Old 02-18-2017, 06:20 PM   #1
schpeen
schpeen's Avatar
anyone upgrade their headlight on a 91 blazer k5?
have not found anything myself yet
1991 K5 Blazer 4x4 "9 ball"
2019 Chevy Silverado Trail Boss 4x4
2018 Chevy Colorado 2 door ZR2 4x4
1988 23' Mako Marine
2005 Harley Davidson Road King
schpeen is offline   Reply With Quote
Old 02-19-2017, 08:40 AM   #2
Edahall
Re: anyone upgrade their headlight on a 91 blazer k5?
Yes, I put a set of Hella H4 E code headlights in mine. I also added relays to the wiring. Huge difference in light output but not cheap. The stock headlights are absolutely pathetic.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 02-19-2017, 08:46 AM   #3
schpeen
schpeen's Avatar
wow that is good news really was hoping for a set of LEDs but that sounds better than what i got for sure
thanks man
Old 02-19-2017, 09:52 AM   #4
Edahall
thanks man
Someone correct me if I'm wrong but I've heard that the LED's are not much better (maybe even worse) than stock headlights. The ones I've seen seem to just put the light directly out in front and not project to a distance.
Another option would be making your own projectors but that would require a lot of fabrication.
These housings are not very common and were only used on a few models. The Camaro's and Firebird's used this size housing as well as the Jeep Cherokee Limited's and that's about all that comes to my mind.
Old 02-19-2017, 01:13 PM   #5
schpeen
schpeen's Avatar
I will look into the Hella. Since my truck is hella cool. Lol
Old 02-19-2017, 01:30 PM   #6
schpeen
schpeen's Avatar
4wheelparts $165 for 2 pair no relay included? did the relay come from?
Rampage H4 Headlamp Conversion Kit (Clear) - 5089927
Rampage | Part Number: RPP5089927
This part fits your vehicle:
1991 CHEVROLET BLAZER BASE V8 - 5.7 Liter - GAS Change Vehicle
Rampage - Rampage H4 Headlamp Conversion Kit (Clear) - 5089927 | 4WheelParts.com
Click to Enlarge
3.8 Read 4 Reviews
Qualifies for Free Shipping
Technical Details
Rectangular headlights
Headlights are a direct replacement
60% more luminescence and D.O.T. approved
Kit includes a pair of durable die-cast aluminum housings with s
Questions(1) Answers(1)
Overview
Instructions
Product Specs
Update your dim stock headlight bulbs to a set of Rampage H4 Conversion Headlights that are a direct replacement, 60% more luminescence and D.O.T. approved. This is a simple 10 minute installation that requires only a screwdriver and the results will be incredible. Kit includes a pair of durable die-cast aluminum housings with solid clear glass lens and 2-H4 55/60W Bulbs. Imagine a whole new brighter nighttime driving experience that’s safer and less fatiguing.
Old 02-19-2017, 06:57 PM   #7
Edahall
I'm not sure those headlights will fit your 91 K5. I believe they are 150mm by 92mm or 5.9 inches by 3.6 inches roughly. The ones I have are made by Bosch and use Hella H4 bulbs, P/N HL21001
I wired up my own relays but you can buy the kit also.
Old 02-19-2017, 07:34 PM   #8
Edahall
LMC sells these but I don't know how good they are.
http://www.lmctruck.com/features/cc/CCEL5.htm
Old 02-19-2017, 09:13 PM   #9
buffydores
buffydores's Avatar
LED headlamps use to struggle with throw, but it's not the case now. They've closed the gap and exceeded HID and Halogen. I currently run Hella HIDs on my Jeep (same 7" round hole as the Blazer). I just installed a set of Lightforce 215mm LED flood lights. It's laughable how much more light the LEDs are capable of producing compared to the HIDs. As for the '91 headlamps. I'm not sure about the options out there. The 7" rounds are so great for options.
Old 02-20-2017, 01:49 AM   #10
Edahall
Did you install these LEDs in place of the stock headlights? Are they legal to use? Do other drivers get blinded? Here are the specs. Wish they weren't so expensive.
Power: 108 W
Raw lumens: 7794
Old 02-20-2017, 04:25 PM   #11
buffydores
buffydores's Avatar
Power: 108 W
Raw lumens: 7794
The big driving light (sorry, I said floods) are not legal. You'd kill people.
Raw lumens won't really tell you a bunch.
Old 06-11-2017, 09:48 PM   #12
1976K5CHALET
1976K5CHALET's Avatar
Swap to a base model core support and run JW Speaker 8900's.
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 06-15-2017, 07:52 PM   #13
buffydores
buffydores's Avatar
That is super sharp
