11-24-2020, 07:01 AM | #51 | |
Re: Funny truck stuff from the board members
Thanks. Now I have another word to go look up.
11-24-2020, 10:26 AM | #52 |
Who Changed This?
I rebuilt the 305 that was in my '85 Pontiac Parisienne wagon and stuffed it in my '68 Skylark. With the 700 trans, I got 18.5 MPG in rush hour traffic. That low first gear made it a great hole shot car, even with the 2.73 axle. I put in a little Edelbrock cam and added a 600 CFM carb and the smallest cam Edelbrock sells. It really could have used a 3.42 or so axle, though. I sold it and the guy who bought did that.
11-24-2020, 10:33 AM | #53 | |
1968 - 1971 with 2 Barrel Carb Max Brake Horsepower: 200 @ 5800 rpm Max Torque: 300 @ 4200 rpm Stroke: 3.25 Bore: 3.875 Compression: 9.00 Firing Order: 18436572 |
11-24-2020, 03:59 PM | #54 |
Still got my 1970 307 from my C10, ran when pulled,I didn't think there was a market for them,
11-24-2020, 05:26 PM | #55 |
"Tail Gate Best Seat In House"
Never drive back home from having a BIL push you and your car to get it started some 5 miles for the rotor you thought you left ,,when all the time it was in your shirt pocket
When you learn a thing a day you store up smart. |
11-24-2020, 07:59 PM | #56 |
[QUOTE]My father bought a new El Camino in 1968 that had the 307, it was a damn good motor. They were an under square motor, 283 block with a 327 crank which made them quite torquey for a 2 barreled carb engine.
For what it is worth a 307 is an over square engine, 3.875 bore x 3.25 stroke. a 307 is basically a factory built 283 stroker. My brothers and I had alot of fun "racing" a built 307 we put in a 62 Chevy II. A much better engine than the tiny piston, tiny valve and 350 stroke = 305 smog motor |
11-24-2020, 10:27 PM | #57 | |
All about them K’s
[quote=gvw5400;8840399]
I don’t have any experience with the 307 but I’ve heard decent things about it. I like the 283’s a lot, revving little bastards they are, and the 327’s aren’t much different. There love child can’t be too bad... A de-stroked bigger bore engine like the 302 or 307 is a great combo for high rpms. A small bore longer stroke not so much, especially with weak heads.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
11-24-2020, 11:02 PM | #58 |
a 307 is basically a factory built 283 stroker. You are 100% correct and I knew that....what I typed and what I was thinking was 180 out..Lol |
11-26-2020, 09:58 PM | #59 |
isn't amazing how we can be thinking one thing and our typing magic fingers
seem to have a mind of their own! lol. Sheepdip I hope Thanksgiving was good for you guys. All The Best Dirk |
11-27-2020, 12:21 AM | #60 |
Who Changed This?
I was designing a piece of equipment that would absorb the radio frequency energy from a transmitter, many years ago. I got all the parts lined up, and then flipped them around to check the model for clearances, and sent the drawing to manufacturing. All the parts came back, and it didn't go together, because I had flipped the model around. Luckily, I was able to use a few parts off the shelf to make my design work. About $1000, which is chump-change in the defense biz. Pretty embarrassing, anyway. Magic fingers can still miss the target.
11-27-2020, 08:56 AM | #61 | |
I had a 307 wear the fiber timing gear out. I had a new dbl roller for it looking for time to install when it jumped. Ended up with bent valves, 120k on the motor. That's the one I rebuilt. Minimal machining required. The crank was micro-polish ready, no cylinder ridge, and they only needed a light hone for hatch marks. Everyone was impressed with how little wear that engine showed.
11-27-2020, 01:34 PM | #62 | |
Can't tell you how many times I've looked for a part, and the last place looked was literally the last place possible. From another board just now..
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
11-27-2020, 01:49 PM | #63 |
Synthetic belt tires won't rust
12-18-2021, 06:09 PM | #64 |
Bringing this thread to the Top.
Do-It Yourself Spark plug wire separators
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
12-18-2021, 06:38 PM | #65 |
That's actually not a bad idea.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-18-2021, 07:26 PM | #66 |
That's halfass. Shoulda gotten color coordinated zip-ties
12-18-2021, 11:34 PM | #67 |
The zip tie wire separators work great!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
12-19-2021, 12:04 AM | #68 | |
All about them K’s
12-19-2021, 01:01 AM | #69 |
Someone here has a quote in their signature that I've always liked: If it ain't broke, fix it 'til it is!
Gregski has a build thread for the truck he just sold named Rusty. He was in the middle of working on something and had to choose how to proceed. As always, there were a few options including spending more time and money. He made his choice and knew that some people would not agree. He didn't take issue with them, but simply and humbly said "I plan on regretting this later." |
12-19-2021, 03:14 AM | #70 |
Location: Herculaneum MO (20 minutes south of St. Louis
You're worried about the zip ties? I can't get past the three different color spark plug wires
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
12-19-2021, 09:10 AM | #71 |
Been using the zip tie trick for years, works great
12-19-2021, 10:02 AM | #72 |
laying low
Neat alright. But where do you get the GOOD zip ties? The ones I have won't hold up long enough to walk away from them before they break much less use them close to a hot engine. I'm talkin cheap.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
12-19-2021, 07:58 PM | #73 | |
R.I.P. E.S.L.L.
It's like Ziploc plastic bags. I always buy the best because the cheap ones will leak and make a mess in the fridge. The cheap stuff doesn't save you any money.
1971 Custom C/20 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
12-20-2021, 11:52 AM | #74 |
I've been happy with the commercial electric zip ties that I've been using on my truck for a couple years now. I really like the small ones for wiring stuff
12-20-2021, 12:12 PM | #75 |
Thread Tools | |
Display Modes | |
