Old 06-16-2017, 10:03 PM   #1
SilverMachine
Alright...down to 3 cam choices, you decide!
ok, so after alot of internet surfing over an extended period of time, i have come to my top 3 cam choices. Voodoo 262, Comp cams xe262h, Crane Energizer 274HO6. Engine: (currently stock goodwrench 350 w/ edlebrock 600cfm carb and performer intake) Im getting Edlebrock E street aluminum heads (185cc intake, 64cc combustion chambers etc... .550 max lift i think) My truck is a daily driver but im looking for some more pep down low. i prefer an exhaust note that is easily distinguishable from a stock cam. (looking to keep reliability..and not absolutely kill gas mileage)
Specs:
Lunati Voodoo 262: Advertised Duration (Int/Exh): 262/268
Duration @ .050 (Int/Exh): 219/227
Gross Valve Lift (Int/Exh): .468/.489
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1400-5800
Comp xe262h - Duration @.050 - 218/224
Lift - .462/.469
LSA - 110
Crane 274H06 - 274 advertised duration, .450/.450 lift, 218/218 duration @.050
Thanks if any of you actually reply
btw..i am probably going to upgrade to around a 2000 stall torque converter.
SilverMachine is offline   Reply With Quote
Old 06-17-2017, 12:47 AM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Alright...down to 3 cam choices, you decide!
For those cam choices I personally would chose the XE262.
For your intended usage, IMO aluminum heads aren't what you NEED.
The intake is 185cc, but might make the motor feel lazy till you get the port volume up. The aluminum heads will dissipate heat faster and dispense that heat under the hood, which may promote vapor lock with todays fuel.
When gm did aluminum heads on the L98, they used 60cc chambers , 163 intake runners, and put it in a sports car so the airflow could help the cooling.
Summit Vortec heads- 700/pr
https://www.summitracing.com/parts/sum-151124/overview/
175cc runner, vortec combustion chamber 67cc, screwed in studs
Vortec intake - 160
http://www.ebay.com/itm/Summit-Racin...ZXUkSh&vxp=mtr
Self aligning rocker arms - 69
http://www.ebay.com/itm/1988-2002-GM...tY9f9M&vxp=mtr
This will help you get to your goals without being disappointed.
Others will chime in, this is my .02
1969 307, t350
1950 Chevy Wagon
Old 06-17-2017, 08:35 AM   #3
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
I also vote for the xe262. I think you'll be pleasantly surprised by the power your 350 will make with the e-street's and this cam. If you change the converter it will be even more fun. Next you'll be investing in new tires!
Mike
P.S. Make sure to use a good molly assembly lube, an oil additive containing zinc, and follow correct break in procedures.
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 06-17-2017, 12:22 PM   #4
GRADYS Performance
GRADYS Performance's Avatar
The Comp Cam 262 or do yourself a favor and go 1 size smaller. for a Daily driver you will not benefit from a larger camshaft. Look at the specs for the Edelbrock Performer camshaft. It is designed to be the best cam to work with your Performer Manifold. It or a cam with virtually the same specs will be your Best choice.
GRADYS Performance is offline   Reply With Quote
Old 06-17-2017, 01:44 PM   #5
mongocanfly
Post Whore
Comp cam would be my choice
Old 06-17-2017, 09:51 PM   #6
Jake Wade
Jake Wade's Avatar
If you are wanting more pep down low, all three cam choices are too big.
Jake Wade is offline   Reply With Quote
Old 06-17-2017, 10:36 PM   #7
Nuckingfuts
My son's rig has this exact set up (with the comp cam, EB carb & intake, flow master exhaust) and though it rips 'ok' up top, there is still lots to be desired off the line.
Short of changing rear end gears, how else can you gain low end torque/power with the 'set up of interest' ?
Nuckingfuts is offline   Reply With Quote
Old 06-18-2017, 01:32 AM   #8
rich weyand
rich weyand's Avatar
The Comp Cams 12-238-2 is a nice choice if you switch to those heads.
One step down, and more in the bottom, is the 12-235-2.
Another step down, and even more in the bottom, is the 12-300-4.
I would probably recommend the 12-235-2.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 06-18-2017, 08:17 AM   #9
ratskin
If you're using a 700r4 you could get away with the Comp Cam.
ratskin is offline   Reply With Quote
350, cam, choose, engine, heads
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
