doors to shut more easily than they ever have. Success!
Gas gauge: What a relief to have a working gas gauge! New sender, new gauge, finally I was able to get it functioning by removing a weird inline resistor wire on the hot wire. Success!
Freeway overheating. I suspected that my fan shroud was actually restricting airflow at highway speed. I removed it and sure enough, I can now go over 6% mountain passes at 100* outside temperature and the gauge climbs only to about 190. After that my new bigass Spal fan takes over. Success!
Details of all the above can be found in previous installments of this thread. Here's a pic of what I got to enjoy today, a working gas gauge and a centered temp gauge (please pardon the '54 gauges in a '50 dash). And just listen to how quiet it is ;-)
Old 08-22-2016, 04:29 AM   #18
MiraclePieCo
Congratulations - looks great! Don't loose those fenders out the back with no tailgate!
Old 08-22-2016, 09:57 AM   #19
nvrdone
if you have a 6 volt gage on a 12 volt system you need that in line resistor. its a voltage drop.
nvrdone is offline   Reply With Quote
Old 08-22-2016, 06:30 PM   #20
MiraclePieCo
Cool - thanks! Never seen one like it before.
Old 08-30-2016, 12:06 AM   #21
dirty dish
Size:  31.3 KBfinally got tires mounted and put on had to mount them by hand wouldn't fit on tire machine
dirty dish is offline   Reply With Quote
Old 08-30-2016, 11:10 AM   #22
OrrieG
OrrieG's Avatar
stovebolts.com has a great tech article on converting from 6 to 12 volts. Can't link it on my phone.
OrrieG is offline   Reply With Quote
Old 08-30-2016, 02:52 PM   #23
ChuckDriver
Picked up my new door panel inserts!
Old 08-30-2016, 05:54 PM   #24
CATMdude45
CATMdude45's Avatar
Interesting...... my gauges on my 52 are opposite, don't know if the PO messed it up.....what side is the speedo suppose to be on?
52 Chevy 3100 AD
68 Ford Bronco
06 Dodge 2500 Ram Cummins Diesel
CATMdude45 is offline   Reply With Quote
Old 08-30-2016, 09:41 PM   #25
oldtrucks617
Unhappy Re: What did you do with your truck today, Part 3
I picked up my newly rebuilt LS1,came out of a 1999 SS salvage.Trying to make lemonaid out of LEMONS..Know what I mean ?? going into my 57 GMC..Cali truck..they don't last around here,RUST,THIEVES.....4L60E auto is my best option,and all i have..PCM it and i'm good to go....pics in a few weeks.
oldtrucks617 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
